Chassis Heat
12-18-2005, 09:22
Chassis Heat
Scott- sounds like your sporlan valves are stopped up- thus not letting
coolant circulate. Ernie-83pt40 in texas [Non-text portions of this message have been removed] |
12-18-2005, 13:55
Chassis Heat
I cannot get the chassis heat to work in my FCRB. The water is
circulating to the back, as it heats the hot water heater as it should, but I cannot get water to flow into any of the heat exchangers. I also cannot make the fans blow. I have followed the instructions in the manual (winter/summer switch to winter, chassis heat thermostat on) but no luck. My auxillary pump works, this doesn't help either. Any pointers? Do the chassis heat fans have an override that keeps them from blowing if there is no heat in the heat exchanger? Where is the valve that the winter/summer switch operates? Thanks Scott Forman 82FCRB Memphis |
12-18-2005, 14:24
Chassis Heat
Is the chassis heat thermostat working? Access the heater cores and verify
there is no heat to them. The key needs to be on for the chassis heat to work, verify the sporlan valve behind the curbside headlight is functioning. You might be swinging that drivers side front panel, checking them circuit breakers. I have gotten pretty familar with that area of my bus. Too many crimp connectors and not enough relays. Mike Hohnstein Germantown, WI 83FC35rb ----- Original Message ----- From: Scott Forman To: WanderlodgeForum@yahoogroups.com Sent: Sunday, December 18, 2005 7:55 PM Subject: [WanderlodgeForum] Chassis Heat I cannot get the chassis heat to work in my FCRB. The water is circulating to the back, as it heats the hot water heater as it should, but I cannot get water to flow into any of the heat exchangers. I also cannot make the fans blow. I have followed the instructions in the manual (winter/summer switch to winter, chassis heat thermostat on) but no luck. My auxillary pump works, this doesn't help either. Any pointers? Do the chassis heat fans have an override that keeps them from blowing if there is no heat in the heat exchanger? Where is the valve that the winter/summer switch operates? Thanks Scott Forman 82FCRB Memphis ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
12-18-2005, 14:43
Chassis Heat
Scott,
If your coach is similar to mine you will find two sporlan valves near the hot water heater both of these operate when you switch to "winter". You also must have the engine up to operating temperature to get the engine thermostat to open before you can get any heat at the chassis heaters. Chet Geist 1981 FC33SB, Austin, Texas -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of Scott Forman Sent: Sunday, December 18, 2005 7:56 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Chassis Heat I cannot get the chassis heat to work in my FCRB. The water is circulating to the back, as it heats the hot water heater as it should, but I cannot get water to flow into any of the heat exchangers. I also cannot make the fans blow. I have followed the instructions in the manual (winter/summer switch to winter, chassis heat thermostat on) but no luck. My auxillary pump works, this doesn't help either. Any pointers? Do the chassis heat fans have an override that keeps them from blowing if there is no heat in the heat exchanger? Where is the valve that the winter/summer switch operates? Thanks Scott Forman 82FCRB Memphis ---------------------------------------------------------------------------- -- YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ---------------------------------------------------------------------------- -- [Non-text portions of this message have been removed] |
12-18-2005, 14:49
Chassis Heat
I agree with Ernie, it appears that the electrically
operated "sporlan" valves that diverts water either through the water- heater and then return to the engine, or throught the water-heater and then the chassis heaters are not operating. Most likely this is an electrical issue. It can be a bad circuit- breaker, not sure which ones in an '82 RB, could also be the winter/summer switch or its wiring to the dash, you'll need to do some chasing on this. If the chassis heaters are actually getting warm water but not blowing (slide the sofa out and feel the top of the heater after the engine is good and warm) then it is probably either the circuit- breaker or the thermostat, both of which I've seen go bad many times. The summer/winter switch on the dash is common to both the heat exchanger flow and the blowers. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@r...> wrote: > > I cannot get the chassis heat to work in my FCRB. The water is > circulating to the back, as it heats the hot water heater as it should, > but I cannot get water to flow into any of the heat exchangers. I also > cannot make the fans blow. I have followed the instructions in the > manual (winter/summer switch to winter, chassis heat thermostat on) but > no luck. My auxillary pump works, this doesn't help either. > > Any pointers? Do the chassis heat fans have an override that keeps > them from blowing if there is no heat in the heat exchanger? Where is > the valve that the winter/summer switch operates? > > Thanks > > Scott Forman > 82FCRB > Memphis > |
12-19-2005, 13:23
Chassis Heat
keep me in the loop on this as my 81FCrb is the same and not working
i have problems with the switchs by the driver and have not run it down yet they have something to do with it according to the wirng dia. woody at ft bragg nc go army --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@r...> wrote: > > I cannot get the chassis heat to work in my FCRB. The water is > circulating to the back, as it heats the hot water heater as it should, > but I cannot get water to flow into any of the heat exchangers. I also > cannot make the fans blow. I have followed the instructions in the > manual (winter/summer switch to winter, chassis heat thermostat on) but > no luck. My auxillary pump works, this doesn't help either. > > Any pointers? Do the chassis heat fans have an override that keeps > them from blowing if there is no heat in the heat exchanger? Where is > the valve that the winter/summer switch operates? > > Thanks > > Scott Forman > 82FCRB > Memphis > |
03-23-2006, 20:31
Chassis Heat
I wish to thank Mike Hohenstein, Kevin, in Yorba Linda, and Jeff Miller,
for helping me out with my chassis heat question. Henry@... in Austin, Tx, 1979 FC 35. |
User(s) browsing this thread: 6 Guest(s)
