remove/microwave/convection
01-23-2006, 16:11
Does any one know how to remove the microwave in a 1984 1/2?
Called BB and Benny was no help. I can not seem to find the screws that are holding it in. remove the top panel but the their is a hose laying across the top of micro. for A/C Joe 1984 1/2 PT 40 |
01-23-2006, 16:42
On my '84 PT40 I first removed the grill surrounding the unit, removed
a small bracket inside the microwave cabinet and then found a couple of screws above the cooktop that went into the bottom of the microwave. Removed those and pulled out the unit. It was interesting to see how well built these birds are. Just about bullet-proof. That is the main reason I am doing a restoration on my bird - I haven't found anything that comes close to the solid construction and I like to rebuild old things. I plan to call our unit "Renewal" primarily because It will renew my spirit when we travel around in it. OK, OK - I know that's a little hokey, but hey, it's late!!! Good Luck! Roger Little Rock, 1984 PT40WL --- In WanderlodgeForum@yahoogroups.com, "mjzakowski" <mjzakowski@j...> wrote: > > Does any one know how to remove the microwave in a 1984 1/2? > Called BB and Benny was no help. I can not seem to find the screws > that are holding it in. remove the top panel but the their is a hose > laying across the top of micro. for A/C > Joe 1984 1/2 PT 40 > |
01-25-2006, 12:58
Here are 2 write up's from my "Interior Tips" file that I saved from
the forum: HTH, Steve Harrie '86 PT38 The Micro lives in a box, the top and left side of which are cabinet plywood and the bottom and right side are made of stainless steel. Then the bottom has a thin layer of insulation which is overtopped by another layer of stainless: a single sheet that wraps around the bottom and right side. (BTW, my galley is on the pilot's side). I had to remove the trim, then remove the screws in the back panel above the stove (under the micro) and the ones in the side panel above the toaster (the right side of the micro and well to its rear). The outer stainless panel is a jam fit between the inner stainless panel and, on the bottom, the stove's back panel, and on the right, the sides of the oversink cabinets. It is a bear to get out and even worse to get back in. Be sure you take out every screw that even looks like it could reach. I even removed the eyeball light over the stove, though that turned out to be unnecessary (although the hole turned out to be handy for pulling down the panel to get the stainless started back in there upon reassembly). All this removal of trim, stainless steel panel, and insulation is solely for the purpose of exposing the heads of two screws that are run through the inner stainless into the bottom of the micro to keep it from drifting around the coach. I made new holes in the bottom of the micro so as to use the existing holes in the stainless (to secure the new one). I now wish that I had drilled the outer stainless to match the holes in the inner stainless so that I wouldn't have to go through this again the next time the micro goes belly up. BTW, while you're in there, after you get the micro out, check out the wiring that runs behind it. I found a multi- conductor, wrapped cable that was resting on a ridiculously long quarter inch bolt, just waiting to wear through the insulation and short out. I bent the bolt back against the wall so the cable was resting on wood. 86PT40 In my 1993, there is a small compartment over the oven. There are 2 long screws up there supposedly holding the oven. There is a little boxed in area, on the right hand side of this compartment and one of the holding screws is supposedly in that box, along with the electrical receptacle. Under the oven, at the very back and in front of the mirrors, there is a bar and it has two screws. One is supposed to loosen them and the oven will lift off of that bar. We'll see. This oven is heavy. |
