Intake Plenum Vacuum Measurement Probe
03-20-2013, 11:31
High resolution and accuracy intake plenum vacuum monitoring:
Attached File(s)
.pdf  Sensor - Low Pressure - Literature - R3.pdf (Size: 339.72 KB / Downloads: 1025)
.pdf  LED Display - Literature - R1.pdf (Size: 589.41 KB / Downloads: 1089)
03-20-2013, 12:13
RE: Intake Plenum Vacuum Measurement Probe
With a couple of switches, you could set a single gauge up to read a whole bunch of stuff.
03-20-2013, 18:02
Is this where the Arduino/Canpod platform with the iPad can fit in? Configure a gauge for vacuum into the system as well as fan speed etc etc?
i am not sure I understand this Arduino thing completely but it would seem to fit here along with a host of other monitoring.
03-20-2013, 18:55 (This post was last modified: 03-20-2013 19:16 by davidbrady.)
You're not kidding Gary. Yet another great sensor to add to our SANduino! Smile
I gotta get busy on this project! That would be this thread, over here: http://wanderlodgegurus.com/Thread-CAT-3208-monitoring
03-21-2013, 00:39 (This post was last modified: 03-21-2013 00:42 by Itchintogo.)
That sounds good. We are breaking new ground here for newer and older coaches alike. Modern day technology in older coaches.
Valuable
The FC crowd in particular may be able to pin point problems with out taking off the front bumper and front body panels and swinging the rad.
Worth a Fortune
I am glad you can work on this and provide something of real value to coach owners that is professionally engineered.
PRICELESS!
At the end of the day you give freely of your expertise as a true gentleman not as a way to make money and won't have a bunch of proprietary stuff you want to sell the members.
Only on WaGu ladies and gentlemen!
03-21-2013, 07:44
Hear, hear!
Well said, and so true. Big Grin
(03-21-2013 00:39)Itchintogo Wrote:  That sounds good. We are breaking new ground here for newer and older coaches alike. Modern day technology in older coaches.
Valuable
Worth a Fortune
PRICELESS!
Jennifer and Darrell Snell
2000 LXi ME SS
