Auxillary LP connection
01-05-2006, 09:16
On my FC, in between the entry door and the generator tray, there is
a small door that I have been told is where they put the gasoline tank filler on models that came with a gas generator. Since my unit came with a diesel gen, though, there is no gas filler...instead, behind the door is a quick-release socket like that at the end of an air hose (female end). I assumed this was an auxillary air valve. Imagine my surprise when I hooked my air hose and discovered that it is actually a connection into the propane system. My questions are these: 1) Is this a factory feature? I can find no mention of it in any manual in my blue box 2) Was there something in particular this connection was intended to run? Some accessory that came with the coach maybe? 3) If I rig up a hose with a quick-connect end, would it be safe to run propane accessories off this connection? (space heater, grill, cooking burner, etc.) Scott Forman "Tiger Pride" 82 FC35RB Memphis |
01-05-2006, 09:27
Grille connection. I believe that the fitting was a Weber standard.
Might be in the manual, optional equipment in the back of the binder. I'm not sure where the gasoline tank would be in an FC31/33 RB model, but in the SB model it was behind the curbside drive wheel (just ahead of the bumper, half-size storage ahead). Diesel genset was standard on the FC35 Diesels (except WLII) so no fuel-flap. Probably just for the grille. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@r...> wrote: > > On my FC, in between the entry door and the generator tray, there is > a small door that I have been told is where they put the gasoline > tank filler on models that came with a gas generator. Since my unit > came with a diesel gen, though, there is no gas filler...instead, > behind the door is a quick-release socket like that at the end of an > air hose (female end). > > I assumed this was an auxillary air valve. Imagine my surprise when > I hooked my air hose and discovered that it is actually a connection > into the propane system. My questions are these: > > 1) Is this a factory feature? I can find no mention of it in any > manual in my blue box > > 2) Was there something in particular this connection was intended to > run? Some accessory that came with the coach maybe? > > 3) If I rig up a hose with a quick-connect end, would it be safe to > run propane accessories off this connection? (space heater, grill, > cooking burner, etc.) > > Scott Forman > "Tiger Pride" > 82 FC35RB > Memphis > |
01-05-2006, 09:29
Scott,
The propane connection was to hook up the outside cooking grill that came with the Bird. Mike Bulriss 1983 PT40 "Stagecoach" - FOR SALE 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@r...> wrote: > > On my FC, in between the entry door and the generator tray, there is > a small door that I have been told is where they put the gasoline > tank filler on models that came with a gas generator. Since my unit > came with a diesel gen, though, there is no gas filler...instead, > behind the door is a quick-release socket like that at the end of an > air hose (female end). > > I assumed this was an auxillary air valve. Imagine my surprise when > I hooked my air hose and discovered that it is actually a connection > into the propane system. My questions are these: > > 1) Is this a factory feature? I can find no mention of it in any > manual in my blue box > > 2) Was there something in particular this connection was intended to > run? Some accessory that came with the coach maybe? > > 3) If I rig up a hose with a quick-connect end, would it be safe to > run propane accessories off this connection? (space heater, grill, > cooking burner, etc.) > > Scott Forman > "Tiger Pride" > 82 FC35RB > Memphis > |
01-05-2006, 10:47
--- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@y...>
wrote: > > Scott, > > The propane connection was to hook up the outside cooking grill that > came with the Bird. > > Mike Bulriss > 1983 PT40 "Stagecoach" - FOR SALE > 1991 WB40 "Texas Minivan" > San Antonio, TX > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@r...> > wrote: > > > > On my FC, in between the entry door and the generator tray, there is > > a small door that I have been told is where they put the gasoline > > tank filler on models that came with a gas generator. Since my unit > > came with a diesel gen, though, there is no gas filler...instead, > > behind the door is a quick-release socket like that at the end of an > > air hose (female end). > > > > I assumed this was an auxillary air valve. Imagine my surprise when > > I hooked my air hose and discovered that it is actually a connection > > into the propane system. My questions are these: > > > > 1) Is this a factory feature? I can find no mention of it in any > > manual in my blue box > > > > 2) Was there something in particular this connection was intended to > > run? Some accessory that came with the coach maybe? > > > > 3) If I rig up a hose with a quick-connect end, would it be safe to > > run propane accessories off this connection? (space heater, grill, > > cooking burner, etc.) > > > > Scott Forman > > "Tiger Pride" > > 82 FC35RB > > Memphis > > > |
01-05-2006, 10:52
My 91 WL has the auxiliary LP quick connection and I have set it up to supply LP
through the regulators of our grills and our 'artificial' campfire we use when tailgating at Hawkeye games. It is important to remember to cut of the LP flow at the coach quick connect and let the remaining LP in the hose burn off at the grill, this can take a bit more time than you would think, depending on the length of hose you use. Otherwise, if you `quick disconnect' with LP in the hose you have a substantial burst of LP gas coming out, which can be dangerous.>>> >Roger Webb>>91 WBWL>>lace>Cedar Rapids, IAlace>--- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@r...> wrote: > > On my FC, in between the entry door and the generator tray, there is > a small door that I have been told is where they put the gasoline > tank filler on models that came with a gas generator. Since my unit > came with a diesel gen, though, there is no gas filler...instead, > behind the door is a quick-release socket like that at the end of an > air hose (female end). > > I assumed this was an auxillary air valve. Imagine my surprise when > I hooked my air hose and discovered that it is actually a connection > into the propane system. My questions are these: > > 1) Is this a factory feature? I can find no mention of it in any > manual in my blue box > > 2) Was there something in particular this connection was intended to > run? Some accessory that came with the coach maybe? > > 3) If I rig up a hose with a quick-connect end, would it be safe to > run propane accessories off this connection? (space heater, grill, > cooking burner, etc.) > > Scott Forman > "Tiger Pride" > 82 FC35RB > Memphis > [Non-text portions of this message have been removed] |
