Tandy TV Antenna
12-29-2005, 08:44
Tandy TV Antenna
Anyone have the directions and schematic(s) for the Tandy TV Antenna. A
couple pictures of the antenna in the upright and retracted positions would help a lot. I'm toying with the idea of making the old unit stand up, and work. The Mimistat 5MS9000 will replace the old round plastic antenna. -- Curt Sprenger 1987 PT38, Anaheim Hills, Calif. |
12-29-2005, 10:52
Tandy TV Antenna
The antenna is powered directy from the amplifier/rotor unit which I
believe to be located in the rearmost salon overhead cabinet (the small one) on the passenger/curbside. This is also where the rotor control plugs in, and the rotor control from the bedroom is wired in parallel with the main (front) control. If you're looking for a wiring diagram of the lift motor and warning light, that exists at BB coachworks as well as in some of our blue boxes. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Anyone have the directions and schematic(s) for the Tandy TV Antenna. A > couple pictures of the antenna in the upright and retracted positions > would help a lot. I'm toying with the idea of making the old unit stand > up, and work. The Mimistat 5MS9000 will replace the old round plastic > antenna. > > -- > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > |
12-29-2005, 13:54
Tandy TV Antenna
I'm looking for a wiring diagram of the lift motor and warning light.
Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Jeff Miller wrote: > The antenna is powered directy from the amplifier/rotor unit which I > believe to be located in the rearmost salon overhead cabinet (the small > one) on the passenger/curbside. This is also where the rotor control > plugs in, and the rotor control from the bedroom is wired in parallel > with the main (front) control. > > If you're looking for a wiring diagram of the lift motor and warning > light, that exists at BB coachworks as well as in some of our blue > boxes. > > - Jeff Miller > in Holland, MI > > > --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > > > > Anyone have the directions and schematic(s) for the Tandy TV Antenna. > A > > couple pictures of the antenna in the upright and retracted positions > > would help a lot. I'm toying with the idea of making the old unit > stand > > up, and work. The Mimistat 5MS9000 will replace the old round plastic > > antenna. > > > > -- > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > > > > > > > SPONSORED LINKS > Recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Recr...vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_O\ bWmSYTw> > Wanderlodge > <http://groups.yahoo.com/gads?t=ms&k=Wand...2=Wan\ derlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recrea\ tional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ> > Automotive maintenance > <http://groups.yahoo.com/gads?t=ms&k=Auto...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34\ cC1O9CxA> > > Recreational vehicle dealer > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeY\ HfELr6o72IW1A> > Used recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Used...onal+\ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer\ &w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-\ kXbDI4ZSadEw> > Automotive radiators > <http://groups.yahoo.com/gads?t=ms&k=Auto...ehicl\ es&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Us\ ed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq\ _4GlXA> > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > |
12-29-2005, 16:17
Tandy TV Antenna
It's a fairly simple drawing, a relay, a switch, a circuit-
breaker, ... drawing that I have is 3738846. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > I'm looking for a wiring diagram of the lift motor and warning light. > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > Jeff Miller wrote: > > > The antenna is powered directy from the amplifier/rotor unit which I > > believe to be located in the rearmost salon overhead cabinet (the small > > one) on the passenger/curbside. This is also where the rotor control > > plugs in, and the rotor control from the bedroom is wired in parallel > > with the main (front) control. > > > > If you're looking for a wiring diagram of the lift motor and warning > > light, that exists at BB coachworks as well as in some of our blue > > boxes. > > > > - Jeff Miller > > in Holland, MI > > > > > > --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > > > > > > > Anyone have the directions and schematic(s) for the Tandy TV Antenna. > > A > > > couple pictures of the antenna in the upright and retracted positions > > > would help a lot. I'm toying with the idea of making the old unit > > stand > > > up, and work. The Mimistat 5MS9000 will replace the old round plastic > > > antenna. > > > > > > -- > > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > > > > > > > > > > > > > > > > SPONSORED LINKS > > Recreational vehicles > > <http://groups.yahoo.com/gads? t=ms&k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge&w 3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recrea tional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_O bWmSYTw> > > Wanderlodge > > <http://groups.yahoo.com/gads? t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automoti ve+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+veh icles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ> > > Automotive maintenance > > <http://groups.yahoo.com/gads? t=ms&k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge& w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34 cC1O9CxA> > > > > Recreational vehicle dealer > > <http://groups.yahoo.com/gads? t=ms&k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wanderl odge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+ recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeY HfELr6o72IW1A> > > Used recreational vehicles > > <http://groups.yahoo.com/gads? t=ms&k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlo dge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+r ecreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L- kXbDI4ZSadEw> > > Automotive radiators > > <http://groups.yahoo.com/gads? t=ms&k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w3 =Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreat ional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq _4GlXA> > > > > > > > > ------------------------------------------------------------------ ------ > > YAHOO! GROUPS LINKS > > > > * Visit your group "WanderlodgeForum > > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > > > * To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > > Service <http://docs.yahoo.com/info/terms/>. > > > > > > ------------------------------------------------------------------ ------ > > > |
