Back Up System Help
01-03-2006, 15:17
Back Up System Help
I am replacing the video camera and monitor in my 87 FC. I have a
friend of a friend who got me a Honeywell High Res. Miniature Color Camera with a 2.7-13.5 Auto Iris Lens. He says that the camera needs very little light to function and has a b/w night function. I then got a 6.8â LCD Safety Vision Monitor (HYPERLINK "http://www.safetyvision.com/en/cms/?17"http://www.safetyvision.com/en/c ms/?17). I bought this unit because of a number of reasons. Primarily they were size, remote, and the mirror function. I set the system up and came upon a stumbling point. That is the monitor will not function in the mirror image unless it has a Safety Vision camera hooked up to it. In other words it will not reverse the image if you have mirror function selected. This has got me. I thought I had researched this fully and now the tech department says I will need a Safety Vision camera. I called Honeywell tech department and they say that the polarity must be switched. I asked him if it were something I could do and the answer was no. Iâve spent hours on the net looking for some answer but have come up with nothing. I have read most if not all the posts on the Wanderlodge sites and the only thing that is discussed is reversing the image on a system with a CRT screen. So my question is how do you go about reversing the image for a LCD screen? Blair or anyoneâs help will be much appreciated. Dan Leftwich 87 35FC Somers NY -- No virus found in this outgoing message. Checked by AVG Free Edition. Version: 7.1.371 / Virus Database: 267.14.11/219 - Release Date: 1/2/2006 [Non-text portions of this message have been removed] |
01-04-2006, 05:03
Back Up System Help
I don't understand why it needs their camera to do it, sounds fishy.
The LCD monitor must have the reverse/mirror functions built in to the monitor to reverse, can't be done by reversing a couple of wires like a CRT can. LCD monitors and chip cameras work using pixel- mapping, the reverse is done by software. It is possible that the camera in that system does the reverse-image, not the monitor? What is wrong with your original monitor? I am interested in it if you're not keeping it. Otherwise consider using the new camera with the old monitor. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, Dan Leftwich wrote: > > I am replacing the video camera and monitor in my 87 FC. I have a > friend of a friend who got me a Honeywell High Res. Miniature Color > Camera with a 2.7-13.5 Auto Iris Lens. He says that the camera needs > very little light to function and has a b/w night function. I then got > a 6.8" LCD Safety Vision Monitor (HYPERLINK > "http://www.safetyvision.com/en/cms/? 17"http://www.safetyvision.com/en/c > ms/?17). I bought this unit because of a number of reasons. Primarily > they were size, remote, and the mirror function. > > I set the system up and came upon a stumbling point. That is the > monitor will not function in the mirror image unless it has a Safety > Vision camera hooked up to it. In other words it will not reverse the > image if you have mirror function selected. This has got me. I thought > I had researched this fully and now the tech department says I will need > a Safety Vision camera. I called Honeywell tech department and they say > that the polarity must be switched. I asked him if it were something I > could do and the answer was no. > > I've spent hours on the net looking for some answer but have come up > with nothing. I have read most if not all the posts on the Wanderlodge > sites and the only thing that is discussed is reversing the image on a > system with a CRT screen. > > So my question is how do you go about reversing the image for a LCD > screen? Blair or anyone's help will be much appreciated. > > Dan Leftwich > 87 35FC Somers NY > > -- > No virus found in this outgoing message. > Checked by AVG Free Edition. > Version: 7.1.371 / Virus Database: 267.14.11/219 - Release Date: > 1/2/2006 > > > > [Non-text portions of this message have been removed] > |
01-04-2006, 14:09
Back Up System Help
Thanks for the response Jeff.
I gave the tech guy from Safety Vision a call late today to further have him explain how the Safety Vision system works. He said the monitor does the reversing of the image but works in conjunction with the camera that reverses the polarity through the use of magnets. Donât know if I completely understand this but I guess it sounds plausible. He said that you just need to make sure that you have a camera that does this. He said there were cameras on the market that do this other than Safety Vision. I donât think I have ever come across one though. Just for interest look at the top of pg. 2 at HYPERLINK "http://www.safetyvision.com/attachments/...-001_3.pdf "http://www.safetyvision.com/attachments/...-001_3.pdf Iâm going to have the guy who got me the Honeywell camera stop by to see what he thinks. He is an installer for home and commercial alarms. Hopefully he will be able to address the problem. The old monitor was working when I took it out. I used some of the brackets for the new system that held the CRT monitor together. I might need the monitor but if I do not I will drop you a line. I have the rear b/w camera too. Regards, Dan Leftwich 87 35FC Somers NY -- No virus found in this outgoing message. Checked by AVG Free Edition. Version: 7.1.371 / Virus Database: 267.14.12/220 - Release Date: 1/3/2006 [Non-text portions of this message have been removed] |
01-05-2006, 03:37
Back Up System Help
LOL
I think that the tech support person knows nothing. My take from the manual pages is that the lettering on the camera was poorly translated from Korean or Chinese, and says "Magnetic" and "Non-Magnetic" instead of "Mirrored" and "Non-Mirrored" so the manual is trying to explain the correct switch positions. In a CRT (not LCD) the horizontal and vertical deflection is magnetic, either mirrored or normal, might be where the Chinese got confused, I've seen lots of botched manual translations. It appears that the monitor does the image-reverse, and is signaled by the switch on the camera and utilizes an extra wire in the DIN cable. The signal is probably GND or +5v, could also be +12v / GND, but without knowing which it is difficult to reverse the image manually. Perhaps another tech support person will know more. Again, the image in an LCD monitor can't be reversed magnetically, they are unaffected by reasonable amounts of magnetic energy (unlike CRTs), it will have to be reversed by a built-in software switch to do the pixel-mapping backwards (which it apparently has if you can figure out what the signal voltage needs to be). - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, Dan Leftwich wrote: > > Thanks for the response Jeff. > > I gave the tech guy from Safety Vision a call late today to further have > him explain how the Safety Vision system works. He said the monitor > does the reversing of the image but works in conjunction with the camera > that reverses the polarity through the use of magnets. Don't know if I > completely understand this but I guess it sounds plausible. He said > that you just need to make sure that you have a camera that does this. > He said there were cameras on the market that do this other than Safety > Vision. I don't think I have ever come across one though. > > Just for interest look at the top of pg. 2 at HYPERLINK > "http://www.safetyvision.com/attachments/...20CKITQIG- 001_3.pdf > "http://www.safetyvision.com/attachments/...20CKITQIG- 001_3.pdf > > I'm going to have the guy who got me the Honeywell camera stop by to see > what he thinks. He is an installer for home and commercial alarms. > Hopefully he will be able to address the problem. > > The old monitor was working when I took it out. I used some of the > brackets for the new system that held the CRT monitor together. I might > need the monitor but if I do not I will drop you a line. I have the > rear b/w camera too. > > Regards, > Dan Leftwich > 87 35FC Somers NY > > -- > No virus found in this outgoing message. > Checked by AVG Free Edition. > Version: 7.1.371 / Virus Database: 267.14.12/220 - Release Date: > 1/3/2006 > > > > [Non-text portions of this message have been removed] > |
01-05-2006, 03:42
Back Up System Help
As an addendum, probably the lowest risk experiment (lowest, not
without risk) would be to ground that pin and see if the image reverses. - Jeff Miller still in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > > LOL > I think that the tech support person knows nothing. > > My take from the manual pages is that the lettering on the camera was > poorly translated from Korean or Chinese, and says "Magnetic" > and "Non-Magnetic" instead of "Mirrored" and "Non-Mirrored" so the > manual is trying to explain the correct switch positions. In a CRT > (not LCD) the horizontal and vertical deflection is magnetic, either > mirrored or normal, might be where the Chinese got confused, I've > seen lots of botched manual translations. > > It appears that the monitor does the image-reverse, and is signaled > by the switch on the camera and utilizes an extra wire in the DIN > cable. > > The signal is probably GND or +5v, could also be +12v / GND, but > without knowing which it is difficult to reverse the image manually. > Perhaps another tech support person will know more. > > Again, the image in an LCD monitor can't be reversed magnetically, > they are unaffected by reasonable amounts of magnetic energy (unlike > CRTs), it will have to be reversed by a built-in software switch to > do the pixel-mapping backwards (which it apparently has if you can > figure out what the signal voltage needs to be). > > - Jeff Miller > in Holland, MI > > > --- In WanderlodgeForum@yahoogroups.com, Dan Leftwich > wrote: > > > > Thanks for the response Jeff. > > > > I gave the tech guy from Safety Vision a call late today to further > have > > him explain how the Safety Vision system works. He said the monitor > > does the reversing of the image but works in conjunction with the > camera > > that reverses the polarity through the use of magnets. Don't know > if I > > completely understand this but I guess it sounds plausible. He said > > that you just need to make sure that you have a camera that does > this. > > He said there were cameras on the market that do this other than > Safety > > Vision. I don't think I have ever come across one though. > > > > Just for interest look at the top of pg. 2 at HYPERLINK > > "http://www.safetyvision.com/attachments/...20CKITQIG- > 001_3.pdf > > "http://www.safetyvision.com/attachments/...20CKITQIG- > 001_3.pdf > > > > I'm going to have the guy who got me the Honeywell camera stop by > to see > > what he thinks. He is an installer for home and commercial alarms. > > Hopefully he will be able to address the problem. > > > > The old monitor was working when I took it out. I used some of the > > brackets for the new system that held the CRT monitor together. I > might > > need the monitor but if I do not I will drop you a line. I have the > > rear b/w camera too. > > > > Regards, > > Dan Leftwich > > 87 35FC Somers NY > > > > -- > > No virus found in this outgoing message. > > Checked by AVG Free Edition. > > Version: 7.1.371 / Virus Database: 267.14.12/220 - Release Date: > > 1/3/2006 > > > > > > > > [Non-text portions of this message have been removed] > > > |
01-05-2006, 07:34
Back Up System Help
Thank You Jeff for explaining this to me.
I found a diagram in the manual which proves to be semi helpful. You are correct in saying that there is a pin in the 4 pin multi connector that is responsible for the mir/nor signal. I tried grounding that line out but saw no change in the signal. I will attempt this again because it is easiest and more importantly safest. My next attempt will be adding power to that pin but am not sure how to get 5V. I imagine I will connect it to power with a 5 amp fuse in line. How does one get 5 volt power source? Also how do you get at +12V/Ground? I know how to get a +12V. Dan Leftwich 87 35FC -- No virus found in this outgoing message. Checked by AVG Free Edition. Version: 7.1.371 / Virus Database: 267.14.13/221 - Release Date: 1/4/2006 [Non-text portions of this message have been removed] |
01-05-2006, 09:22
Back Up System Help
By +12v/Gnd I meant either +12v or Gnd. Most likely the switch is
made by +12, Gnd, or +5v. +5v is used often in logic circuits, it would be created in the camera. If +5v is not needed inside the camera, it would not output +5v, and then the most likely (IMO) signal would be +12v. For logic/semiconductor circuits it is unlikely that a 5amp fuse will protect it from a dead-short. Something like 5ma or less (fast-blow) might (.005a). Your odds are good IMO, but not 100%. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, Dan Leftwich wrote: > > Thank You Jeff for explaining this to me. > > I found a diagram in the manual which proves to be semi helpful. You > are correct in saying that there is a pin in the 4 pin multi connector > that is responsible for the mir/nor signal. I tried grounding that line > out but saw no change in the signal. I will attempt this again because > it is easiest and more importantly safest. > > My next attempt will be adding power to that pin but am not sure how to > get 5V. I imagine I will connect it to power with a 5 amp fuse in line. > How does one get 5 volt power source? Also how do you get at > +12V/Ground? I know how to get a +12V. > > Dan Leftwich > 87 35FC > > > > > > > > > > > > > > -- > No virus found in this outgoing message. > Checked by AVG Free Edition. > Version: 7.1.371 / Virus Database: 267.14.13/221 - Release Date: > 1/4/2006 > > > > [Non-text portions of this message have been removed] > |
01-05-2006, 13:39
Back Up System Help
use a resistor to your 5 volt, not a fuse. Try a 20k to start
Jeff Miller Most likely the switch is made by +12, Gnd, or +5v. +5v is used often in logic circuits, it would be created in the camera. If +5v is not needed inside the camera, it would not output +5v, and then the most likely (IMO) signal would be +12v. For logic/semiconductor circuits it is unlikely that a 5amp fuse will protect it from a dead-short. Something like 5ma or less (fast-blow) might (.005a). Your odds are good IMO, but not 100%. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, Dan Leftwich wrote: > > Thank You Jeff for explaining this to me. > > I found a diagram in the manual which proves to be semi helpful. You > are correct in saying that there is a pin in the 4 pin multi connector > that is responsible for the mir/nor signal. I tried grounding that line > out but saw no change in the signal. I will attempt this again because > it is easiest and more importantly safest. > > My next attempt will be adding power to that pin but am not sure how to > get 5V. I imagine I will connect it to power with a 5 amp fuse in line. > How does one get 5 volt power source? Also how do you get at > +12V/Ground? I know how to get a +12V. > > Dan Leftwich > 87 35FC > > > > > > > > > > > > > > -- > No virus found in this outgoing message. > Checked by AVG Free Edition. > Version: 7.1.371 / Virus Database: 267.14.13/221 - Release Date: > 1/4/2006 > > > > [Non-text portions of this message have been removed] > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators --------------------------------- YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- [Non-text portions of this message have been removed] |
01-06-2006, 08:36
Back Up System Help
---JEFF:
I read most of your replys and am usually always impressed...I just have one question????? When do you sleep??? LOL Regards, Hank Hannigan & Naty At "Aussie Millions" in Melbourne Australia trying to get money for a 2008 SP380 Bluebird from coachworks! 90SP36 In WanderlodgeForum@yahoogroups.com, "Jeff Miller" wrote: > > LOL > I think that the tech support person knows nothing. > > My take from the manual pages is that the lettering on the camera was > poorly translated from Korean or Chinese, and says "Magnetic" > and "Non-Magnetic" instead of "Mirrored" and "Non-Mirrored" so the > manual is trying to explain the correct switch positions. In a CRT > (not LCD) the horizontal and vertical deflection is magnetic, either > mirrored or normal, might be where the Chinese got confused, I've > seen lots of botched manual translations. > > It appears that the monitor does the image-reverse, and is signaled > by the switch on the camera and utilizes an extra wire in the DIN > cable. > > The signal is probably GND or +5v, could also be +12v / GND, but > without knowing which it is difficult to reverse the image manually. > Perhaps another tech support person will know more. > > Again, the image in an LCD monitor can't be reversed magnetically, > they are unaffected by reasonable amounts of magnetic energy (unlike > CRTs), it will have to be reversed by a built-in software switch to > do the pixel-mapping backwards (which it apparently has if you can > figure out what the signal voltage needs to be). > > - Jeff Miller > in Holland, MI > > > --- In WanderlodgeForum@yahoogroups.com, Dan Leftwich > wrote: > > > > Thanks for the response Jeff. > > > > I gave the tech guy from Safety Vision a call late today to further > have > > him explain how the Safety Vision system works. He said the monitor > > does the reversing of the image but works in conjunction with the > camera > > that reverses the polarity through the use of magnets. Don't know > if I > > completely understand this but I guess it sounds plausible. He said > > that you just need to make sure that you have a camera that does > this. > > He said there were cameras on the market that do this other than > Safety > > Vision. I don't think I have ever come across one though. > > > > Just for interest look at the top of pg. 2 at HYPERLINK > > "http://www.safetyvision.com/attachments/...20CKITQIG- > 001_3.pdf > > "http://www.safetyvision.com/attachments/...20CKITQIG- > 001_3.pdf > > > > I'm going to have the guy who got me the Honeywell camera stop by > to see > > what he thinks. He is an installer for home and commercial alarms. > > Hopefully he will be able to address the problem. > > > > The old monitor was working when I took it out. I used some of the > > brackets for the new system that held the CRT monitor together. I > might > > need the monitor but if I do not I will drop you a line. I have the > > rear b/w camera too. > > > > Regards, > > Dan Leftwich > > 87 35FC Somers NY > > > > -- > > No virus found in this outgoing message. > > Checked by AVG Free Edition. > > Version: 7.1.371 / Virus Database: 267.14.12/220 - Release Date: > > 1/3/2006 > > > > > > > > [Non-text portions of this message have been removed] > > > |
