Auxiliary Air Compressor
01-04-2006, 07:55
Hi folks,
Just got done searching past posts about installing an auxiliary air compressor in the basement of my 94 Wanderlodge WBSA. Is the GAST compressor the recommended way to go? Or is there a better and more commonly used compressor that I did not see? I need the compressor to pump up my air system without the engine running, air tires, operate my dump valves, and be available as an emergency backup in case of engine driven air compressor failure (I take it 12volt compressor would be required for this). I already have a compressor that operates the air system for the toilet but I assume that compressor has to remain solely dedicated to the toilet operation. I am going to Quartzsite for the first time this year. Do you folks know of a particular person/vendor who would be able to install this auxilliary compressor while I am there? Also, I need a new left side windshield pane installed. What are the chances that I could get that done by someone while I am there? I have no clue who to call in advance to arrange. Thanks for any advice/help you can give. Jerry Kessler 1994 Wanderlodge WBSA Santa Barbara, CA |
01-04-2006, 12:38
Jerry you might want to contact Canyon State Bus Sales in
Phoenix,Arizona since they are a Bluebird School Bus dealer. They will know how to work on your bus and you can have the windshield shipped there for installation. Canyon State Bus Sales 3113 West Weldon Street, Phoenix, AZ 85017 (602) 230-1515 , FAX (602) 230-1519 Primary Area of Responsibility: Arizona Tom Warner 1982 FC35 Vernon Center,NY At 02:55 PM 1/4/2006, you wrote: >Hi folks, > >Just got done searching past posts about installing an auxiliary air >compressor in the basement of my 94 Wanderlodge WBSA. Is the GAST >compressor the recommended way to go? Or is there a better and more >commonly used compressor that I did not see? > >I need the compressor to pump up my air system without the engine >running, air tires, operate my dump valves, and be available as an >emergency backup in case of engine driven air compressor failure (I >take it 12volt compressor would be required for this). I already have >a compressor that operates the air system for the toilet but I assume >that compressor has to remain solely dedicated to the toilet operation. > >I am going to Quartzsite for the first time this year. Do you folks >know of a particular person/vendor who would be able to install this >auxilliary compressor while I am there? Also, I need a new left side >windshield pane installed. What are the chances that I could get that >done by someone while I am there? I have no clue who to call in >advance to arrange. > >Thanks for any advice/help you can give. > >Jerry Kessler >1994 Wanderlodge WBSA >Santa Barbara, CA > > > > > > >SPONSORED LINKS ><http://groups.yahoo.com/gads?t=ms&k=Recr...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_\ ObWmSYTw>Recreational >vehicles ><http://groups.yahoo.com/gads?t=ms&k=Wand...w2=Wa\ nderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre\ ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>W\ anderlodge ><http://groups.yahoo.com/gads?t=ms&k=Auto...3;veh\ icles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5\ =Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy3\ 4cC1O9CxA>Automotive >maintenance ><http://groups.yahoo.com/gads?t=ms&k=Recr...tiona\ l+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal\ er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xahae\ YHfELr6o72IW1A>Recreational >vehicle dealer ><http://groups.yahoo.com/gads?t=ms&k=Used...ional\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L\ -kXbDI4ZSadEw>Used >recreational vehicles ><http://groups.yahoo.com/gads?t=ms&k=Auto...vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnM\ q_4GlXA>Automotive >radiators > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
01-04-2006, 13:22
Jerry,
A-Z bus is also a Bluebird dealer. They have a shop in Sacramento and, I believe, in Compton, CA. I have used the Sacramento shop and had good service. George Lowry '95 WBDA 4203 Spearfish, SD Currently enjoying shirtsleeve weather in Palm Springs, CA Tom Warner wrote: >Jerry you might want to contact Canyon State Bus Sales in >Phoenix,Arizona since they are a Bluebird School Bus dealer. They >will know how to work on your bus and you can have the windshield >shipped there for installation. > >Canyon State Bus Sales >3113 West Weldon Street, Phoenix, AZ 85017 >(602) 230-1515 , FAX (602) 230-1519 >Primary Area of Responsibility: Arizona > >Tom Warner >1982 FC35 >Vernon Center,NY > > > > > >At 02:55 PM 1/4/2006, you wrote: > > >>Hi folks, >> >>Just got done searching past posts about installing an auxiliary air >>compressor in the basement of my 94 Wanderlodge WBSA. Is the GAST >>compressor the recommended way to go? Or is there a better and more >>commonly used compressor that I did not see? >> >>I need the compressor to pump up my air system without the engine >>running, air tires, operate my dump valves, and be available as an >>emergency backup in case of engine driven air compressor failure (I >>take it 12volt compressor would be required for this). I already have >>a compressor that operates the air system for the toilet but I assume >>that compressor has to remain solely dedicated to the toilet operation. >> >>I am going to Quartzsite for the first time this year. Do you folks >>know of a particular person/vendor who would be able to install this >>auxilliary compressor while I am there? Also, I need a new left side >>windshield pane installed. What are the chances that I could get that >>done by someone while I am there? I have no clue who to call in >>advance to arrange. >> >>Thanks for any advice/help you can give. >> >>Jerry Kessler >>1994 Wanderlodge WBSA >>Santa Barbara, CA >> >> >> >> >> >> >>SPONSORED LINKS >><http://groups.yahoo.com/gads?t=ms&k=Recr...3;veh\ icles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5\ =Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn\ _ObWmSYTw>Recreational >>vehicles >><http://groups.yahoo.com/gads?t=ms&k=Wand...&w2=W\ anderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recr\ eational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>\ Wanderlodge >><http://groups.yahoo.com/gads?t=ms&k=Auto...43;ve\ hicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w\ 5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy\ 34cC1O9CxA>Automotive >>maintenance >><http://groups.yahoo.com/gads?t=ms&k=Recr...ation\ al+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea\ ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xaha\ eYHfELr6o72IW1A>Recreational >>vehicle dealer >><http://groups.yahoo.com/gads?t=ms&k=Used...tiona\ l+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal\ er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4\ L-kXbDI4ZSadEw>Used >>recreational vehicles >><http://groups.yahoo.com/gads?t=ms&k=Auto...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTn\ Mq_4GlXA>Automotive >>radiators >> >> >>---------- >>YAHOO! GROUPS LINKS >> >> * Visit your group >>"<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. >> * >> * To unsubscribe from this group, send an email to: >> * >> rlodgeForum-unsubscribe@yahoogroups.com >> >> * >> * Your use of Yahoo! Groups is subject to the >><http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. >> >> >>---------- >> >> > > > > > > > >Yahoo! Groups Links > > > > > > > > > > |
01-04-2006, 13:29
Jerry,
From what I have learned, the Auxiliary Compressor is an 120 VAC unit. If you have the switch on the dash as I have, then you should have the relay in a box at the rear of the driver side baggage bay. I checked into the GAST but found it was a very expensive unit. I picked up a 2 hp 120 VAC compressor from Sears on a close out. I have yet to figure out exactly where to mount it. I already know where the connection is to connect the air and the box with the relay. Mounting it is not at the top of my list yet. I can use it as a portable compressor in the mean time..... George Lowry '95 WBDA 4203 Spearfish, SD ejapilot wrote: >Hi folks, > >Just got done searching past posts about installing an auxiliary air >compressor in the basement of my 94 Wanderlodge WBSA. Is the GAST >compressor the recommended way to go? Or is there a better and more >commonly used compressor that I did not see? > >I need the compressor to pump up my air system without the engine >running, air tires, operate my dump valves, and be available as an >emergency backup in case of engine driven air compressor failure (I >take it 12volt compressor would be required for this). I already have >a compressor that operates the air system for the toilet but I assume >that compressor has to remain solely dedicated to the toilet operation. > >I am going to Quartzsite for the first time this year. Do you folks >know of a particular person/vendor who would be able to install this >auxilliary compressor while I am there? Also, I need a new left side >windshield pane installed. What are the chances that I could get that >done by someone while I am there? I have no clue who to call in >advance to arrange. > >Thanks for any advice/help you can give. > >Jerry Kessler >1994 Wanderlodge WBSA >Santa Barbara, CA > > > > > > > >Yahoo! Groups Links > > > > > > > > > > |
01-04-2006, 14:10
A 120v compressor can extend the life of your 12v compressor for the
toilet also ($$$). The Gast is a nice unit, they are industrial compressors. I'm not sure that this expensive a unit is necessary, you will be primarily concerned with noise so that it doesn't shake and rattle the coach, and the cut-in/cut-out PSI if you want to inflate tires to 115psi or more. Packaging is also an issue, many folks will separate the compressor and tanks and install the compressor only. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "ejapilot" wrote: > > Hi folks, > > Just got done searching past posts about installing an auxiliary air > compressor in the basement of my 94 Wanderlodge WBSA. Is the GAST > compressor the recommended way to go? Or is there a better and more > commonly used compressor that I did not see? > > I need the compressor to pump up my air system without the engine > running, air tires, operate my dump valves, and be available as an > emergency backup in case of engine driven air compressor failure (I > take it 12volt compressor would be required for this). I already have > a compressor that operates the air system for the toilet but I assume > that compressor has to remain solely dedicated to the toilet operation. > > I am going to Quartzsite for the first time this year. Do you folks > know of a particular person/vendor who would be able to install this > auxilliary compressor while I am there? Also, I need a new left side > windshield pane installed. What are the chances that I could get that > done by someone while I am there? I have no clue who to call in > advance to arrange. > > Thanks for any advice/help you can give. > > Jerry Kessler > 1994 Wanderlodge WBSA > Santa Barbara, CA > |
