block heaters question
11-20-2005, 08:04
Ok , how long should it take to heat the block up? should I leave it on
overnight? guy smalley 86 pt 40 |
11-20-2005, 08:43
Hi Guy, I have found that 2-3 hours of block heater time is fine and results
is a good clean start except in the very worst of conditions (<0 degrees F). The problem is getting up that early before an early morning departure. I might also add that I always leave my PT-36 6V92 plugged in to AC until after I fire the engine. Regards, Neil Author, "The RVer's Ultimate Survival Guide" http://www.rvsafetyinfo.com author@... -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of guysmalley Sent: Sunday, November 20, 2005 12:05 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] block heaters question Ok , how long should it take to heat the block up? should I leave it on overnight? guy smalley 86 pt 40 Yahoo! Groups Links |
11-20-2005, 10:10
You might want to read the instructions that comes with the block
heater. It specifically states to not have the coach/truck plugged in to the AC when starting as it will drastically shorten the life of the heater... Blair in Oregon At 12:43 PM 11/20/2005, you wrote: >Hi Guy, I have found that 2-3 hours of block heater time is fine and results >is a good clean start except in the very worst of conditions (<0 degrees F). >The problem is getting up that early before an early morning departure. I >might also add that I always leave my PT-36 6V92 plugged in to AC until >after I fire the engine. > >Regards, [Non-text portions of this message have been removed] |
11-20-2005, 11:05
Good to know Blair. Thanks
Original Message: ----------------- From: Blair vagabond@... Date: Sun, 20 Nov 2005 14:10:18 -0800 To: WanderlodgeForum@yahoogroups.com Subject: RE: [WanderlodgeForum] block heaters question You might want to read the instructions that comes with the block heater. Â It specifically states to not have the coach/truck plugged in to the AC when starting as it will drastically shorten the life of the heater... Blair in Oregon At 12:43 PM 11/20/2005, you wrote: >Hi Guy, I have found that 2-3 hours of block heater time is fine and results >is a good clean start except in the very worst of conditions (<0 degrees F). >The problem is getting up that early before an early morning departure. I >might also add that I always leave my PT-36 6V92 plugged in to AC until >after I fire the engine. > >Regards, [Non-text portions of this message have been removed] <!-- |**|begin egp html banner|**| --> SPONSORED LINKS
<!-- |**|end egp html banner|**| --> <!-- |**|begin egp html banner|**| --> YAHOO! GROUPS LINKS
<!-- |**|end egp html banner|**| --> -------------------------------------------------------------------- mail2web - Check your email from the web at http://mail2web.com/ . |
11-20-2005, 11:23
Hi Rob! Yep, I found out the hard way. Burned mine out and
replaced....found that juicy tidbit in the package and called Wayne's. Said that a lot of fleet operators go in early and unplug all the tractors before the drivers show up for work.....Blair in Oregon At 03:05 PM 11/20/2005, you wrote: >Good to know Blair. Thanks > >Original Message: >----------------- >From: Blair vagabond@... >Date: Sun, 20 Nov 2005 14:10:18 -0800 >To: WanderlodgeForum@yahoogroups.com >Subject: RE: [WanderlodgeForum] block heaters question > > > > > > > >You might want to read the instructions that comes with the block >heater. It specifically states >to not have the coach/truck plugged in to the AC when starting as it will > >drastically shorten the >life of the heater... > >Blair in Oregon > > > >At 12:43 PM 11/20/2005, you wrote: > >Hi Guy, I have found that 2-3 hours of block heater time is fine and >results > >is a good clean start except in the very worst of conditions (<0 degrees >F). > >The problem is getting up that early before an early morning departure. >I > >might also add that I always leave my PT-36 6V92 plugged in to AC until > >after I fire the engine. > > > >Regards, > > >[Non-text portions of this message have been removed] > > > > > ><!-- |**|begin egp html banner|**| --> > > > > SPONSORED LINKS >
><!-- |**|end egp html banner|**| --> > > > ><!-- |**|begin egp html banner|**| --> > > >
>> YAHOO! GROUPS LINKS > >
>> > ><!-- |**|end egp html banner|**| --> > > > > > > >-------------------------------------------------------------------- >mail2web - Check your email from the web at ><http://mail2web.com/>http://mail2web.com/ . > > > > >SPONSORED LINKS ><http://groups.yahoo.com/gads?t=ms&k=Recr...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_\ ObWmSYTw>Recreational >vehicles ><http://groups.yahoo.com/gads?t=ms&k=Wand...w2=Wa\ nderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre\ ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>W\ anderlodge ><http://groups.yahoo.com/gads?t=ms&k=Auto...3;veh\ icles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5\ =Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy3\ 4cC1O9CxA>Automotive >maintenance ><http://groups.yahoo.com/gads?t=ms&k=Recr...tiona\ l+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal\ er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xahae\ YHfELr6o72IW1A>Recreational >vehicle dealer ><http://groups.yahoo.com/gads?t=ms&k=Used...ional\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L\ -kXbDI4ZSadEw>Used >recreational vehicles ><http://groups.yahoo.com/gads?t=ms&k=Auto...vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnM\ q_4GlXA>Automotive >radiators > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- [Non-text portions of this message have been removed] |
11-20-2005, 17:38
No man should be in the very worst conditions(<0 degrees F)!!!
LT 90 SP in Eclectic, AL ----- Original Message ----- From: "Neil & Pat LeKander" To: Sent: Sunday, November 20, 2005 2:43 PM Subject: RE: [WanderlodgeForum] block heaters question > Hi Guy, I have found that 2-3 hours of block heater time is fine and > results > is a good clean start except in the very worst of conditions (<0 degrees > F). > The problem is getting up that early before an early morning departure. I > might also add that I always leave my PT-36 6V92 plugged in to AC until > after I fire the engine. > > Regards, > > Neil > Author, "The RVer's Ultimate Survival Guide" > http://www.rvsafetyinfo.com > author@... > > -----Original Message----- > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of guysmalley > Sent: Sunday, November 20, 2005 12:05 PM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] block heaters question > > Ok , how long should it take to heat the block up? should I leave it on > overnight? > > guy smalley > 86 pt 40 > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > |
