step air leak
11-16-2005, 12:50
step air leak
I have a leak at the control box- if that is the correct term, by my
step. The cylinder is fine. The leak is not at a fitting, but at another part of that control. Anyone have this situation? Ernie-83PT40 in Weatherford, Tx- YUP--AT HOME!! |
11-16-2005, 14:13
step air leak
Ernie, I had the same prob as a symtom to a bad seal in the ram. When
I would tug the step fully open the air hissing would stop. (My 94pt40 has a non spring ram with two air ports) If you remove the ram and blow air in, to push the stroke out , the air should stop blowing out the other port when the stroke bottoms out. if the air continues to blow out the other port the seal is bad in the ram. You may be able to remove both airlines to the ram and test it without removing the ram first. I tried to split the ram open to replace the seal but the Clippar ram used on my bus could not be serviced. Gregory O'Connor 94PT40 Romoland California --- In WanderlodgeForum@yahoogroups.com, "Ernest Ekberg" > > I have a leak at the control box- if that is the correct term, by my > step. The cylinder is fine. The leak is not at a fitting, but at > another part of that control. Anyone have this situation? Ernie- 83PT40 > in Weatherford, Tx- YUP--AT HOME!! > |
11-16-2005, 15:04
step air leak
Ernie,
As a suggestion,I would, first of all, contact Bennie Collier at BlueBird Customer Service and get a detailed schematic of the step air system and ask him where you should start trouble shooting. He usually knows the weaknesses & common failures and can save you some time. I do all my own work on my '91 (except computers) and (1)reading the manual, (2)checking the blueprints, and (3)then calling Bennie are my first steps in fixing stuff. They often have better drawings and he will fax them to you. My '78 FC 31' had a tempermental step. Cold weather made it slow. I'm getting ready to work on my TV antenna system and I'm trying to "tone out" my coax cables, so I will probably be asking for a diagram of them soon. I usually only have to call him about once a year! I live just west of Lewisville, Texas (940-241-2244) if you need any help. Bob & Judy Johannesen '91 WLWB 40' "Seldom Blue", FMCA F72567, WL# 1986, Vintage Birds #345 Argyle, Texas Gregory OConnor Ernie, I had the same prob as a symtom to a bad seal in the ram. When I would tug the step fully open the air hissing would stop. (My 94pt40 has a non spring ram with two air ports) If you remove the ram and blow air in, to push the stroke out , the air should stop blowing out the other port when the stroke bottoms out. if the air continues to blow out the other port the seal is bad in the ram. You may be able to remove both airlines to the ram and test it without removing the ram first. I tried to split the ram open to replace the seal but the Clippar ram used on my bus could not be serviced. Gregory O'Connor 94PT40 Romoland California --- In WanderlodgeForum@yahoogroups.com, "Ernest Ekberg" > > I have a leak at the control box- if that is the correct term, by my > step. The cylinder is fine. The leak is not at a fitting, but at > another part of that control. Anyone have this situation? Ernie- 83PT40 > in Weatherford, Tx- YUP--AT HOME!! > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators --------------------------------- YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- --------------------------------- Yahoo! FareChase - Search multiple travel sites in one click. [Non-text portions of this message have been removed] |
11-16-2005, 19:38
step air leak
Thanks Greg, am probably going to get one of those fancy leak detectors to
pinpoint ALL of my air leaks. Ernie 83pt40 in texas [Non-text portions of this message have been removed] |
11-16-2005, 19:40
step air leak
Hi Bob, I believe Ralph came to your place to help you with your coach. Come
on down to our Lone Star Birds rally in Boerne. Ernie- in weatherford [Non-text portions of this message have been removed] |
11-17-2005, 00:56
step air leak
Tom- what section of walmart has the rectorseek? Ernie- kinda cheap in texas
11-17-2005, 03:35
step air leak
Ernie I have one of the expensive ultrasonic leak detectors and it
works. But I also have a small bottle of Rectorseek that you can buy at Walmart and it works just as good. You swab it on all of the places you think there might be a leak and no matter how small the leak is this stuff will form a bubble around it locating the exact spot. Its a couple of dollars a bottle. http://www.rectorseal.com/ac.htm#leak%20locators Tom Warner 1982 FC35 Vernon Center,Ny At 07:38 AM 11/17/2005, you wrote: >Thanks Greg, am probably going to get one of those fancy leak detectors to >pinpoint ALL of my air leaks. Ernie 83pt40 in texas > > >[Non-text portions of this message have been removed] |
11-17-2005, 04:51
step air leak
Thanks Tom- will get some tomorrow, The forum is up and running- maybe a
yahoo hiccup. Ernie [Non-text portions of this message have been removed] |
11-17-2005, 09:17
step air leak
Ernie today someone else has been occupying my body. I meant Home
Depot and its in the heating and air conditioning section. Its in a plastic bottle and is an orange color. This stuff sticks like snot but will wash off easily or dry without harming anything you swab it on to. Believe me if there is even the tiniest leak it will start forming a bubble even hours later. Tom At 12:56 PM 11/17/2005, you wrote: >Tom- what section of walmart has the rectorseek? Ernie- kinda cheap in texas > > >[Non-text portions of this message have been removed] > > > >SPONSORED LINKS ><http://groups.yahoo.com/gads?t=ms&k=Recr...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_\ ObWmSYTw>Recreational >vehicles ><http://groups.yahoo.com/gads?t=ms&k=Wand...w2=Wa\ nderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre\ ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>W\ anderlodge ><http://groups.yahoo.com/gads?t=ms&k=Auto...3;veh\ icles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5\ =Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy3\ 4cC1O9CxA>Automotive >maintenance ><http://groups.yahoo.com/gads?t=ms&k=Recr...tiona\ l+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal\ er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xahae\ YHfELr6o72IW1A>Recreational >vehicle dealer ><http://groups.yahoo.com/gads?t=ms&k=Used...ional\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L\ -kXbDI4ZSadEw>Used >recreational vehicles ><http://groups.yahoo.com/gads?t=ms&k=Auto...vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnM\ q_4GlXA>Automotive >radiators > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
11-18-2005, 08:41
step air leak
Bill, I think that may be the same stuff Tom Warner alerted me to, yesterday.
Sorry- but only drink stuff from a box. Ernie-83pt40 with air and oil leaks intexas [Non-text portions of this message have been removed] |
