Hydro-Hot systems
12-17-2005, 18:22
Hydro-Hot systems
As part of the refurb on my '84 PT40WL, I am considering removing
all the propane heat, refrigerator, hot water heater and cooktop
systems along with the electric heaters throughout the coach and
installing the hydro-Hot system.
This would free up some space, remove a lot of weight and electric
circuits as well as provide updated heat for the coach.
The deeper I get into this project the more I realize the massive
nature of the Blue Bird coach. This baby is like a tank.
Everything is super-duty in design and function. I had wanted one
since I was a young pup and the local millionaire brought one out to
the airport where I was washing planes to pay for flight lessons.
What a neat motorcoach.
What are your opinions on this conversion. The Hydro-Hot is about
$5,500. As a retired ATP and long time A&P and IA I have dertainly
have the time, the tools, the shop and the ability to do the
conversion. Just looking for wiser heads to input their thoughts on
this. Thanks,
Roger Sadler
Little Rock, '84PT40WL
12-17-2005, 20:57
Hydro-Hot systems
That sounds like a project. What if--- the Hydro hot fails- in real cold
weather? Ernie-83pt40 in texas- all heaters work- not at one time
12-18-2005, 01:34
Hydro-Hot systems
Hi Roger,
> and cooktop
> the coach and
WOW that is a mouthful. In our (wife and I)
opinion, one of the best upgrades BB made in late 90's
was to Aqua-Hot system; however, it appears to require
regular annual attention to diesel burner section and
every 2-3 yr replacement of the mixing system "guts;"
shouldn't be a problem for you mechanically, but a
cost consideration.
How about considering the possibility of leaving the
refrig, cooktop, and elect heaters as is?
Understand the primary heating for the
Aqua-hot/Hydro-hot is electric and the diesel only
fires when the elect can't maintain the required
temps. Second, understand the diesel burner is only
50,000BTU so sufficient hot water (for showering) is
very dependent upon the incoming water temp and its
required temp rise; AND that same burner has to
generate the heat for coach heating. E.g. Even with
cool, not cold, outside temps, you will not get a long
hot shower without shutting down the coach heat
temporarily. Therefore, you will "want" to keep the
elect boost heaters; even the newer models with their
double insulated glass, have at least 2 to augment.
> weight and electric
> coach.
Doubt you'll net any weight savings and don't recall
size of the propane tank in your model, but with
refrig backup and cooktop, would likely only need a
40gal or so.
We'd also have "to sit a spell and chat" before I'd
be convinced about "removing a lot of electric
circuits" - the numerous branches and loops for at
least 3 zones are likely to require more circuits, not
fewer.
> realize the massive
> tank.
That's one reason we fools keep on buyin' 'em.
> Hydro-Hot is about
> $5,500.
Probably can't cost justify, but it would give you a
project to be proud of having added, and some
"bragging rights" among the rest of us.
> have dertainly
> to do the
> their thoughts on
> this. Thanks,
Boy, that's unfairly puttin' on the pressure.
John Suter, (ret: CFII etc.)
2000LXi and prior
Do You Yahoo!?
http://mail.yahoo.com
12-18-2005, 03:39
Hydro-Hot systems
One question: How old are you and what's your life expentency? Blair in
Oregon
Sent: Saturday, December 17, 2005 10:22 PM
Subject: [WanderlodgeForum] Hydro-Hot systems
this. Thanks,
Roger Sadler
SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance
Recreational vehicle dealer Used recreational vehicles Automotive
radiators
YAHOO! GROUPS LINKS
12-18-2005, 04:36
Hydro-Hot systems
Your chassis heat system is the basis of a hot water system, just add a diesel
boiler and replace fans with those new fangled "computer" fans and you have a
usable system.
I have used the Pro heat diesel boiler in my custom toter home and my FC. I
would not abandon the electric or LP heaters myself as I like the back up
systems.
Pro Heat has a web site, I paid $1200 for the X 45 that is the "bus" application
heater. I shopped the Hydrohot and Webasto products, old sayin' Bucks or BS. I
don't mind a little BS.
In the FC, we use the electric heat most of the time as we like to stay at
commercial camp grounds. Dry camping is getting costly if ones wants to use
diesel to heat the interior.
I really like the fact that I never have to start my engine cold, one of the
best features of the boiler. It takes about a half hour from cold to showing
movement on the heat gage.
The FC is in dry dock for the next 5 or 6 months, the chassis heat is on the
agenda for serious flushing and a look at the routing of the supply lines. The
floor plan is rear bath, the water heater is located in the road side rear
corner and the chassis heater for the bath is located under the sink. The bath
heater becomes effective first on a warm up cycle the dinette heater next then
the solon. The solon heater doesn't work well unless the bus is under way, I
need to find what is up with the flow, I think something might have been bolixed
up by a past owner as the rubber hose on the underside has been replaced with
silicon hose. My winter/summer sporlan doesn't shut off the flow to the dinette
heater as an example. I'm confident that the oem chassis heat has the potential
to successfully warm the coach interior when camping, time will tell in my case.
Mike Hohnstein
Germantown, WI
83FC35
Sent: Sunday, December 18, 2005 12:22 AM
this. Thanks,
Roger Sadler
radiators
YAHOO! GROUPS LINKS
12-18-2005, 04:37
Hydro-Hot systems
A good question.
Mike Hohnstein
Sent: Sunday, December 18, 2005 9:39 AM
Subject: Re: [WanderlodgeForum] Hydro-Hot systems
Oregon
this. Thanks,
Roger Sadler
radiators
YAHOO! GROUPS LINKS
YAHOO! GROUPS LINKS
12-18-2005, 04:42
Hydro-Hot systems
Only if you own a bird................I can't even begin to imagine rebuilding a
bird like that.
Morning Mike. We leave tomorrow for the south - warmth - shrimp tacos - Blair
Sent: Sunday, December 18, 2005 8:37 AM
A good question.
Mike Hohnstein
Oregon
this. Thanks,
Roger Sadler
radiators
YAHOO! GROUPS LINKS
Service.
YAHOO! GROUPS LINKS
radiators
YAHOO! GROUPS LINKS
12-18-2005, 05:06
Hydro-Hot systems
Having lived with the Aqua Hot system for over ten years and having
installed one and replaced another, I think I might be able to shed some
light on the subject. For background: I installed the complete system
in the GM bus conversion the wife and I designed and built. That was
installed in the early nineties and worked flawlessly as long as we had
the coach. The '95 BB we now have had an Aqua hot installed when we got
it. Obviously it was left in cold country, unwinterized, and the
domestic water heater coil split. I elected to replace the unit with a
rebuilt unit from Vehicle Systems.
As for annual maintenance: Vehicle Systems recommends that the
"nozzle/filter" be replaced annually. I chose to replace on condition
and found that it needed replacement about every three years. The newer
ones have a filter screen that can be cleaned, reducing cost. I carry a
couple with me just in case. The burner can does need replacing
periodically. I had to replace mine, in the GM bus, once in over ten
years of operation.
My current coach is all electric - no propane. There are pluses and
minuses to either system. I have to either be plugged in or be running
the generator. I really need 50 amp power - not always easy to find. I
have a cheater that I built so that I can use two 30 outlets or a 30 and
a 20 to power the two legs of the coach. Now the wife really loves the
large (19 cu. ft.) refrigerator which has ice and water in the door as
well as being frost free; But it is a power hog. Makes boon docking
difficult as the generator needs to be running most of the time. She is
adapting to using the two burner electric cook top.
I firmly feel that the hydronic heat is much nicer than the forced hot
air. In any newer coach, we will have Hydronic heat. As far as heating
domestic hot water, we have never run out. True, the Aqua Hot has a
larger tank and a few other items that the Hydro Hot does not. Both are
quite adequate and I believe that I would use the Hydro Hot if I were in
your shoes. I would definitely keep the electric toe kick heaters. We
use them exclusively when heating requirements are low, only kicking on
the Aqua Hot when more heat capacity is needed. The electric element in
the Aqua Hot was designed to be used for low heat requirements and as a
backup for the diesel burner. BB hooked theirs up so that both could be
used at the same time. Vehicle Systems originally designed it so that
they would be used separately. (BTW, I had one of the original units.)
You are looking at quite a bit of work which will include the removal of
the propane systems but installation of the hydronic heating system
which will require running water lines for all the heat exchanger
units. I used 1/2" copper but BB used rubber hoses which should be
easier to retrofit.
Cost wise, I think it will cost closer to $8,000 for material by the
time you are done, not counting the refer and cook top. If I can be of
any help, let me know.
George Lowry
'95 WBDA 4203
Spearfish, SD Currently at TTN in Soledad Canyon, CA heading south. Be
in Palm Springs next week, then to the WMHA rally in Indio.
John Suter wrote:
>Hi Roger,
>>and cooktop
>>the coach and
>cost consideration.
>>weight and electric
>>coach.
>40gal or so.
>fewer.
>>realize the massive
>>tank.
>>Hydro-Hot is about
>>$5,500.
>>have dertainly
>>to do the
>>their thoughts on
>>this. Thanks,
>2000LXi and prior
>Do You Yahoo!?
>Yahoo! Groups Links
No virus found in this outgoing message.
Checked by AVG Free Edition.
Version: 7.1.371 / Virus Database: 267.14.1/206 - Release Date: 12/16/2005
12-18-2005, 05:28
Hydro-Hot systems
Watch out for the black ice and fog. I'll stay here in the land of cheese and
burn wood. Bright sunny day, foot of snow and 10degrees above 10 am. I love
it, some doubt my sincerity but cold is good. However don't get locked out of
the house, that's not good.
MH
Sent: Sunday, December 18, 2005 10:42 AM
a bird like that.
A good question.
Mike Hohnstein
in Oregon
this. Thanks,
Roger Sadler
maintenance
Automotive radiators
YAHOO! GROUPS LINKS
Service.
YAHOO! GROUPS LINKS
Service.
radiators
YAHOO! GROUPS LINKS
radiators
YAHOO! GROUPS LINKS
