No Engine Hot Water
11-09-2005, 12:37
No Engine Hot Water
The other day I drained the fresh water tank and flushed it. I also
drained the hot water heater. Now it does not generate hot water via the engine, although it works fine on electricity. All other water system components and functions are fine. Any suggestions? I'm pretty sure it is another newbie screw up:-) Steve Harrie '86 PT38 St. George, UT Heading to Overton NV Tomorrow |
11-09-2005, 14:17
No Engine Hot Water
Steve you know it worked before you drained it and flushed it so its
got to be something you did during the process< big been there and did the same thing grin>. Chances are you turned off the coolant supply between the engine and the water tank. Should be two valves in yours. Tom Warner 1982 FC35 Vernon Center,NY At 07:37 PM 11/9/2005, you wrote: >The other day I drained the fresh water tank and flushed it. I also >drained the hot water heater. Now it does not generate hot water via >the engine, although it works fine on electricity. All other water >system components and functions are fine. > >Any suggestions? I'm pretty sure it is another newbie screw up:-) > >Steve Harrie >'86 PT38 >St. George, UT >Heading to Overton NV Tomorrow > > > > > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
11-09-2005, 15:41
No Engine Hot Water
the water tank. Should be two valves in yours. Hmmm...I don't recall doing anything in the engine compartment, but I'll definately take a look! All I had to do is flip some switches on the bed frame to drain the hot water heater. Thanks for the tip Tom. Steve Harrie '86 PT38 Twin Beds |
11-19-2005, 06:43
No Engine Hot Water
Sounds like your problem could be air in the system. Purge the air at high
connections or just leave it alone and watch the coolant level. It will drop when the air works it's way through. Dick Hayden - '87 PT38 ----- Original Message ----- From: trvlngnrs To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, November 09, 2005 8:41 PM Subject: [WanderlodgeForum] Re: No Engine Hot Water >Chances are you turned off the coolant supply between the engine and the water tank. Should be two valves in yours. Hmmm...I don't recall doing anything in the engine compartment, but I'll definately take a look! All I had to do is flip some switches on the bed frame to drain the hot water heater. Thanks for the tip Tom. Steve Harrie '86 PT38 Twin Beds SPONSORED LINKS Recreational vehicles<http://groups.yahoo.com/gads?t=ms&k=Recr...ation\ al+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea\ ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKk\ U7Dzhn_ObWmSYTw> Wanderlodge<http://groups.yahoo.com/gads?t=ms&k=Wand...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj\ 9U0JvqYQ> Automotive maintenance<http://groups.yahoo.com/gads?t=ms&k=Auto...ecrea\ tional+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle\ +dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4\ u_5wI8Pmy34cC1O9CxA> Recreational vehicle dealer<http://groups.yahoo.com/gads?t=ms&k=Recr...ecrea\ tional+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle\ +dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_\ XahaeYHfELr6o72IW1A> Used recreational vehicles<http://groups.yahoo.com/gads?t=ms&k=Used...Recre\ ational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicl\ e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UG\ EY5km4L-kXbDI4ZSadEw> Automotive radiators<http://groups.yahoo.com/gads?t=ms&k=Auto...ation\ al+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea\ ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmI\ SsCWgTnMq_4GlXA> ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum<http://groups.yahoo.com/group/WanderlodgeForum>" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service<http://docs.yahoo.com/info/terms/>. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
