Need a mounting base for '81 FC Ramco mirror
12-07-2005, 08:08
I pulled my drivers side mirror off to polish it, dropped it and
cracked (off) the part that attaches to the bus. Anyone have an old
parts mirror around or a complete drivers side one that they would be
willing to part with?
Thanks,
Tim Hannink
Winter Park, FL
1981 FC-33SB
12-07-2005, 08:37
Original 3-bolt?
- Jeff Miller
in Holland, MI
--- In WanderlodgeForum@yahoogroups.com, "Tim Hannink"
> Thanks,
> Tim Hannink
> Winter Park, FL
> 1981 FC-33SB
12-07-2005, 09:17
No, its a 4-bolt base 8"w x 4"h. Definately look original, I didn't
see any other holes under the base.
Thanks
Tim
> Original 3-bolt?
> - Jeff Miller
> in Holland, MI
old
would be
> > Thanks,
> > Tim Hannink
> > Winter Park, FL
> > 1981 FC-33SB
12-07-2005, 09:58
If all else fails:
1-800-321-4819
Is it same 4 hole mounting as found on latest models?
Think it may be called 7.25 Mount? But current model
seems to have smaller bolt holes than my 2000LXi
model, and use latest uses phillips, rather than the
allen wrench, driven stainless bolts.
John Suter
> dropped it and
> Anyone have an old
> that they would be
> Thanks,
> Tim Hannink
> Winter Park, FL
> 1981 FC-33SB
__________________________________________
Yahoo! DSL – Something to write home about.
Just $16.99/mo. or less.
dsl.yahoo.com
12-07-2005, 10:03
Tim,
If all else fails, check with http://www.Ramco-Eng.com or 1-800-321-4819 and they
are pretty good about parts availability. I talked to them once when I was
making a spacer for their mirror.
Bob Johannesen
91WLWB40 "Seldom Blue"
Argyle, Texas.
Thanks
Tim
> Original 3-bolt?
> - Jeff Miller
> in Holland, MI
old
would be
> > Thanks,
> > Tim Hannink
> > Winter Park, FL
> > 1981 FC-33SB
SPONSORED LINKS
Recreational vehicles Wanderlodge Automotive maintenance
Recreational vehicle dealer Used recreational vehicles Automotive radiators
YAHOO! GROUPS LINKS
Visit your group "WanderlodgeForum" on the web.
To unsubscribe from this group, send an email to:
Yahoo! Personals
Let fate take it's course directly to your email.
See who's waiting for you Yahoo! Personals
12-07-2005, 11:17
Hey Tim, I happen to be going thru the "mirror issue" as we speak on
our 86 FC. I purchased a new set of mirrors for RUBY and the hole
pattern is very close and we all know "close is only good for
grenades and ..The hole pattern on the present base as on John's
coach is just about 1/4 inch off...just enough.
The mount on our coach was made in Canada by a company called Canada
Brass. That company has either gone out of business or quit making
mirrors...mute point there are no longer any molds of our mirror
bases.
I have been working with RAMCO for some time and even sent them my
bases. It appears that at one time mirrors bases were drilled/counter
sunk simply by "eye balling" it. Thus making each installation
unique. Heck the driver and passenger are different on our's. Bill
Reed is handleing this adventure for me and we are getting close to
getting the right dimensions after sending bases back and forth
several times. He has been nothing less than a great guy..most mfg
would have given up and sent my money back. We even joked that this
was taking him back some 30yrs when he was first starting out and
encountering all these problems. I am working with my second casting
and just sent it back to them for re-drilling to try to get it to
fit.
My suggestion would be..if you can't find a replacement take the
existing to a welder or a metal shop and see if they could weld it
and polish it to match. If you contact Remco try to reach Bill to
discuss this with him, the others may say it will fit ..but it won't.
Best of Luck
Scott B
86FC35 "RUBY"
Murrells Inlet SC (leavin in 10 days for Ok, Co, NM can't wait)
--- In WanderlodgeForum@yahoogroups.com, John Suter
> If all else fails:
> 1-800-321-4819
> John Suter
> > dropped it and
> > Anyone have an old
> > that they would be
> > Thanks,
> > Tim Hannink
> > Winter Park, FL
> > 1981 FC-33SB
> dsl.yahoo.com
12-07-2005, 11:53
Well I have a pair of 3-bolt brackets ('77 through mid-'83), but gave
away my last 4-bolt. Sorry.
If they truly are Ramco, they are later mirrors. 4-bolt would
indicate so also. Fortunately Ramco is alive and well making mirrors
so you will likely be able to buy new if you can't find used.
- Jeff Miller
in Holland, MI
> Thanks
> Tim
> > Original 3-bolt?
> > - Jeff Miller
> > in Holland, MI
> old
> would be
> > > Thanks,
> > > Tim Hannink
> > > Winter Park, FL
> > > 1981 FC-33SB
12-07-2005, 13:48
Here is a photo of an '82 FC-35 with the same set of mirrors that
are on my '81:
<http://www.vintagebirds.com/images/baird1.jpg>
They even have the extra aluminum plate mounted to the top of the
mirror for a stick-on convex mirror.
I went out and looked over my mirror for a manufacturer or model
number but only found the word 'JAPAN' stamped on the base (on the
piece that broke off, imagine that). I would guess they are probably
not Ramcos.
There was also a set of aluminum wedges underneath each end of the
mounting base to make them fit flush to the body; the mirrors
evidently had less curve than the corner of the coach has.
Thanks,
Tim Hannink
1981 FC-33SB
Winter Park, FL
gave
mirrors
> - Jeff Miller
> in Holland, MI
didn't
> > Thanks
> > Tim
> > wrote:
> > > Original 3-bolt?
> > > - Jeff Miller
> > > in Holland, MI
> and
an
> > old
> > would be
> > > > Thanks,
> > > > Tim Hannink
> > > > Winter Park, FL
> > > > 1981 FC-33SB
12-07-2005, 14:04
On the other hand get a piece of stainless rolled to the correct radiius and use
it kind of like a washer under the replacement mirror to cover the holes that
don't fit the replacement base, if well done it will look just fine. Them
mirror bases are all over the map, welding and redrilling the bases is way to
much like work.
Mike Hohnstein
Sent: Wednesday, December 07, 2005 5:17 PM
Subject: [WanderlodgeForum] Re: Need a mounting base for '81 FC Ramco mirror
bases.
fit.
Best of Luck
Scott B
86FC35 "RUBY"
> If all else fails:
> 1-800-321-4819
> John Suter
> > dropped it and
> > Anyone have an old
> > that they would be
> > Thanks,
> > Tim Hannink
> > Winter Park, FL
> > 1981 FC-33SB
> Yahoo! DSL - Something to write home about.
> dsl.yahoo.com
SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance
radiators
YAHOO! GROUPS LINKS
12-07-2005, 14:17
Those are the late '83 FC mirrors / mounts. I can't remember the
vendor.
They're around, occasionally one of us removes them to install power
Ramcos, keep asking around.
- Jeff Miller
in Holland, MI
> are on my '81:
probably
> not Ramcos.
> Thanks,
> Tim Hannink
> 1981 FC-33SB
> Winter Park, FL
