Front upper dash TV
11-07-2005, 01:46
Front upper dash TV
If I remember right the TV was just held in with the straps. You can take
the front off with some screws in the side brackets & take the TV out the
front. I needed to do this anyway because I wanted to fasten my Flat screen to
front.
Don
89 SP 36'
Butler, PA
Is,
the TV connected(screwed)to the plywood base it sits on? I am
trying to replace it. Have already took off metal strap over tv. Also
does the tv come out the rear with base attached, or through the front?
11-07-2005, 04:42
Front upper dash TV
Is the TV connected(screwed)to the plywood base it sits on? I am
11-07-2005, 04:48
Front upper dash TV
--- In WanderlodgeForum@yahoogroups.com, "ED GARDELS"
Also
front?
Forgot to mention its a 89sp.
11-07-2005, 04:48
Front upper dash TV
Also
front?
11-07-2005, 05:04
Front upper dash TV
Hi Ed,
It would help if you would sign your posts and indicate what model you
have so that we can response more accurately. For instance, if you
are talking about the backup monitor/TV in an 83 PT, the answer is
that the monitor is connected to the upper dash housing by four screws
around the front of the monitor. Disconnect high power cable and lift
out. So, what model are you talking about? And, is it the TV/backup
monitor or a separate TV?
Thanks,
83 PT40 "Stagecoach" - For Sale - with Financing!
91 PT40 "Texas Minivan"
11-07-2005, 06:11
Front upper dash TV
--- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@y...>
> Hi Ed,
you
screws
lift
TV/backup
> Thanks,
SORRY about not signing, I noticed my mistake as soon as I sent it.
(89sp) and I guess its probably the OVERHEAD dash. Imnew at this as
Ive only had my bb for a few months(2 trips). Dont know much about
it, I readthe forum and trial and error.see msg 6340 for
signing.Thanks for the reply.
ED GARDELS 89SP
ARLINGTON, TEXAS
> Mike Bulriss
> San Antonio, TX
Also
front?
11-07-2005, 06:11
Front upper dash TV
> Hi Ed,
you
screws
lift
TV/backup
> Thanks,
ED GARDELS 89SP
ARLINGTON, TEXAS
> Mike Bulriss
> San Antonio, TX
Also
front?
11-07-2005, 06:50
Front upper dash TV
Ed, you are close by. You going to the Boerne rally? Ernie-83pt40 in Weatherford
-----Original Message-----
Sent: Mon, 07 Nov 2005 18:11:33 -0000
Subject: [WanderlodgeForum] Re: Front upper dash TV
> Hi Ed,
you
screws
lift
TV/backup
> Thanks,
ED GARDELS 89SP
ARLINGTON, TEXAS
> Mike Bulriss
> San Antonio, TX
Also
front?
Yahoo! Groups Links
11-07-2005, 08:47
Front upper dash TV
Ernie, Glad you made it back home ok. Are you going to make it to
the rally? What day are you leaving if you are? We are leaving on
the 1st of December.Tell Brenda hi for us.
Best Regards,
Rick & Terri Mcintire
86PT38 Patillo,Tx
in Weatherford
> From: ED GARDELS
<mbulriss@y...>
> > Hi Ed,
model
> you
you
is
> screws
> lift
> TV/backup
> > Thanks,
as
> ED GARDELS 89SP
> ARLINGTON, TEXAS
> > Mike Bulriss
> > San Antonio, TX
am
tv.
> Also
> front?
> Yahoo! Groups Links
11-07-2005, 10:17
Front upper dash TV
--- ED: I have a 90SP36 and put in a 20 inch LCD TV and highly
recommend it. made a metal frame etc.
recommend a 24 in LCD with the speaker ON the bottom..It will fit..u
can get a 24 inch for what I paid for 20 Inch....
regards,
Hank Hannigan
90SP36
> Also
> front?
