Blue Smoke
12-30-2005, 09:32
Blue Smoke
88 PT 40 8V92 Coach has been parked since July,Wife and I Have been
deployed w/FEMA in Oct I was home and started it,no problem.Recently I was home for a couple of days,started it,started right up, white smoke as normal after sitting.But then Blue smoke, that didn't stop,after ten/ fifteen minutes or so.It's never had Blue smoke.Now I'm deployed again and it's eating at me what could be the cause.can someone relieve my concerns.Like maybe it needs a good hot run or some thing Thanks |
12-30-2005, 14:03
Blue Smoke
the length of time you warm it up is not as important as the water or
oil temp the engine reaches. to me it sounds like inefficient diesel burn at the injectors. you do get some ring oil burn befor the pistons reach operating temp. Greg pt40Romoland California--- In WanderlodgeForum@yahoogroups.com, "tjvap" > > 88 PT 40 8V92 Coach has been parked since July,Wife and I Have been > deployed w/FEMA in Oct I was home and started it,no problem.Recently I > was home for a couple of days,started it,started right up, white smoke > as normal after sitting.But then Blue smoke, that didn't stop,after > ten/ fifteen minutes or so.It's never had Blue smoke.Now I'm deployed > again and it's eating at me what could be the cause.can someone relieve > my concerns.Like maybe it needs a good hot run or some thing Thanks > |
