TV in Bay?
12-25-2005, 04:11
TV in Bay?
Merry Christmas to everyone.
Anyone ever installed a TV in one of the FC bays? I have found a perfectly-sized TV for the bay just in front of the entry door if I can get the wiring down there. Any advice on how to do that? Thanks Scott Forman 82FC35RB Memphis |
12-25-2005, 06:46
TV in Bay?
Scott,
I wired our PT curb side forward bay to have satellite, shore and antenna TV reception. Also installed a car radio/CD player, DVD player, satellite radio, speakers. TV...I installed powered signal boosters (one in and 4 out, Radio Shack) for the TV source, and a three way (using it as 3 in, 1 out, Radio Shack) non powered splitter in the bay. Locate your coax TV cable, split it, put fittings on the ends, connect the SOURCE end to the IN connection of the signal booster, connect the other to one of the OUT connections. Your existing TV should now work as it did before, maybe better with the powered booster. Find a 12v source to power the booster and install a 12V switch to turn on-off the splitter. For the BAY cable, find a path to run from a booster OUT connection down to the bay. The powered booster cleared up the slightly snowy TV reception in the coach and bay (3 TVs). You may not need the powered booster(s)...can be added later if needed. Finding a path for the cables was interesting. On the drivers side in the PT there are drawers next to the cabinets under the sink. I removed the drawers. Using a fish tape, I was able to pull the coax cable from the electrical run-way at the back of the upper cupboards, down behind the drawers. I found room to drill a hole through the floor under the sink and near the outside wall. Had to drill down through the bay top too. I then drilled a hole in that bay forward end wall. Also drilled a hole in the curb side bay end wall, the bay that the TV goes in. The coax cables were pulled through this path. Had to tie up or hang the cables between the bays using zip ties. There was factory installed 12V in our TV bay. You will need to install 12V and/or 120V, and install on-off switches. I purchased an Inverter for the bay and it powers the TV, no 120V in the bay. This took about 2 days, but I ran 3 TV sources to the bay. Let me know if you need clarification. Or call me at 714 998-6187. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Scott Forman wrote: > Merry Christmas to everyone. > > Anyone ever installed a TV in one of the FC bays? I have found a > perfectly-sized TV for the bay just in front of the entry door if I can > get the wiring down there. Any advice on how to do that? > > Thanks > Scott Forman > 82FC35RB > Memphis > > > > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > |
