CO detectors
01-01-2006, 02:09
CO detectors
> Next questions - Has anyone experience with the battery operated
CO > sensor vs the hard wired? Wal-Mart sells a battery sensor. Camping World > sells a hard wired sensor. Is one CO sensor enough? > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Curt, I installed a battery powered combined fire/CO detector in our bus after purchase. I had concern over the propane heaters as far as fire/CO (I checked them out, but still, components are 20 yrs old...) and also wanted to ensure i had a good smoke detector. Detector is mounted mid cabin in our 33' and we normally do not close the bedroom door when on the bus except to dress, if i had a longer bus, or separated areas, i would consider one for any isolated sleeping area. A hardwire unit will not be active if no 120vt...A battery powered one will not be active on a dead battery....take your pick. Does it work....well, the "morning toaster test" has on occassion alarmed the unit for smoke/fire. And last year I started the generator (THIS WAS A DUMB MOVE...trying to rush) "just for a minute" with the RV cover on trying to trace a circuit. The window over the gen exhaust was cracked about 1/2 inch, and the detector CO alarmed after about 2 minutes, before I could smell anything... Frank 85FC33 Woodbridge, VA. |
01-01-2006, 04:05
CO detectors
Frank,
Yesterday I bought two battery operated CO detectors from WalMart and installed one in the bedroom and one in the rear lounge area. I did not see the dual purpose units but then I didn't spend a lot of time looking. I think the battery units are the way to go for us as most of our camping is boondocking. Oh, also bought a supply of batteries. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. fwernlein wrote: > > Next questions - Has anyone experience with the battery operated > CO > > sensor vs the hard wired? Wal-Mart sells a battery sensor. Camping > World > > sells a hard wired sensor. Is one CO sensor enough? > > > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > Curt, > > I installed a battery powered combined fire/CO detector in our bus > after purchase. I had concern over the propane heaters as far as > fire/CO (I checked them out, but still, components are 20 yrs old...) > and also wanted to ensure i had a good smoke detector. Detector is > mounted mid cabin in our 33' and we normally do not close the > bedroom door when on the bus except to dress, if i had a longer bus, > or separated areas, i would consider one for any isolated sleeping > area. > > A hardwire unit will not be active if no 120vt...A battery powered > one will not be active on a dead battery....take your pick. > > Does it work....well, the "morning toaster test" has on occassion > alarmed the unit for smoke/fire. And last year I started the > generator (THIS WAS A DUMB MOVE...trying to rush) "just for a > minute" with the RV cover on trying to trace a circuit. The window > over the gen exhaust was cracked about 1/2 inch, and the detector CO > alarmed after about 2 minutes, before I could smell anything... > > > Frank > 85FC33 > Woodbridge, VA. > > > > > > > SPONSORED LINKS > Recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Recr...vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_O\ bWmSYTw> > Wanderlodge > <http://groups.yahoo.com/gads?t=ms&k=Wand...2=Wan\ derlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recrea\ tional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ> > Automotive maintenance > <http://groups.yahoo.com/gads?t=ms&k=Auto...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34\ cC1O9CxA> > > Recreational vehicle dealer > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeY\ HfELr6o72IW1A> > Used recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Used...onal+\ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer\ &w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-\ kXbDI4ZSadEw> > Automotive radiators > <http://groups.yahoo.com/gads?t=ms&k=Auto...ehicl\ es&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Us\ ed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq\ _4GlXA> > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > |
