Tank Odor
12-20-2005, 12:25
Tank Odor
The Bird sometimes has tank odor, and other times no tank odor inside of
the coach. Before departing, I always make sure the kitchen sink and shower p-traps have water in them as well as a deodorizer treatment, the toilet has water in it above the flapper level, and the roof vents are closed. Seems strange that sometimes the odor is present and other times no odor. What else should I check for? -- Curt Sprenger 1987 PT38, Anaheim Hills, Calif. |
12-20-2005, 12:40
Tank Odor
Check for Hydrogen Sulfide (rotten egg smell) from a bad battery. After the
coach sits, the smell may be in accumulating in the battery compartment, if so, look for bad battery. Happened to me and to another BB owner I know. Roger Webb 91 WLWB Cedar Rapids, IA --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger wrote: > > The Bird sometimes has tank odor, and other times no tank odor inside of > the coach. Before departing, I always make sure the kitchen sink and > shower p-traps have water in them as well as a deodorizer treatment, the > toilet has water in it above the flapper level, and the roof vents are > closed. Seems strange that sometimes the odor is present and other times > no odor. What else should I check for? > > -- > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > |
12-20-2005, 13:08
Tank Odor
Roger,
Thank you for your suggestion. I topped up the batteries a month ago and no smell at the batteries at that time. But I will be sure to check. How does that smell get inside of the coach? Curt Sprenger 1987 PT38, Anaheim Hills, Calif. rogerwwebb wrote: > > Check for Hydrogen Sulfide (rotten egg smell) from a bad battery. > After the coach sits, the smell may be in accumulating in the battery > compartment, if so, look for bad battery. > > Happened to me and to another BB owner I know. > > Roger Webb > > 91 WLWB > > Cedar Rapids, IA > > > --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > > > > The Bird sometimes has tank odor, and other times no tank odor > inside of > > the coach. Before departing, I always make sure the kitchen sink and > > shower p-traps have water in them as well as a deodorizer treatment, > the > > toilet has water in it above the flapper level, and the roof vents are > > closed. Seems strange that sometimes the odor is present and other > times > > no odor. What else should I check for? > > > > -- > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > > > > > > > SPONSORED LINKS > Recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Recr...vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_O\ bWmSYTw> > Wanderlodge > <http://groups.yahoo.com/gads?t=ms&k=Wand...2=Wan\ derlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recrea\ tional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ> > Automotive maintenance > <http://groups.yahoo.com/gads?t=ms&k=Auto...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34\ cC1O9CxA> > > Recreational vehicle dealer > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeY\ HfELr6o72IW1A> > Used recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Used...onal+\ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer\ &w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-\ kXbDI4ZSadEw> > Automotive radiators > <http://groups.yahoo.com/gads?t=ms&k=Auto...ehicl\ es&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Us\ ed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq\ _4GlXA> > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > |
12-20-2005, 14:46
Tank Odor
I don't know how it got inside the coach, however, my coach is not air tight.
Hydrogen Sulfide is a strong oder often found in some well water and in sewer gases. It will be quite obvious if it is coming from a battery as soon as you open the compartment and stick your nose in. If you don't smell it then, it probably isn't the battery. Roger Webb 91WBWL Cedar Rapids, IA --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger wrote: > > The Bird sometimes has tank odor, and other times no tank odor inside of > the coach. Before departing, I always make sure the kitchen sink and > shower p-traps have water in them as well as a deodorizer treatment, the > toilet has water in it above the flapper level, and the roof vents are > closed. Seems strange that sometimes the odor is present and other times > no odor. What else should I check for? > > -- > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > |
12-20-2005, 14:58
Tank Odor
Ok, thanks, good to know. I'll open the side cover near the batteries. I
usually open the rear cover first so maybe I'm allowing a cross breeze to move the smell out of the compartment. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. rogerwwebb wrote: > > I don't know how it got inside the coach, however, my coach is not air > tight. Hydrogen Sulfide is a strong oder often found in some well > water and in sewer gases. It will be quite obvious if it is coming > from a battery as soon as you open the compartment and stick your nose > in. If you don't smell it then, it probably isn't the battery. > > Roger Webb > > 91WBWL > > Cedar Rapids, IA > > > > --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > > > > The Bird sometimes has tank odor, and other times no tank odor > inside of > > the coach. Before departing, I always make sure the kitchen sink and > > shower p-traps have water in them as well as a deodorizer treatment, > the > > toilet has water in it above the flapper level, and the roof vents are > > closed. Seems strange that sometimes the odor is present and other > times > > no odor. What else should I check for? > > > > -- > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > > > > > > > SPONSORED LINKS > Recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Recr...vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_O\ bWmSYTw> > Wanderlodge > <http://groups.yahoo.com/gads?t=ms&k=Wand...2=Wan\ derlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recrea\ tional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ> > Automotive maintenance > <http://groups.yahoo.com/gads?t=ms&k=Auto...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34\ cC1O9CxA> > > Recreational vehicle dealer > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeY\ HfELr6o72IW1A> > Used recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Used...onal+\ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer\ &w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-\ kXbDI4ZSadEw> > Automotive radiators > <http://groups.yahoo.com/gads?t=ms&k=Auto...ehicl\ es&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Us\ ed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq\ _4GlXA> > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > |
12-20-2005, 14:59
Tank Odor
inside of the coach. Curt, I don't know if BB uses the valves, but Newmar has valves in the bathroom, under the sink that can stick open and allow the holding tank odor in the rig. Here are some posts reagrding this valve from the Newmarowners forum on Yahoo. Steve Harrie St. George, UT Subject: Re: Strange White Undersink Valve in Water Lines/Smells >The valve is behind the drawers, located quite high, and installed between two lines which have the same appearance as water lines. There are two pipes and there is a directional flow arrow on one valve fitting. The gravity weighted one-way valve inside appears to restrict flow to the bottom fitting, but not the side fitting. The side fitting appears to be vented to open air through the top of the valve. I also noticed that the valve has some markings: 110 degrees F & 125 PSI. What you are calling the very strange looking valve is the anti back flow valve in the line that goes to your black water tank flush system. It keeps stuff from backing up to the connector where you attach your hose to flush your black water tank. I have replaced my valve twice. If it sticks open you get a terrific odor. Check message #30212 for a solution which has worked for me. I too have been plagued by smells at one time or another. The anti-siphon valve under the sink in the bathroom is for the black tank rinse (I believe). I have checked and rechecked this valve. I have removed it, bypassed it, and replaced it. All with no positive results. I have determined that somehow I have a leak or improper seal in one of the tanks that causes fumes to occur in the basement. When I turn on the Fantastic Fan in the bath area. I can feel air rushing in from under the sink cabinet. This air coming in is smelly! I think eventually I will foam the area around the hoses and pipes that penetrate the flooring and this will keep the smell in the basement. The next step is to find the exact source of the smell. There is a one way vent under the sink, which is called a vacumn breaker, I believe. It breaks the vacumn caused by water rushing out of the sink and allows the sink trap to retain water, for odor control purposes. I tried taping the vent shut, and filling the trap with water prior to moving, but that didn't seem to help. 1. The valve under the lavy sink is for the black tank. 2. You have a mechanical vent by each sink drain line. It unscrews and is 1 1/2 inch diameter. These can be covered or wrapped with a ziplock bag and secured with a rubber band. 3. The location of the roof vent does not make a difference. The refer is sealed from the inside. 4 If you have any roof vent open while traveling and one of these vents is close to the gray roof vent you may have pulled in the odor since you have a vacumm in any RV while traveling. Unless you open some windows and equalize the pressure. Make sure the washer dryer prep drain pipe has water in the P-trap. Put water down the tube and then seal to top. Brent Subject: DSDP '01--Odor under bathroom vanity The drain line for the washer and sink(that is at the bottom of the cabinet) has a "valve" that seems designed to allow air to enter the line to expedite drainage when the washer empties. Air enters the line through a rubber diaphram which I think is designed to allow airflow in only one direction. The problem is that we seem to be getting gray water odors that that backup into the vanity. I was in a location where I couldn't easily get another valve, and I managed to get mine to work again. The valve is a combination anti-siphon air inlet and one-way sewer flush water valve. The one-way valve can get stuck if you run water quickly into the valve. We did this when we flushed our black tank using one of the campground water valves that has a handle you lift (they're used in areas that freeze). Lifting the handle instantly turns the water on, and initially air is in the hose, and the air can travel quickly through the small Newmar valve. When the water hits the valve there is a lot of momentum, and the one-way water part of the valve can travel further than it is designed to travel, and get stuck. After we got ours unstuck, I've only turned the sewer flush water on slowly, and haven't had a problem since. -- Daryl Daughters I think the valve is called a "vacuum break valve". Lets air in but not out when it is not stuck or broken. Lowes, Home Depot would have them. Works on the same principle as a straw full of water with you finger over the end. The water fill not drain out until you remove your finger, thus breaking the vacuum. Also, before I blamed the under sink vacuum valve I would go to the roof and check the air vent. The roof air vent may be blocked thus forcing gasses out the vacuum breaker valve. You can just take a water hose on the roof and run water down the air vent. It goes directly in the holding tank. Tom Nagy Does the sewage odor only appear after you have driven down the road for several hour? Does it abate after you have sat in a campground for several days? If you answer yes to the above questions it is most likely the anti-siphon/backflow prevention valve in the black tank cleaning system. Usually you will have to remove the drawers to see this valve. There are two valves under the sink. The first one that you mentioned is an anti-siphon valve that, usually sits on top of a short riser, on the drain line from the sink. You can isolate this valve by either removing it and replacing it with a solid cap or the easier and cheaper method is to wrap it in Saran Wrap and either rubber band or tape the bottom around the riser pipe. If this does not eliminate the problem then most likely it is the anti-siphon/backflow prevention valve in the black tank cleaning system. I don't know which anti-siphon/backflow prevention valve that you have in the black tank cleaning system. If it brass with a, most likely, gray fitting coming out of it horizontally then what you need to replace is that little gray valve. They can also be repaired. The problem is, like Daryl mentioned, due to a large rush of water/air there is a little o-ring that gets moved out of position. If you unscrew the valve. Take a small rod and insert it in one end of the valve. Then push and open the valve. While holding it open use a tooth pick or somethin similar and reseat the o-ring underneath the little plunger. Put it back together and you should be off and running. If the anti-siphon/backflow prevention valve is one piece I cannot help you. But I would suggest removing it and looking in the horizantal attachment end and see if it would appear as describe above and maybe you can fix it. |
12-21-2005, 04:14
Tank Odor
>Curt, I have a 95 BMC that had sewer smell at times, after a close examination of the plumbing system I found that the problem was that at the factory they put the penetration thought the roof and then the vent pipe through and then the vac-u-vent, they never sealed the pipe to the roof. So every time there was any kind of a inversion in weather the sewer gas would go up the pipe and come back down in the coach. I removed the vac-u-vent covers and sealed the pipe to the roof with RTV and put on new vent covers, problem solved. It's hard for me to believe that the two previous owners never got it fixed. > The Bird sometimes has tank odor, and other times no tank odor inside of > the coach. Before departing, I always make sure the kitchen sink and > shower p-traps have water in them as well as a deodorizer treatment, the > toilet has water in it above the flapper level, and the roof vents are > closed. Seems strange that sometimes the odor is present and other times > no odor. What else should I check for? > > -- > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > |
12-22-2005, 10:33
Tank Odor
If the flapper is closed, holding water above it, the most likely
culprit as has been mentioned is the gasket/seal between the toilet and the floor/pipe. Many leak, stinks when there is a negative in the coach (front windows are worst for creating negative pressure), otherwise go unnoticed until the unfortunate overfilling of the blackwater tank. - Jeff Miller in Holland, MI |
12-22-2005, 11:00
Tank Odor
Our toilet has the air pressure assist for pushing the contents
over/down to the holding tank. Would this still apply? Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Jeff Miller wrote: > If the flapper is closed, holding water above it, the most likely > culprit as has been mentioned is the gasket/seal between the toilet and > the floor/pipe. Many leak, stinks when there is a negative in the coach > (front windows are worst for creating negative pressure), otherwise go > unnoticed until the unfortunate overfilling of the blackwater tank. > > - Jeff Miller > in Holland, MI > > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > |
12-22-2005, 12:25
Tank Odor
Hi Curt,
Is your toilet a Microphor air unit? The Microphor air toilet has a hopper below the bowl that collects the contents of the flush, then, after the flapper closes, air pressure is applied to this hopper and the contents are pushed down through a 1 1/2" pipe. On these, there is no floor pipe in the fashion of an electric Microphor or other straight drop type toilet. The 1 1/2" pipe may still be a source of a leak where it connects to the hopper. Most connect at the rear of the hopper and the connection is visible by removing the lid at the back of the toilet and looking with a flashlight. Some also connect at the bottom and will be harder to see. These toilets are designed for use where a straight drop direct to the tank is not possible due to floorplan design and tank location. Air pressure is necessary to keep the clean water, after a flush, in the bowl but if air is depleted and it leaks into the hopper, this clean water should still prevent odors from entering through the toilet. Here is a link that will let you download Microphor installation and service manuals. http://www.microphor.com/html/2quart-rec.html Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Our toilet has the air pressure assist for pushing the contents > over/down to the holding tank. Would this still apply? > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > Jeff Miller wrote: > > > If the flapper is closed, holding water above it, the most likely > > culprit as has been mentioned is the gasket/seal between the toilet and > > the floor/pipe. Many leak, stinks when there is a negative in the coach > > (front windows are worst for creating negative pressure), otherwise go > > unnoticed until the unfortunate overfilling of the blackwater tank. > > > > - Jeff Miller > > in Holland, MI > > > > > > > > > > ----------------------------------------------------------------- ------- > > YAHOO! GROUPS LINKS > > > > * Visit your group "WanderlodgeForum > > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > > > * To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > > Service <http://docs.yahoo.com/info/terms/>. > > > > > > ----------------------------------------------------------------- ------- > > > |
User(s) browsing this thread: 15 Guest(s)
