units sways excessively
12-27-2005, 15:54
i have a 83 fc-35, not having owned a BB before, it appears to be
unstable to me, a litle top heavy perhaps, how do i know if the air ride is functioning properly? unit has 80,000 miles,when should shocks be replaced. also if anyone can help me with the cruse conrtol please let me know.i havn't found the vacuum pump as of yet. thanks for all the good information on this forum re brake 1983 fc-35 |
12-27-2005, 21:24
re brake- my thoughts were the same as yours when we purchased our first
bird- 84-35FC. I was not use to the coach being so heavy as we had owned a various selection of plastic palaces before. If the shocks are Koni's on the front, they are adjustable. Lots of folks are away from the forum for the holidays, so an answer might be slow in coming to your cruise question. ernie-83pt40- no cruise [Non-text portions of this message have been removed] |
12-28-2005, 04:00
Good morning:
The sway may be caused by the bolts on the sway bar over the rear axle being loose. If your front and rear air gauges are at 120 psi and your suspension dump switch is not dumped then your air bags should be up. If you take a walk around the Coach when aired up and listen at each wheel for an air leak and find none, this I would say that your suspension is up. Also with the air up, your Coach should not be leaning from side to side and you should be able to put your hand on edge, over the wheels. I may have a vacuum pump on my shelf for the cruise. Have a photo of your's? Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 03:54 AM 12/28/2005 +0000, you wrote: >i have a 83 fc-35, not having owned a BB before, it appears to be >unstable to me, a litle top heavy perhaps, how do i know if the air >ride is functioning properly? unit has 80,000 miles,when should shocks >be replaced. >also if anyone can help me with the cruse conrtol please let me know.i >havn't found the vacuum pump as of yet. >thanks for all the good information on this forum > >re brake 1983 fc-35 > > |
12-28-2005, 05:22
On On the sway, it might be the coach, it might be you if you're not
used to it yet and overcorrecting. It takes a while for input to get to the wheels and back to you, steer less and see what happens. Many people find it easier to learn using the armrest and steering with one hand. If it is a stability issue, many possibilities: You should have LRH / 16PR tires, inflation pressures are in the transfer-switch door on the way up your stairs. The original Koni shocks might be worn, might be replaced with non- Konis (look for the Koni orange paint), or the original shocks might need to be adjusted firmer. Shock bushings can also be worn. The Panhard-Bar connecting the rear axle to the frame might need new bushings, or the bolt at either end could be broken causing the axle to be loose. I've seen a couple broken loose, not bad preventative maintenance to replace the bolts. The steering box bolts can be loose on the frame. The steering box might have excessive play. The steering "drag link" might have excessive play and need adjustment. I can't remember ride-height on the '83 FC, but I believe it is around 19-1/2" to the ground from the body behind the front wheels and ahead of the rear wheels. Someone will likely have the correct information if this is not correct. Too high or too low will cause ride issues. As far as the cruise-control, if you have the vacuum-cruise as most '83s have (control on the turn-signal stalk) it should have an aspirator / vacuum generator just behind the step-hole on the driver's side of the front bumper. It should hiss / expel air as it creates vacuum. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "putneyflash" > > i have a 83 fc-35, not having owned a BB before, it appears to be > unstable to me, a litle top heavy perhaps, how do i know if the air > ride is functioning properly? unit has 80,000 miles,when should shocks > be replaced. > also if anyone can help me with the cruse conrtol please let me know.i > havn't found the vacuum pump as of yet. > thanks for all the good information on this forum > > re brake 1983 fc-35 > |
12-30-2005, 14:39
We just went the same thing with our '81FC31. Spent around $4K and finally
found it to be the "dig Bones" both front and back. Those are the stabilizer bars that hold the body in place with the frame. This is a very long and expensive story that I won't go into now. So save yourself a lot of time and expense by either checking or having them checked first thing. The bushings were gone and were metal to metal. If you need to know the whole story let me know. But, try this first and save yourself a lot of money aned hastle. Dick Hayden '87PT38 - Lk Stevens, WA - in Yuma now >From: "putneyflash" >To: WanderlodgeForum@yahoogroups.com >Subject: [WanderlodgeForum] units sways excessively >Date: Wed, 28 Dec 2005 03:54:20 -0000 > > > > > >i have a 83 fc-35, not having owned a BB before, it appears to be > >unstable to me, a litle top heavy perhaps, how do i know if the air > >ride is functioning properly? unit has 80,000 miles,when should shocks > >be replaced. > >also if anyone can help me with the cruse conrtol please let me know.i > >havn't found the vacuum pump as of yet. > >thanks for all the good information on this forum > > > >re brake 1983 fc-35 > > > > > > > > > > > > > > > > > > > > SPONSORED LINKS > > > > > Recreational vehicles > > > Wanderlodge > > > Automotive maintenance > > > > > Recreational vehicle dealer > > > Used recreational vehicles > > > Automotive radiators > > > > > > > > > > > > > > > > YAHOO! GROUPS LINKS > > > > > Visit your group "WanderlodgeForum" on the web. > > To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > > > > > > > > > > > |
12-30-2005, 23:11
Dick,
I'm assuming by the term "dig bones", that you probably meant Dog Bones and that you are referring to what is commonly known as the Panhard Rod. Jeff Miller refered to this in his post and I have taken a previous post by Jeff and added it to photos and drawings to show just what is involved in the repair and or, replacement of the Panhard Rod assembly. I have found this to be a very common problem on the older 'Birds and it did greatly effect the handling of my 'Bird. Check out; http://www.pbase.com/iamflagman/image/40441402 Be sure to click on "NEXT" at the right of each picture to see more information. "REMEMBER SEPTEMBER 11, 2001" John Finn '82 35FCRB BLUEBIRD WANDERLODGE TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE GO TO; http://www.pbase.com/image/24977457 '66 SUPERIOR / IH 392 GAS V8 32' PUSHER "FOR SALE" SEE THE OLD COACH AT: http://www.pbase.com/image/26052733 HOPKINS, SOUTH CAROLINA /////////////////////////////////////////////////////////////////// --- In WanderlodgeForum@yahoogroups.com, "Richard Hayden" > > We just went the same thing with our '81FC31. Spent around $4K and finally > found it to be the "dig Bones" both front and back. Those are the > stabilizer bars that hold the body in place with the frame. This is a very > long and expensive story that I won't go into now. So save yourself a lot > of time and expense by either checking or having them checked first thing. > The bushings were gone and were metal to metal. If you need to know the > whole story let me know. But, try this first and save yourself a lot of > money aned hastle. > > Dick Hayden '87PT38 - Lk Stevens, WA - in Yuma now > > > >From: "putneyflash" > >To: WanderlodgeForum@yahoogroups.com > >Subject: [WanderlodgeForum] units sways excessively > >Date: Wed, 28 Dec 2005 03:54:20 -0000 > > > > > > > > > > > >i have a 83 fc-35, not having owned a BB before, it appears to be > > > >unstable to me, a litle top heavy perhaps, how do i know if the air > > > >ride is functioning properly? unit has 80,000 miles,when should shocks > > > >be replaced. > > > >also if anyone can help me with the cruse conrtol please let me know.i > > > >havn't found the vacuum pump as of yet. > > > >thanks for all the good information on this forum > > > > > > > >re brake 1983 fc-35 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > SPONSORED LINKS > > > > > > > > > > Recreational vehicles > > > > > > Wanderlodge > > > > > > Automotive maintenance > > > > > > > > > > Recreational vehicle dealer > > > > > > Used recreational vehicles > > > > > > Automotive radiators > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > YAHOO! GROUPS LINKS > > > > > > > > > > Visit your group "WanderlodgeForum" on the web. > > > > To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > |
12-31-2005, 06:03
Yes I did mean "dog bones" - sorry. I was typing in the dark last night on a
new computer. I later saw all of the good advice offered by others. Much more detailed than my short note. I got the advice and the "dog bone" term from BB Customer Service. But, it is indeed what Jeff says. Good luck. Dick Hayden - '87 PT 38 - Yuma ----- Original Message ----- From: John To: WanderlodgeForum@yahoogroups.com Sent: Saturday, December 31, 2005 3:11 AM Subject: [WanderlodgeForum] Re: units sways excessively Dick, I'm assuming by the term "dig bones", that you probably meant Dog Bones and that you are referring to what is commonly known as the Panhard Rod. Jeff Miller refered to this in his post and I have taken a previous post by Jeff and added it to photos and drawings to show just what is involved in the repair and or, replacement of the Panhard Rod assembly. I have found this to be a very common problem on the older 'Birds and it did greatly effect the handling of my 'Bird. Check out; http://www.pbase.com/iamflagman/image/40441402<http://www.pbase.com/iamflagman/i\ mage/40441402> Be sure to click on "NEXT" at the right of each picture to see more information. "REMEMBER SEPTEMBER 11, 2001" John Finn '82 35FCRB BLUEBIRD WANDERLODGE TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE GO TO; http://www.pbase.com/image/24977457<http://www.pbase.com/image/24977457> '66 SUPERIOR / IH 392 GAS V8 32' PUSHER "FOR SALE" SEE THE OLD COACH AT: http://www.pbase.com/image/26052733<http://www.pbase.com/image/26052733> HOPKINS, SOUTH CAROLINA /////////////////////////////////////////////////////////////////// --- In WanderlodgeForum@yahoogroups.com, "Richard Hayden" > > We just went the same thing with our '81FC31. Spent around $4K and finally > found it to be the "dig Bones" both front and back. Those are the > stabilizer bars that hold the body in place with the frame. This is a very > long and expensive story that I won't go into now. So save yourself a lot > of time and expense by either checking or having them checked first thing. > The bushings were gone and were metal to metal. If you need to know the > whole story let me know. But, try this first and save yourself a lot of > money aned hastle. > > Dick Hayden '87PT38 - Lk Stevens, WA - in Yuma now > > > >From: "putneyflash" > >To: WanderlodgeForum@yahoogroups.com > >Subject: [WanderlodgeForum] units sways excessively > >Date: Wed, 28 Dec 2005 03:54:20 -0000 > > > > > > > > > > > >i have a 83 fc-35, not having owned a BB before, it appears to be > > > >unstable to me, a litle top heavy perhaps, how do i know if the air > > > >ride is functioning properly? unit has 80,000 miles,when should shocks > > > >be replaced. > > > >also if anyone can help me with the cruse conrtol please let me know.i > > > >havn't found the vacuum pump as of yet. > > > >thanks for all the good information on this forum > > > > > > > >re brake 1983 fc-35 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > SPONSORED LINKS > > > > > > > > > > Recreational vehicles > > > > > > Wanderlodge > > > > > > Automotive maintenance > > > > > > > > > > Recreational vehicle dealer > > > > > > Used recreational vehicles > > > > > > Automotive radiators > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > YAHOO! GROUPS LINKS > > > > > > > > > > Visit your group "WanderlodgeForum" on the web. > > > > To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > SPONSORED LINKS Recreational vehicles<http://groups.yahoo.com/gads?t=ms&k=Recr...ation\ al+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea\ ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKk\ U7Dzhn_ObWmSYTw> Wanderlodge<http://groups.yahoo.com/gads?t=ms&k=Wand...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj\ 9U0JvqYQ> Automotive maintenance<http://groups.yahoo.com/gads?t=ms&k=Auto...ecrea\ tional+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle\ +dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4\ u_5wI8Pmy34cC1O9CxA> Recreational vehicle dealer<http://groups.yahoo.com/gads?t=ms&k=Recr...ecrea\ tional+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle\ +dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_\ XahaeYHfELr6o72IW1A> Used recreational vehicles<http://groups.yahoo.com/gads?t=ms&k=Used...Recre\ ational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicl\ e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UG\ EY5km4L-kXbDI4ZSadEw> Automotive radiators<http://groups.yahoo.com/gads?t=ms&k=Auto...ation\ al+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea\ ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmI\ SsCWgTnMq_4GlXA> ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum<http://groups.yahoo.com/group/WanderlodgeForum>" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service<http://docs.yahoo.com/info/terms/>. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
