Air suspension saga continues....
01-15-2006, 08:11
OK, need some help here.
I have a problem with a leaning coach. Last week I posted that I believed I had identified the problem as a torn air bag. However, upon further inspection, here is what I have determined. 1) The air bag I though was blown actually isn't. It is in bad shape and I am going to replace it, but the inner bladder is still intact and it holds air. I can find no evidence of this bag leaking or seeping air...soaped it up real good, no bubbles. 2) All three leveling valves seem to be OK. They are all three fairly new...I did both rears last year and the front appears new, so I am guessing it was done shortly before I got the coach. I know the rears are fine as far as the side-to-side leveling...with the front valve disconnected, the rear axle will air up properly level. 3) So my problem is that the right front fills more than the left front, causing the front of the coach to lean. But since both sides of the front are controlled by one valve, I find myself at a troubleshooting dead end here. Help? Scott Forman 'Tiger Pride' 82 FC35RB Memphis |
01-15-2006, 10:47
Scott,
To get the front level, since it has only one valve for both sides, you need to adjust the rear valves. Raising and lowering one side of the rear or the other will shift the front side to side. BB says to measure front height at the point behind the front wheel. It should be around 16 or 17 inches. You might check with BB on your year and model. If that does not do it, then I am not sure what else to look at. Tom McCarthy '95 PT42 Poway, CA --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@r...> wrote: > > OK, need some help here. > > I have a problem with a leaning coach. Last week I posted that I > believed I had identified the problem as a torn air bag. However, > upon further inspection, here is what I have determined. > > 1) The air bag I though was blown actually isn't. It is in bad shape > and I am going to replace it, but the inner bladder is still intact > and it holds air. I can find no evidence of this bag leaking or > seeping air...soaped it up real good, no bubbles. > > 2) All three leveling valves seem to be OK. They are all three > fairly new...I did both rears last year and the front appears new, so > I am guessing it was done shortly before I got the coach. I know the > rears are fine as far as the side-to-side leveling...with the front > valve disconnected, the rear axle will air up properly level. > > 3) So my problem is that the right front fills more than the left > front, causing the front of the coach to lean. But since both sides > of the front are controlled by one valve, I find myself at a > troubleshooting dead end here. > > Help? > > Scott Forman > 'Tiger Pride' > 82 FC35RB > Memphis > |
01-15-2006, 10:53
Well, since the rear inflates level, I do not think it is the rear
valves. If a rear valve was out of whack, the rear would lean just as the front does...at least as I understand it. When I replaced the rear valves last year, both axles were leaning. --- In WanderlodgeForum@yahoogroups.com, "Tom McCarthy" > > Scott, > > To get the front level, since it has only one valve for both sides, > you need to adjust the rear valves. Raising and lowering one side > of the rear or the other will shift the front side to side. BB says > to measure front height at the point behind the front wheel. It > should be around 16 or 17 inches. You might check with BB on your > year and model. > > If that does not do it, then I am not sure what else to look at. > > Tom McCarthy > '95 PT42 > Poway, CA > > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" > <sforman@r...> wrote: > > > > OK, need some help here. > > > > I have a problem with a leaning coach. Last week I posted that I > > believed I had identified the problem as a torn air bag. However, > > upon further inspection, here is what I have determined. > > > > 1) The air bag I though was blown actually isn't. It is in bad > shape > > and I am going to replace it, but the inner bladder is still > intact > > and it holds air. I can find no evidence of this bag leaking or > > seeping air...soaped it up real good, no bubbles. > > > > 2) All three leveling valves seem to be OK. They are all three > > fairly new...I did both rears last year and the front appears new, > so > > I am guessing it was done shortly before I got the coach. I know > the > > rears are fine as far as the side-to-side leveling...with the > front > > valve disconnected, the rear axle will air up properly level. > > > > 3) So my problem is that the right front fills more than the left > > front, causing the front of the coach to lean. But since both > sides > > of the front are controlled by one valve, I find myself at a > > troubleshooting dead end here. > > > > Help? > > > > Scott Forman > > 'Tiger Pride' > > 82 FC35RB > > Memphis > > > |
01-15-2006, 12:40
. of the front are controlled by one valve, I find myself at a > troubleshooting dead end here. > > Help? > > Scott Forman > 'Tiger Pride' > 82 FC35RB > Memphis > THEN trace out your ft copper lines and fix the 1 that is stopped up or pinched ................ pull them at the bags and measure psi at both points ....... IMO Woody 81fcrbsgd |
01-15-2006, 12:46
First of all you didnt say which side in the front is low? You need
to adjust the rear height adjusters to get the right and left front at the same height and then adjust the front height adjuster to get the front at the correct height. I think you will find that one of the rear height adjusters is misadjusted. Remember that if the right front is low, then you lower the right rear adjuster etc. Tom Warner 1982 FC35 Vernon Center,NY At 07:40 PM 1/15/2006, you wrote: >.> >. of the front are controlled by one valve, I find myself at a > > troubleshooting dead end here. > > > > Help? > > > > Scott Forman > > 'Tiger Pride' > > 82 FC35RB > > Memphis > > > >THEN trace out your ft copper lines and fix the 1 that is stopped up >or pinched ................ > >pull them at the bags and measure psi at both points ....... > >IMO > >Woody 81fcrbsgd > > > > > >SPONSORED LINKS ><http://groups.yahoo.com/gads?t=ms&k=Recr...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_\ ObWmSYTw>Recreational >vehicles ><http://groups.yahoo.com/gads?t=ms&k=Wand...w2=Wa\ nderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre\ ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>W\ anderlodge ><http://groups.yahoo.com/gads?t=ms&k=Auto...3;veh\ icles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5\ =Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy3\ 4cC1O9CxA>Automotive >maintenance ><http://groups.yahoo.com/gads?t=ms&k=Recr...tiona\ l+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal\ er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xahae\ YHfELr6o72IW1A>Recreational >vehicle dealer ><http://groups.yahoo.com/gads?t=ms&k=Used...ional\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L\ -kXbDI4ZSadEw>Used >recreational vehicles ><http://groups.yahoo.com/gads?t=ms&k=Auto...vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnM\ q_4GlXA>Automotive >radiators > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
01-15-2006, 12:47
Could it be that the front leveling valve has some crud in it limiting
the right side air volume/pressure. Take the valve out and check it. Checking line pressure at the bag ends is a good thought...might tell you the front leveling valve is bad or the crud as I mentioned. Good luck. Keep us posted. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. rwoodysurplus wrote: > .> > . of the front are controlled by one valve, I find myself at a > > troubleshooting dead end here. > > > > Help? > > > > Scott Forman > > 'Tiger Pride' > > 82 FC35RB > > Memphis > > > > THEN trace out your ft copper lines and fix the 1 that is stopped up > or pinched ................ > > pull them at the bags and measure psi at both points ....... > > IMO > > Woody 81fcrbsgd > > > > > > SPONSORED LINKS > Recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Recr...vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_O\ bWmSYTw> > Wanderlodge > <http://groups.yahoo.com/gads?t=ms&k=Wand...2=Wan\ derlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recrea\ tional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ> > Automotive maintenance > <http://groups.yahoo.com/gads?t=ms&k=Auto...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34\ cC1O9CxA> > > Recreational vehicle dealer > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeY\ HfELr6o72IW1A> > Used recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Used...onal+\ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer\ &w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-\ kXbDI4ZSadEw> > Automotive radiators > <http://groups.yahoo.com/gads?t=ms&k=Auto...ehicl\ es&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Us\ ed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq\ _4GlXA> > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > |
01-15-2006, 13:07
Scott, from what I understand, given the ground is level, a lean in
the front will create a reverse-lean in the rear on the opposite corner. ie if the driverside front leans down the passanger side rear should pull up. Gregory O'Connor pt Romoland California --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@r...> wrote: > > Well, since the rear inflates level, I do not think it is the rear > valves. If a rear valve was out of whack, the rear would lean just > as the front does...at least as I understand it. When I replaced the > rear valves last year, both axles were leaning. > > > > --- In WanderlodgeForum@yahoogroups.com, "Tom McCarthy" > > > > > Scott, > > > > To get the front level, since it has only one valve for both sides, > > you need to adjust the rear valves. Raising and lowering one side > > of the rear or the other will shift the front side to side. BB > says > > to measure front height at the point behind the front wheel. It > > should be around 16 or 17 inches. You might check with BB on your > > year and model. > > > > If that does not do it, then I am not sure what else to look at. > > > > Tom McCarthy > > '95 PT42 > > Poway, CA > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" > > <sforman@r...> wrote: > > > > > > OK, need some help here. > > > > > > I have a problem with a leaning coach. Last week I posted that I > > > believed I had identified the problem as a torn air bag. > However, > > > upon further inspection, here is what I have determined. > > > > > > 1) The air bag I though was blown actually isn't. It is in bad > > shape > > > and I am going to replace it, but the inner bladder is still > > intact > > > and it holds air. I can find no evidence of this bag leaking or > > > seeping air...soaped it up real good, no bubbles. > > > > > > 2) All three leveling valves seem to be OK. They are all three > > > fairly new...I did both rears last year and the front appears > new, > > so > > > I am guessing it was done shortly before I got the coach. I know > > the > > > rears are fine as far as the side-to-side leveling...with the > > front > > > valve disconnected, the rear axle will air up properly level. > > > > > > 3) So my problem is that the right front fills more than the left > > > front, causing the front of the coach to lean. But since both > > sides > > > of the front are controlled by one valve, I find myself at a > > > troubleshooting dead end here. > > > > > > Help? > > > > > > Scott Forman > > > 'Tiger Pride' > > > 82 FC35RB > > > Memphis > > > > > > |
01-15-2006, 13:47
causing the problem,or the linkage that hooks to the arm,sometimes they slip,or bend,depends on the linkage,replace both rear height control valves,never just one. heres something else to check,the panhard bar bolts,this is the bar that locates the rearend from side to side,if the bolts are worn or broken it aloows the bus to move to the side of the rearend,and the bags on one side will inflate more because of the misalignment. randy dupree 93wb > > Scott, from what I understand, given the ground is level, a lean in > the front will create a reverse-lean in the rear on the opposite > corner. ie if the driverside front leans down the passanger side > rear should pull up. > Gregory O'Connor > pt Romoland California > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" > <sforman@r...> wrote: > > > > Well, since the rear inflates level, I do not think it is the rear > > valves. If a rear valve was out of whack, the rear would lean just > > as the front does...at least as I understand it. When I replaced > the > > rear valves last year, both axles were leaning. > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Tom McCarthy" > > > > > > > > Scott, > > > > > > To get the front level, since it has only one valve for both > sides, > > > you need to adjust the rear valves. Raising and lowering one > side > > > of the rear or the other will shift the front side to side. BB > > says > > > to measure front height at the point behind the front wheel. It > > > should be around 16 or 17 inches. You might check with BB on > your > > > year and model. > > > > > > If that does not do it, then I am not sure what else to look at. > > > > > > Tom McCarthy > > > '95 PT42 > > > Poway, CA > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" > > > <sforman@r...> wrote: > > > > > > > > OK, need some help here. > > > > > > > > I have a problem with a leaning coach. Last week I posted that > I > > > > believed I had identified the problem as a torn air bag. > > However, > > > > upon further inspection, here is what I have determined. > > > > > > > > 1) The air bag I though was blown actually isn't. It is in bad > > > shape > > > > and I am going to replace it, but the inner bladder is still > > > intact > > > > and it holds air. I can find no evidence of this bag leaking > or > > > > seeping air...soaped it up real good, no bubbles. > > > > > > > > 2) All three leveling valves seem to be OK. They are all three > > > > fairly new...I did both rears last year and the front appears > > new, > > > so > > > > I am guessing it was done shortly before I got the coach. I > know > > > the > > > > rears are fine as far as the side-to-side leveling...with the > > > front > > > > valve disconnected, the rear axle will air up properly level. > > > > > > > > 3) So my problem is that the right front fills more than the > left > > > > front, causing the front of the coach to lean. But since both > > > sides > > > > of the front are controlled by one valve, I find myself at a > > > > troubleshooting dead end here. > > > > > > > > Help? > > > > > > > > Scott Forman > > > > 'Tiger Pride' > > > > 82 FC35RB > > > > Memphis > > > > > > > > > > |
01-15-2006, 14:17
OOOPs major brain spasm. If the right front is low then you lower
the LEFT rear adjuster. tom At 07:46 PM 1/15/2006, you wrote: >First of all you didnt say which side in the front is low? You need >to adjust the rear height adjusters to get the right and left front >at the same height and then adjust the front height adjuster to get >the front at the correct height. I think you will find that one of >the rear height adjusters is misadjusted. Remember that if the right >front is low, then you lower the right rear adjuster etc. > >Tom Warner >1982 FC35 >Vernon Center,NY > >At 07:40 PM 1/15/2006, you wrote: > >.> > >. of the front are controlled by one valve, I find myself at a > > > troubleshooting dead end here. > > > > > > Help? > > > > > > Scott Forman > > > 'Tiger Pride' > > > 82 FC35RB > > > Memphis > > > > > > >THEN trace out your ft copper lines and fix the 1 that is stopped up > >or pinched ................ > > > >pull them at the bags and measure psi at both points ....... > > > >IMO > > > >Woody 81fcrbsgd > > > > > > > > > > > >SPONSORED LINKS > ><<http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recr > eational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehic\ le+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=D\ AUkCKkU7Dzhn_ObWmSYTw>http://groups.yahoo.com/gads?t=ms&k=Recr...cles&\ w1=Recreational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreationa\ l+vehicle+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163\ &.sig=DAUkCKkU7Dzhn_ObWmSYTw>Recreational > > >vehicles > ><<http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+v > ehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&\ w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3Q\ LPj9U0JvqYQ>http://groups.yahoo.com/gads?t=ms&k=Wand...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj\ 9U0JvqYQ>Wanderlodge > > ><<http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Rec > reational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehi\ cle+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=\ IF4u_5wI8Pmy34cC1O9CxA>http://groups.yahoo.com/gads?t=ms&k=Auto...enanc\ e&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreatio\ nal+vehicle+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=1\ 63&.sig=IF4u_5wI8Pmy34cC1O9CxA>Automotive > > >maintenance > ><<http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w > 1=Recreational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational\ +vehicle+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&\ .sig=z6_XahaeYHfELr6o72IW1A>http://groups.yahoo.com/gads?t=ms&k=Recreational+veh\ icle+dealer&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4\ =Recreational+vehicle+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiato\ rs&c=6&s=163&.sig=z6_XahaeYHfELr6o72IW1A>Recreational > > >vehicle dealer > ><<http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1 > =Recreational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+\ vehicle+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.\ sig=UGEY5km4L-kXbDI4ZSadEw>http://groups.yahoo.com/gads?t=ms&k=Used+recreational\ +vehicles&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=R\ ecreational+vehicle+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators\ &c=6&s=163&.sig=UGEY5km4L-kXbDI4ZSadEw>Used > > >recreational vehicles > ><<http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recre > ational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicl\ e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=eP\ NVMmISsCWgTnMq_4GlXA>http://groups.yahoo.com/gads?t=ms&k=Auto...rs&w1\ =Recreational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+\ vehicle+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.\ sig=ePNVMmISsCWgTnMq_4GlXA>Automotive > > >radiators > > > > > >---------- > >YAHOO! GROUPS LINKS > > > > * Visit your group > > > "<<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yahoo.com/group/\ WanderlodgeForum>WanderlodgeForum" > on the web. > > * > > * To unsubscribe from this group, send an email to: > > * > > > odgeForum-unsubscribe@yahoogroups.com > > > > > * > > * Your use of Yahoo! Groups is subject to the > > > <<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/>Yahoo! > Terms of Service. > > > > > >---------- > > > > > > >SPONSORED LINKS ><http://groups.yahoo.com/gads?t=ms&k=Recr...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_\ ObWmSYTw>Recreational >vehicles ><http://groups.yahoo.com/gads?t=ms&k=Wand...w2=Wa\ nderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre\ ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>W\ anderlodge ><http://groups.yahoo.com/gads?t=ms&k=Auto...3;veh\ icles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5\ =Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy3\ 4cC1O9CxA>Automotive >maintenance ><http://groups.yahoo.com/gads?t=ms&k=Recr...tiona\ l+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal\ er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xahae\ YHfELr6o72IW1A>Recreational >vehicle dealer ><http://groups.yahoo.com/gads?t=ms&k=Used...ional\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L\ -kXbDI4ZSadEw>Used >recreational vehicles ><http://groups.yahoo.com/gads?t=ms&k=Auto...vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnM\ q_4GlXA>Automotive >radiators > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
01-15-2006, 16:35
Tom,
Shouldn't that be the opposite rear, or left in your hypothetical? Tom McCarthy --- In WanderlodgeForum@yahoogroups.com, Tom Warner wrote: > > First of all you didnt say which side in the front is low? You need > to adjust the rear height adjusters to get the right and left front > at the same height and then adjust the front height adjuster to get > the front at the correct height. I think you will find that one of > the rear height adjusters is misadjusted. Remember that if the right > front is low, then you lower the right rear adjuster etc. > > Tom Warner > 1982 FC35 > Vernon Center,NY > > At 07:40 PM 1/15/2006, you wrote: > >.> > >. of the front are controlled by one valve, I find myself at a > > > troubleshooting dead end here. > > > > > > Help? > > > > > > Scott Forman > > > 'Tiger Pride' > > > 82 FC35RB > > > Memphis > > > > > > >THEN trace out your ft copper lines and fix the 1 that is stopped up > >or pinched ................ > > > >pull them at the bags and measure psi at both points ....... > > > >IMO > > > >Woody 81fcrbsgd > > > > > > > > > > > >SPONSORED LINKS > ><http://groups.yahoo.com/gads? t=ms&k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge& w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recr eational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzh n_ObWmSYTw>Recreational > >vehicles > ><http://groups.yahoo.com/gads? t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automot ive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+v ehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z- 8HJdysB3QLPj9U0JvqYQ>Wanderlodge > ><http://groups.yahoo.com/gads? t=ms&k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge &w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+rec reational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pm y34cC1O9CxA>Automotive > >maintenance > ><http://groups.yahoo.com/gads? t=ms&k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wander lodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xah aeYHfELr6o72IW1A>Recreational > >vehicle dealer > ><http://groups.yahoo.com/gads? t=ms&k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderl odge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used +recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km 4L-kXbDI4ZSadEw>Used > >recreational vehicles > ><http://groups.yahoo.com/gads? t=ms&k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w 3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgT nMq_4GlXA>Automotive > >radiators > > > > > >---------- > >YAHOO! GROUPS LINKS > > > > * Visit your group > > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > > * > > * To unsubscribe from this group, send an email to: > > * > > > > > > * > > * Your use of Yahoo! Groups is subject to the > > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > > > > >---------- > |
