How Thick Is The Roof
12-16-2005, 06:33
I am trying to mount solar panels on the roof of my 1990 WB. My roof
does not have the deck plate. I drilled a whole in the medal roof and
only found foam insulation under it. How do you get anything to hold
on just thin medal.
Thanks for any help
Joe Blankenship
Phoenix,Az
90WB40
12-16-2005, 07:28
--- In WanderlodgeForum@yahoogroups.com, "joedana0502"
>Joe, the sheet metal should be about 1/8" thick. If ss sheet metal
screws will not be stong enough, they make Nutserts, just search the
web, they make lots of different types. marty
> on just thin medal.
> Thanks for any help
> Joe Blankenship
> Phoenix,Az
> 90WB40
12-16-2005, 08:20
Do a search for "rivet nut" at http://www.mcmaster.com/
David Brady
'02 LXi, Smokey, Va
>>on just thin medal.
>>Thanks for any help
>>Joe Blankenship
>>Phoenix,Az
>>90WB40
>Yahoo! Groups Links
No virus found in this outgoing message.
Checked by AVG Free Edition.
Version: 7.1.371 / Virus Database: 267.14.1/204 - Release Date: 12/15/2005
12-16-2005, 08:39
Thanks David it maybe ok with just the sheet medal I was just hopeing
for some plywood too.
Joe Blankenship
Phoenix,Az
90WB40
> David Brady
> '02 LXi, Smokey, Va
> >>on just thin medal.
> >>Thanks for any help
> >>Joe Blankenship
> >>Phoenix,Az
> >>90WB40
> >Yahoo! Groups Links
12/15/2005
12-16-2005, 10:11
Joe depending on the size and weight of your solar panels you may
want to mount the panels on a piece of 3/4" marine plywood (or the
aluminum diamond plate used on some of the other BB) mounted to the
roof of the coach. But I would make sure the screws go into the roof
supports and not just the roof metal. If you contact Benny Collier at
BB he should be able to tell you the exact spacing of the roof
supports and how to locate them. Then I would size the plywood (or
diamond plate)large enough to straddle two or more supports. I would
get some rubber strip material like used on some of the older BB that
acts as an absorber and sealer , and run the strips so they are over
the roof supports(stick then to the roof with contact cement so they
dont move around while you are mounting the plywood) and then lay the
plywood on that and run stainless steel sheet metal screws thru the
plywood and rubber strips into the roof supports. This should give
you the strongest leak free mounting you need. Then mount your solar
panels to the plywood using screws that does not penetrate entirely
thru the plywood. This will ensure you get a leak free mounting surface.
Tom Warner
1982 FC35
Vernon Center,NY
>Joe Blankenship
>Phoenix,Az
>90WB40
> <http://www.mcmaster.com/>http://www.mcmaster.com/
> > David Brady
> > '02 LXi, Smokey, Va
> > > wrote:
> > >>Joe, the
12-16-2005, 11:09
I would second Davids recommendation for rivet nuts. A solid blind
hole fastener system. There are types with rubber collars that will
provide both the strength and the weatherproof seal you need.
I have used on the bus and my boat with good success. They save a
significant amount of cussing where you can not easily reach the back
side of an installation.
frank w.
woodbridge, va.
85fc33
> on just thin medal.
> Thanks for any help
> Joe Blankenship
> Phoenix,Az
> 90WB40
12-16-2005, 14:36
Joe, If you have any concern, make a blank true radius plate for an
interface between the lodge and the solar panel. finish it with good
paint and use the 3-m double sided tape to hold it down then sheet
metal screw it also.
Greg
--- In WanderlodgeForum@yahoogroups.com, "fwernlein"
will
back
> frank w.
> woodbridge, va.
> 85fc33
roof
hold
> > on just thin medal.
> > Thanks for any help
> > Joe Blankenship
> > Phoenix,Az
> > 90WB40
12-17-2005, 03:32
Do you have the rails on the roof?
Bob Lawrence
84 PT36
Tacoma, Wa.
> on just thin medal.
> Thanks for any help
> Joe Blankenship
> Phoenix,Az
> 90WB40
12-17-2005, 04:00
You will probably find that the roof is strong enough for the panels
the regular armour that is placed over the roof in MOST cases is just
screwed to the roof and well sealed they are not aligned with the
inside roof ribs
The method to to attach is to use z shaped Brackets and use the
factory frame on the panels use short brackets so air cannot get
underneath the panels and create lift when drivng placing strain on
the panels make sure holes are well sealed to prevent water intrusion
and you should have no problems wirng would run down througha vent or
if you choose a seperate hole with a clamshell cover over a bulkhead
feedthru again to stop the water intrusion. if you have any questions
drop me a line
Stephen 77fc35 been there done that no pictures but got the tee shirt
--- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence"
> Bob Lawrence
> 84 PT36
> Tacoma, Wa.
> > on just thin medal.
> > Thanks for any help
> > Joe Blankenship
> > Phoenix,Az
> > 90WB40
12-17-2005, 04:25
Thanks Stephen what you described is what I had in mind of doing.
The 1/8" sheet medal just scared me.
Thanks again
Joe Blankenship
Phoenix,Az
90WB40
> inside roof ribs
> drop me a line
> > Bob Lawrence
> > 84 PT36
> > Tacoma, Wa.
roof and
> > > on just thin medal.
> > > Thanks for any help
> > > Joe Blankenship
> > > Phoenix,Az
> > > 90WB40
