tail lights
01-15-2006, 16:02
tail lights
My tail lights quit working, so I started at the breaker behind the
driver side headlight (breaker#6) I have power leaving there. I checked at the terminal block above the batterys and it is dead there, so I opened up the dash to get to the switch and I have power there. With the switch in the parking lights position the dash lights up green and the parking (tail)lights come on like they should(2 of the 4 tail lights). With the switch in the headlights position the headlights come on but no taillights, but the break lights work fine. My question how does it get from the switch to the terminal block above the batterys? Is there a relay or some other fuse between the switch and the terminal block. Also does anyone have a wiring diagram for the headlight switch. The switch has 6 wires red= hot green= hot orange= headlights blue= guage lights black/orange= parking & green dash lights (crimped together on same lug) with this setup I'm not sure how you can turn on the tail lights without using the orange from the headlights, because the black/orange wires are dead when the switch is in the headlight position. Otherwise the dash would be glowing green anytime the headlights were on, but that would turn on the tail lights ![]() Thanks Bruce Campbell Clearwater, FL 83'FC 35 SB "Blue Skies" |
01-16-2006, 00:52
tail lights
Bruce,
Try to connect an independent, temporary ground to the tail lights in order to rule out a ground problem early in the diagnosis. My experience has been, 9 out of 10 times, the ground has been at fault when I received otherwise confusing results. John Suter P.S. your yahoo account below, indicates no longer in service. --- fl_bluebird_1983 wrote: > My tail lights quit working, so I started at the > breaker behind the > driver side headlight (breaker#6) I have power > leaving there. I > checked at the terminal block above the batterys and > it is dead > there, so I opened up the dash to get to the switch > and I have power > there. With the switch in the parking lights > position the dash lights > up green and the parking (tail)lights come on like > they should(2 of > the 4 tail lights). With the switch in the > headlights position the > headlights come on but no taillights, but the break > lights work fine. > My question how does it get from the switch to the > terminal block > above the batterys? Is there a relay or some other > fuse between the > switch and the terminal block. Also does anyone have > a wiring diagram > for the headlight switch. The switch has 6 wires > red= hot > green= hot > orange= headlights > blue= guage lights > black/orange= parking & green dash lights (crimped > together on same > lug) > > with this setup I'm not sure how you can turn on the > tail lights > without using the orange from the headlights, > because the > black/orange wires are dead when the switch is in > the headlight > position. Otherwise > the dash would be glowing green anytime the > headlights were on, but > that would turn on the tail lights ![]() > > Thanks > Bruce Campbell > Clearwater, FL > 83'FC 35 SB > "Blue Skies" > > > > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com |
01-16-2006, 01:38
tail lights
The lights work when you pull the knob up one click (parking lights)
but they don't when the switch is in the headlight position (tail lights) SO I don't think it's a ground problem, but you are right grounds are a problem alot of the time! Thanks Bruce Campbell Clearwater, FL 83'FC 35 SB "Blue Skies" --- In WanderlodgeForum@yahoogroups.com, John Suter wrote: > > Bruce, > > Try to connect an independent, temporary ground to > the tail lights in order to rule out a ground problem > early in the diagnosis. My experience has been, 9 out > of 10 times, the ground has been at fault when I > received otherwise confusing results. > > John Suter > P.S. your yahoo account below, indicates no longer in > service. > > > --- fl_bluebird_1983 > wrote: > > > My tail lights quit working, so I started at the > > breaker behind the > > driver side headlight (breaker#6) I have power > > leaving there. I > > checked at the terminal block above the batterys and > > it is dead > > there, so I opened up the dash to get to the switch > > and I have power > > there. With the switch in the parking lights > > position the dash lights > > up green and the parking (tail)lights come on like > > they should(2 of > > the 4 tail lights). With the switch in the > > headlights position the > > headlights come on but no taillights, but the break > > lights work fine. > > My question how does it get from the switch to the > > terminal block > > above the batterys? Is there a relay or some other > > fuse between the > > switch and the terminal block. Also does anyone have > > a wiring diagram > > for the headlight switch. The switch has 6 wires > > red= hot > > green= hot > > orange= headlights > > blue= guage lights > > black/orange= parking & green dash lights (crimped > > together on same > > lug) > > > > with this setup I'm not sure how you can turn on the > > tail lights > > without using the orange from the headlights, > > because the > > black/orange wires are dead when the switch is in > > the headlight > > position. Otherwise > > the dash would be glowing green anytime the > > headlights were on, but > > that would turn on the tail lights ![]() > > > > Thanks > > Bruce Campbell > > Clearwater, FL > > 83'FC 35 SB > > "Blue Skies" > > > > > > > > > > > > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com > |
07-13-2006, 00:52
tail lights
Can anyone provide a source for the taillight assemblies for our 91
WLWB. They have Volvo stamped in the lense and a number (88063). If not a source, I'd like to know what year and model Volvo these lenses fit. Thanks in advance. Tom Gibbs 91 WLWB currently in New Smyrna Beach, FL |
07-13-2006, 01:34
tail lights
go to http://www.vlvworld.com
they seem to be less than a hundred bucks Stephen 77fc35 with really old lights --- In WanderlodgeForum@yahoogroups.com, "cudjoekeytom" > > Can anyone provide a source for the taillight assemblies for our 91 > WLWB. They have Volvo stamped in the lense and a number (88063). If > not a source, I'd like to know what year and model Volvo these lenses > fit. > > Thanks in advance. > > Tom Gibbs > 91 WLWB > currently in New Smyrna Beach, FL > |
07-13-2006, 03:12
tail lights
Thanks. Now I just need to figure out which ones are used on the
coach. The ones on my bird look like the 90-92 740 taillights , but they could be the 740 lights that are earlier. anybody know which model year they are for? Thanks Tom Gibbs 91 WLWB New Smyrba Beach, FL --- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" > > go to http://www.vlvworld.com > they seem to be less than a hundred bucks > > Stephen 77fc35 with really old lights > > > > --- In WanderlodgeForum@yahoogroups.com, "cudjoekeytom" > > > > > Can anyone provide a source for the taillight assemblies for our 91 > > WLWB. They have Volvo stamped in the lense and a number (88063). If > > not a source, I'd like to know what year and model Volvo these lenses > > fit. > > > > Thanks in advance. > > > > Tom Gibbs > > 91 WLWB > > currently in New Smyrna Beach, FL > > > |
07-13-2006, 03:48
tail lights
wrote: > > Can anyone provide a source for the taillight assemblies for our 91 > WLWB. They have Volvo stamped in the lense and a number (88063). If > not a source, I'd like to know what year and model Volvo these lenses > fit. > > Thanks in advance. > > Tom Gibbs > 91 WLWB > currently in New Smyrna Beach, FL > Tail light lens Fits 90-92 Volvo 740 Sedan --Lt Volvo # 3518175 or TVV8171,Rt Volvo # 3518176 or TVV8172. Roger Webb 91WL Cedar Rapids, IA |
07-13-2006, 04:52
tail lights
While we're discussing lights ... I recall someone mentioning that
the '95 (and some years before/after) have Ford truck headlight assemblies. Does anyone have the year and a source? After washing my rig, I notice that I have moisture inside the lens of one of the head lights. Is there a gasket kit or do I need to replace the whole assembly? Thanks. Pete Masterson aeonix1@... '95 Bluebird Wanderlodge WBDA 4203 El Sobrante, CA On Jul 13, 2006, at 8:48 AM, rogerwwebb wrote: > --- In WanderlodgeForum@yahoogroups.com, "cudjoekeytom" > > wrote: >> >> Can anyone provide a source for the taillight assemblies for our 91 >> WLWB. They have Volvo stamped in the lense and a number (88063). If >> not a source, I'd like to know what year and model Volvo these lenses >> fit. >> >> Thanks in advance. >> >> Tom Gibbs >> 91 WLWB >> currently in New Smyrna Beach, FL >> > Tail light lens Fits 90-92 Volvo 740 Sedan --Lt Volvo # 3518175 or > TVV8171,Rt Volvo # 3518176 or TVV8172. > > Roger Webb > 91WL > Cedar Rapids, IA > > [Non-text portions of this message have been removed] |
04-07-2007, 08:03
tail lights
iam looking to start a new project on the bus and its going to be those
dim and dull tail lights. also going to redo the trailer plug. how about some input on the best way to get those tail lights and brake lights to shine bright. also on the trailer plug , lights are also dim. has anyone changed these lights to lcd. thanks for your input. ed and peggy mcstay 83FC 35FT rear bath "lonesome dove" |
04-07-2007, 10:56
tail lights
Ed,
Check out; For Taillight upgrade http://www.pbase.com/image/50381811 For Headlight upgrade http://www.pbase.com/iamflagman/image/32546768 Click on "NEXT" at the right of each page for more information. "REMEMBER SEPTEMBER 11, 2001" John Finn '82 35FCRB BLUEBIRD WANDERLODGE TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE GO TO; http://www.pbase.com/image/24977457 HOPKINS, SOUTH CAROLINA ////////////////////////////////////////////////// --- In WanderlodgeForum@yahoogroups.com, "Peggy & Ed McStay" > > iam looking to start a new project on the bus and its going to be those > dim and dull tail lights. also going to redo the trailer plug. how > about some input on the best way to get those tail lights and brake > lights to shine bright. also on the trailer plug , lights are also dim. > has anyone changed these lights to lcd. thanks for your input. > > > ed and peggy mcstay > 83FC 35FT rear bath > "lonesome dove" > |
