Primus Parts
12-30-2005, 23:21
Primus Parts
Just ordered 2 circ pumps from Vechicle Systems.
Spoke with David Haynes a customer rep. Asked him if would recommend
converson to webasto burner instead. He said no as long as primus burners are
working its a good systmem. Mike with Bluebird said its one of the best
systems
they used only problem was availability of parts. Vehicle Systems website
is vehiclesys.com Davids number is 1800-685-4298 his ext is 127. The part
number was PLX-CM3-P71. Price was 192.50 each
Hope this helps. I am going to have Foothill RV in Taylorsville NC put mine
in. He says he is familiar and carries parts for primus.
john redden 91PT40
12-30-2005, 23:25
Primus Parts
to check the pumps you can change the power supply wire from the outside
post to the center post on the relay and get constant 12V power to the pumps.
Then take a light and look in the resiviour tanks and see if you get the
stream of water flowing into the tanks. If its there and strong then your
pumps
are ok. If not replacement would be a considered option. Bennie with BB told
me about switching the wires to test the pumps. Call him if you have
questions. David with Vehicle Systems agreed that the weak part of all
hydronic
systems is the circ pumps
john redden 91PT40
12-31-2005, 02:07
Primus Parts
Ihave a 92 WB coach with a Primus heat system. I think I need a
circulation pump, does anyone have any info where i can get
replacement parts.
12-31-2005, 02:29
Primus Parts
Get in touch with Stephen Birtles on this Forum. He carries Primus parts.
Safe travels,
>replacement parts.
01-02-2006, 21:58
Primus Parts
outside
the pumps.
get the
then your pumps
with BB told
have
of all hydronic
> john redden 91PT40
>thank you for the info
have a happy new year
rick
