How can you tell if a battery is about to kick the bucket?
12-14-2005, 05:47
I have two identical buses. One bus has steady voltage almost
always and the other varies from about 14.5 volts to 12.5 volts. I can't figure out where the voltage draw is going. It almost acts like some as large as an electric cooling fan is coming on, but these buses have hydraulic fans. And the other bus never shows syptoms like this. So I'm wondering...is one of my batteries about to die? I've heard the lead plates inside can "almost" touch, and cause problems since they're almost a dead cell, so is there any way I can test these batteries or do I just have to wait 'til they drop a cell? Steve Two '98 Q-buses |
12-14-2005, 06:49
The best way to test batteries is to charge them up fully and measure the
voltage, preferable with a good digital multimeter. (Be sure to check the water first) Then disconnect them and wait 6 hours or better yet 24 hours, then measure the voltage again. If the battery is good it should be at 12.6 or 12.7. A good source for this info is [url]www.amplepower.com<[/url]http://www.amplepower.com/> or the Maintenance manual available from [url]www.trojanbattery.com<[/url]http://www.trojanbattery.com/>. Either is a good source for the info even if you have some other battery. Dick Hayden - '87 PT 38 - Lk Stevens, WA ----- Original Message ----- From: transit360 To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, December 14, 2005 9:47 AM Subject: [WanderlodgeForum] How can you tell if a battery is about to kick the bucket? I have two identical buses. One bus has steady voltage almost always and the other varies from about 14.5 volts to 12.5 volts. I can't figure out where the voltage draw is going. It almost acts like some as large as an electric cooling fan is coming on, but these buses have hydraulic fans. And the other bus never shows syptoms like this. So I'm wondering...is one of my batteries about to die? I've heard the lead plates inside can "almost" touch, and cause problems since they're almost a dead cell, so is there any way I can test these batteries or do I just have to wait 'til they drop a cell? Steve Two '98 Q-buses ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum<http://groups.yahoo.com/group/WanderlodgeForum>" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service<http://docs.yahoo.com/info/terms/>. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
12-14-2005, 06:50
get a Load test done on the battery that will give you an indication
of the health of the battery Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "transit360" > > I have two identical buses. One bus has steady voltage almost > always and the other varies from about 14.5 volts to 12.5 volts. I > can't figure out where the voltage draw is going. It almost acts like > some as large as an electric cooling fan is coming on, but these buses > have hydraulic fans. And the other bus never shows syptoms like this. > So I'm wondering...is one of my batteries about to die? I've > heard the lead plates inside can "almost" touch, and cause problems > since they're almost a dead cell, so is there any way I can test these > batteries or do I just have to wait 'til they drop a cell? > > Steve > Two '98 Q-buses > |
12-14-2005, 09:20
Hi Steve,
> I have two identical buses. One bus has > steady voltage almost > always and the other varies from about 14.5 volts to > 12.5 volts. A fully-charged, good, 12v battery "at rest" will generally indicate 12.65V. The inverter/charger can be "set" (for the type of coach/house battery - Gel, AGM, Lead-acid) to absorption/acceptance charge at 14.1v or 14.3v, and to float about 13.1-13.5V. Is it possible your 14.5 and 12.5 readings are the result of checking when the charger is activated and not activated (or immediately after charging but not really "at rest" some several hours later)? > I > can't figure out where the voltage draw is going. It > almost acts like > some as large as an electric cooling fan is coming > on, but these buses > have hydraulic fans. And the other bus never shows > syptoms like this. As others have already suggested, the only real way is to "load test" each individual battery, not the entire bank. A load test device can be characterized as the inverse operation of a charger - the charger brings the battery up to say 14.3, stops its charging, and the battery "rests" back down towards 12.65. The load tester virtually "dead shorts" the battery momentarily down to say 11v, stops the "short," and measures the immediate voltage rise back towards 12.65 and the time (in seconds) it takes to return. Oversimplified, a poor battery sluggishly, or never, returns, while a good battery "springs" quickly back toward the initial voltage. A good load-tester actually performs a more sophisticated set of tests; but you get the general idea. > So I'm wondering...is one of my batteries > about to die? I've > heard the lead plates inside can "almost" touch, and > cause problems > since they're almost a dead cell, so is there any > way I can test these > batteries or do I just have to wait 'til they drop a > cell? The best way to get the most life cycles from any battery is to "maintain" them. In general, maintain lead/acid batteries by keeping the water/acid level above the top of the plates and keep them well charged. For AGM and Gel, charge them relatively slowly and often. AGM/Gel lives are measured in terms of charge/discharge cycles - e.g. the less-deep their discharge before their re-charge, the more times they can be "cycled" before their life is exhausted. John Suter __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com |
