Governor diagnosis
11-11-2005, 14:51
Governor diagnosis
Hey all,
If anyone here can explain the function of the governor in relation to the air dryer specifically that's be great. I have three lines going to the governor on my Bluebird Q-bus. One big one, and then two smaller ones. One smaller line goes to the air dryer on the side of it. Does one line supply the air, build pressure up to the governed pressure, then open the other line of the governor to exert an air force onto the dryer? How does the governor manage to shut the compressor off? The reason I ask is b/c my compressor is seemingly constantly pumping. The air dryer seems to be doing it's job by releasing the air, and that seems to be the only time I don't hear the compressor running, right when the air ejects. It's very annoying to have it pop off the air pressure every 15-20 sec on the interstate. However the dryer doesn't seem to stick open. It pops off and then hushes right up, it just seems I keep building and building air pressure and the only reason I can think of why is b/c the compressor is never shutting off. thanks, Steve 2 '98 Bluebird QBRE Partybuses |
11-11-2005, 16:38
Governor diagnosis
Steve its easier to let you read about how the governor works then
for me to explain it. But your compressor SHOULD be running all of the time since there is no method to turn it off and on. The pully is directly connected to the crankshaft. Read this and it will be clearer how it works. http://www.bendix.com/downloads/service_.../01503.pdf This Bendix site is one of the best I have found and explains how every component of your air system works. I have printed off lots of information from this site which I have put into loose leaf 3 ring binders and keep in my coach when travelling. Hope this helps you, Tom Warner 1982 FC35 Vernon Center,NY At 09:51 PM 11/11/2005, you wrote: >Hey all, > > If anyone here can explain the function of the governor in >relation to the air dryer specifically that's be great. > I have three lines going to the governor on my Bluebird Q-bus. >One big one, and then two smaller ones. One smaller line goes to the >air dryer on the side of it. > Does one line supply the air, build pressure up to the governed >pressure, then open the other line of the governor to exert an air >force onto the dryer? How does the governor manage to shut the >compressor off? > The reason I ask is b/c my compressor is seemingly constantly >pumping. The air dryer seems to be doing it's job by releasing the >air, and that seems to be the only time I don't hear the compressor >running, right when the air ejects. It's very annoying to have it >pop off the air pressure every 15-20 sec on the interstate. However >the dryer doesn't seem to stick open. It pops off and then hushes >right up, it just seems I keep building and building air pressure >and the only reason I can think of why is b/c the compressor is >never shutting off. > >thanks, >Steve >2 '98 Bluebird QBRE Partybuses > > > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
11-13-2005, 18:15
Governor diagnosis
Wow, that's all I needed. Thanks for pointing me in the right
direction! Steve --- In WanderlodgeForum@yahoogroups.com, Tom Warner wrote: > > Steve its easier to let you read about how the governor works then > for me to explain it. But your compressor SHOULD be running all of > the time since there is no method to turn it off and on. The pully > is directly connected to the crankshaft. Read this and it will be > clearer how it works. > http://www.bendix.com/downloads/service_.../01503.pdf > > This Bendix site is one of the best I have found and explains how > every component of your air system works. I have printed off lots of > information from this site which I have put into loose leaf 3 ring > binders and keep in my coach when travelling. > > Hope this helps you, > > Tom Warner > 1982 FC35 > Vernon Center,NY > > > At 09:51 PM 11/11/2005, you wrote: > >Hey all, > > > > If anyone here can explain the function of the governor in > >relation to the air dryer specifically that's be great. > > I have three lines going to the governor on my Bluebird Q- bus. > >One big one, and then two smaller ones. One smaller line goes to the > >air dryer on the side of it. > > Does one line supply the air, build pressure up to the governed > >pressure, then open the other line of the governor to exert an air > >force onto the dryer? How does the governor manage to shut the > >compressor off? > > The reason I ask is b/c my compressor is seemingly constantly > >pumping. The air dryer seems to be doing it's job by releasing the > >air, and that seems to be the only time I don't hear the compressor > >running, right when the air ejects. It's very annoying to have it > >pop off the air pressure every 15-20 sec on the interstate. However > >the dryer doesn't seem to stick open. It pops off and then hushes > >right up, it just seems I keep building and building air pressure > >and the only reason I can think of why is b/c the compressor is > >never shutting off. > > > >thanks, > >Steve > >2 '98 Bluebird QBRE Partybuses > > > > > > > > > > > >---------- > >YAHOO! GROUPS LINKS > > > > * Visit your group > > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > > * > > * To unsubscribe from this group, send an email to: > > * > > > > > > * > > * Your use of Yahoo! Groups is subject to the > > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > > > > >---------- > |
