questions
01-09-2006, 10:58
questions
I have several questions to which I would appreciate your input;
What is the best way to purify my fresh water? How often do you do it? My tow bar for my toad is secured by cotter pins. Are they as safe as the the spring loaded pins I used to have on my previous toad? One of my bay doors won't stay up. Is there an easy fix for this? Thanks so much in advance. Dick & Sandy Friedkin Winston, China, Annie & Junior '04 M380 '04 Chrysler Pacifica |
01-09-2006, 13:08
questions
Richard,
The fresh water tank is cleaned annually by most folks that store their coach in the off season.Of course,consistant use will abate that.Simple use of chlorine bleach will keep your tank fresh. The spring type locks are more secure and if you can change them would be best. IMO The bay doors should have gas charged "lift supports" or small shock absorbers which can be matched up at a good parts store or RV store.The Blue Bird parts dept. also will offer them. Fred & Jeanne Hulse Morristown Arizona 1997 Wanderlodge PT41 |
