Starting Batteries
11-30-2005, 07:03
Starting Batteries
I was wandering what starting batteries was good for a 3208 300 HP TA. When
I got mine it had deep cycle batteries in the engine compartment. They were 675 CCA . When I went to get new batteries today I looked at starting batteries that were 875 CCA .He said they were the same as they put in a Ford Truck with a Diesel engine. I looked at my truck & sure enough that is what it had in it. He said Interstate did make a commercial battery that big trucks use. Now I am confused as what to get. Any opinion on what is the best CCA ? What does everyone else use. Don 89 SP 36' Butler, PA [Non-text portions of this message have been removed] |
11-30-2005, 08:01
Starting Batteries
Don, I just installed 4 new Trojan's in my coach. My other batteries lasted a
little over 3 years. Ernie-83pt40 in Texas [Non-text portions of this message have been removed] |
11-30-2005, 08:16
Starting Batteries
Hank- we look forward to seeing you guys back here when you get "bored" with
Australia. Ernie- 83pt40 going south to Boerne [Non-text portions of this message have been removed] |
11-30-2005, 10:05
Starting Batteries
Hi All Thanks for the info on the batteries. I have 4 Trojans for the
coach that are 135's. They are 2 years old & doing a good job. My starting batteries are on a isolator as they don't run down when the coach batteries do. Is that the function of the Isolator? I guess I will look for the highest CCA that I can get & still fit in the space of the hold down. I have heard that you can use six volt & twelve volt if they are not in the same bank. Is that not true? I have been running the six volts in the coach & twelve volt deep cycle for the engine for two years without any trouble. I just thought that the starting batteries are better for the engine that the deep cycle. Don 89 SP 36' Butler, PA Don, I just installed 4 new Trojan's in my coach. My other batteries lasted a little over 3 years. Ernie-83pt40 in Texas [Non-text portions of this message have been removed] |
11-30-2005, 11:19
Starting Batteries
Bill, Are you batteries all in one compartment? Mine doesn't have a
dedicated battery for the genny.& I don't think it has an alternator. I'll check tomorrow to see. Don 89 SP 36' Butler, PA Don, You may want to know, if the Cat start battery and the coach batteries are all tied together or are they separated. Mixing batteries may not be a good idea. Our 300 HP 3208 and coach batteries are all tied together in the FC. There is a separate battery for the Onan, with its own dedicated alternator. I believe the Onan battery is also charged by the 3208 alternator and the 110V charger, using blocking diodes. I am a little unsure of this last statement. I have not had any trouble here, so I have not explored the wireing schematics. Bill 88 FC [Non-text portions of this message have been removed] |
11-30-2005, 12:28
Starting Batteries
Don,
You may want to know, if the Cat start battery and the coach batteries are all tied together or are they separated. Mixing batteries may not be a good idea. Our 300 HP 3208 and coach batteries are all tied together in the FC. There is a separate battery for the Onan, with its own dedicated alternator. I believe the Onan battery is also charged by the 3208 alternator and the 110V charger, using blocking diodes. I am a little unsure of this last statement. I have not had any trouble here, so I have not explored the wireing schematics. Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, dspithaler@a... wrote: > > I was wandering what starting batteries was good for a 3208 300 HP TA. When > I got mine it had deep cycle batteries in the engine compartment. They were > 675 CCA . When I went to get new batteries today I looked at starting > batteries that were 875 CCA .He said they were the same as they put in a Ford Truck > with a Diesel engine. I looked at my truck & sure enough that is what it had > in it. He said Interstate did make a commercial battery that big trucks use. > Now I am confused as what to get. Any opinion on what is the best CCA ? What > does everyone else use. > Don > 89 SP 36' > Butler, PA > > > [Non-text portions of this message have been removed] > |
11-30-2005, 13:11
Starting Batteries
---Ernie:
I dont think the SP has room for four trojans in the back like the PT does. My SP has two Interstates ..do not know theCCA but would recommend highest. My Interstate batteries are two yrs old and fine.. Even after six months disconnected...BAM..right up! Wish Naty & I could attend the Texas rally..hello to everyone who might remember us...Maybe we can get one in next year as we plan to travel back East sometime after the WSOP in July. I just love Nebraska in July..just kidding!. Regards, Hank Hannigan & Naty 90SP36 dry in Vegas & we r wet in Austra In WanderlodgeForum@yahoogroups.com, erniecarpet@a... wrote: > > Don, I just installed 4 new Trojan's in my coach. My other batteries lasted a > little over 3 years. Ernie-83pt40 in Texas > > > [Non-text portions of this message have been removed] > |
11-30-2005, 13:14
Starting Batteries
Don,
I have a 86 pt 40 the batteries that came with the bird sucked, the owner had all kinds of problems, i lived on a boat for 7 years, deep cell is the way to go. I went with interstate their strongest deep cell in my case the gen set has it's own battery that is hi crank out put. I like interstate is because the price is ok the warrenty is great & they all country wide, I have had no problems in a year of service, trojens are good also guy |
11-30-2005, 13:17
Starting Batteries
--- Ernie:
Just one more thing & then we will be off to chasing ROOS. U will love the Trojan Batteries.........I have two six volt T-105's on motorhome under here(Aus) and they are five years old and are like new....connected to two solar panels and stay around 13.8. Regards, Hank 90Sp36 In WanderlodgeForum@yahoogroups.com, erniecarpet@a... wrote: > > Don, I just installed 4 new Trojan's in my coach. My other batteries lasted a > little over 3 years. Ernie-83pt40 in Texas > > > [Non-text portions of this message have been removed] > |
11-30-2005, 13:18
Starting Batteries
battery note
on my interstate batteries to make them fit I had to cut the handles off, which I have in writing it doesn't void the warrenty if the casing is not cut. I just used a sawsall fit perfit guy smalley 86 pt40 |
