Stud Piloted vs Hub Piloted
12-15-2005, 21:51
I'm searching for 8.25 X 22.5 rims for my 1979 FC 35. So far I've found many
more hub piloted instead of the stud piloted rims. Is much modification
required to use the hub piloted rims? I'm guessing that I'd need different
hubs. Henry@... McAllen, Tx 1979 FC 35.
12-16-2005, 01:22
Henry
Call the tech centre at accuride or alcoa and they will able to give
some part numbers for Stud piloted rims
Stephen 77fc35
--- In WanderlodgeForum@yahoogroups.com, "Henry Claeys"
found many more hub piloted instead of the stud piloted rims. Is much
modification required to use the hub piloted rims? I'm guessing that
I'd need different hubs. Henry@H... McAllen, Tx 1979 FC 35.
12-16-2005, 02:12
Henry,
Check with Billy Moran at T.C.I. Tires in Oklahoma City at 800-322-2710. He
had an a connection for wheels. I bought two used ones from him and got a good
deal, but I had to polish them. Tire shops at truck stops usually have someone
near who polishes wheels.
Bob & Judy Johannesen
91WLWB40 "Seldom Blue"
Argyle, Texas
FMCA #72567, WL #1986, Vintage Birds # 345
Stephen Birtles wrote:
Henry
Stephen 77fc35
SPONSORED LINKS
Recreational vehicles Wanderlodge Automotive maintenance
Recreational vehicle dealer Used recreational vehicles Automotive radiators
YAHOO! GROUPS LINKS
Visit your group "WanderlodgeForum" on the web.
To unsubscribe from this group, send an email to:
Do You Yahoo!?
http://mail.yahoo.com
12-16-2005, 02:35
New hubs, new brake drums, new studs/nuts, new center-caps.
The cost would be too much to be worth it IMO, you can buy stud-piloted
wheels new.
- Jeff Miller
in Holland, MI
12-16-2005, 03:00
Am I the only one who doesen't know what hub "piloted and stud piloted" means?
At the risk of embarrassing myself, what do those terms mean?
Dick Hayden - '87 PT 38 - Lk. Stevens, WA
Sent: Friday, December 16, 2005 6:35 AM
Subject: [WanderlodgeForum] Re: Stud Piloted vs Hub Piloted
wheels new.
- Jeff Miller
in Holland, MI
--- In
"Henry Claeys" ...>
YAHOO! GROUPS LINKS
a.. Visit your group
"WanderlodgeForum<http://groups.yahoo.com/group/WanderlodgeForum>" on the web.
WanderlodgeForum-unsubscribe@yahoogroups.com @yahoogroups.com?subject=Unsubscribe>
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service<http://docs.yahoo.com/info/terms/>.
12-16-2005, 03:10
I had to learn the lesson after I purchased a set of 6 brush finish alloys.
Time came to mount the new tires, I noticed there was no divot around the stud
holes to receive the lug nuts. The dealer got me the right ones no problem. He
did say the stud pilot stuff is getting harder to supply. Don't know if that
was BS or not.
Mike Hohnstein
Sent: Friday, December 16, 2005 9:00 AM
Subject: Re: [WanderlodgeForum] Re: Stud Piloted vs Hub Piloted
To:
wheels new.
- Jeff Miller
in Holland, MI
--- In
"Henry Claeys" ...>
YAHOO! GROUPS LINKS
YAHOO! GROUPS LINKS
12-16-2005, 03:58
Hi Dick,
I'll try to explain.
Stud piloted...the wheel centers on the studs. The wheel stud holes and
lug nuts are tapered. The tapers center the wheel when the lug nuts are
tightened.
Hub piloted...the wheel is centered on the hub. The wheel stud holes and
lug nuts are not tapered.
Someone will chime in if my explanation needs refinement.
> piloted" means? At the risk of embarrassing myself, what do those
> terms mean?
> From: Jeff Miller
> To:
> wheels new.
> - Jeff Miller
> in Holland, MI
> --- In
> "Henry Claeys" ...>
> YAHOO! GROUPS LINKS
> the web.
> YAHOO! GROUPS LINKS
> * Visit your group "WanderlodgeForum
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service <http://docs.yahoo.com/info/terms/>.
12-16-2005, 04:07
follow these url for explanations of hub piloted and sud pilot wheel
would have posted it but they contain pictures and the yahooligans
would have deleted them
stud pilot
http://www.alcoa.com/alcoawheels/north_a...?info\
_page_id=528&prod_id=0&cat_id=893
hub pilot
_page_id=527&prod_id=0&cat_id=893
Stephen 77fc35
In WanderlodgeForum@yahoogroups.com, "Richard Hayden"
terms mean?
> From: Jeff Miller
> To:
stud-piloted
> wheels new.
> - Jeff Miller
> in Holland, MI
> --- In
"Henry Claeys" ...>
much
> YAHOO! GROUPS LINKS
the web.
12-16-2005, 04:41
Thanks all. I quess I've always known that but have not heard the terms.
Dick Hayden '87 PT 38 - L:k Stevens, WA - very cold and hi humidity today
Sent: Friday, December 16, 2005 7:58 AM
Hi Dick,
tightened.
> terms mean?
> From: Jeff Miller
> To:
> wheels new.
> - Jeff Miller
> in Holland, MI
> --- In
> "Henry Claeys" ...>
> YAHOO! GROUPS LINKS
"WanderlodgeForum<http://groups.yahoo.com/group/WanderlodgeForum<http://groups.y\
ahoo.com/group/WanderlodgeForum>>" on
> the web.
Service<http://docs.yahoo.com/info/terms/<http://docs.yahoo.com/info/terms/>>.
> YAHOO! GROUPS LINKS
<http://groups.yahoo.com/group/WanderlodgeForum<http://groups.yahoo.com/group/Wa\
nderlodgeForum>>" on the web.
> Service
YAHOO! GROUPS LINKS
12-16-2005, 05:16
OK Stephen, I went to the 2 sites. Everything was fine till I saw the 2nd
(outside) wheel illustration on the stud centered system. Is there yet another
system? One with the first wheel nut being threaded inside as well as on the
outside and then a regular nut on the outside wheel. I know that there is as
that what I've always had but it must also have a name or system to define it.
Still confused a little but getting better.
Thanks
Sent: Friday, December 16, 2005 8:07 AM
stud pilot
_page_id=528&prod_id=0&cat_id=893<http://www.alcoa.com/alcoawheels/north_america\
/en/product_info_page_cat.asp?info_page_id=528&prod_id=0&cat_id=893>
hub pilot
_page_id=527&prod_id=0&cat_id=893<http://www.alcoa.com/alcoawheels/north_america\
/en/product_info_page_cat.asp?info_page_id=527&prod_id=0&cat_id=893>
Stephen 77fc35
terms mean?
> From: Jeff Miller
> To:
stud-piloted
> wheels new.
> - Jeff Miller
> in Holland, MI
> --- In
"Henry Claeys" ...>
much
> YAHOO! GROUPS LINKS
the web.
SPONSORED LINKS Recreational
vehicles<http://groups.yahoo.com/gads?t=ms&k=Recr...ation\
al+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea\
ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&sig=DAUkCKkU\
7Dzhn_ObWmSYTw>
Wanderlodge<http://groups.yahoo.com/gads?t=ms&k=Wand...;vehi\
Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj\
9U0JvqYQ> Automotive
maintenance<http://groups.yahoo.com/gads?t=ms&k=Auto...ecrea\
tional+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle\
+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4\
u_5wI8Pmy34cC1O9CxA>
dealer<http://groups.yahoo.com/gads?t=ms&k=Recr...ecrea\
+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_\
XahaeYHfELr6o72IW1A> Used recreational
vehicles<http://groups.yahoo.com/gads?t=ms&k=Used...Recre\
ational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicl\
e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&sig=UGE\
Y5km4L-kXbDI4ZSadEw> Automotive
radiators<http://groups.yahoo.com/gads?t=ms&k=Auto...ation\
ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmI\
SsCWgTnMq_4GlXA>
YAHOO! GROUPS LINKS
