Wanderlodge Map
01-27-2006, 03:38
Wanderlodge Map
And don't forget, the map forum is free. Ernie-83pt40 heading to La in the am
01-27-2006, 07:08
Wanderlodge Map
I want to remind you all about the Wanderlodge map at
http://www.frappr.com/wanderlodge which was established as a potential aid
for travelers, or for planning local rallies and get-togethers.
With 750+ members here, only 112 have opted to put their locator pins
on the map. Even at that, it is getting easy to see where some new
regional BB Rallies need to be planned.
Recent changes on the map were made to allow you to change the color
of your map locator. I added a legend to distinguish between
Wanderlodge models. I changed most of the folks that I knew of, or
who had listed their Bird model in their comments. If you signed up
for a Frappr membership when you listed your map location, you can
edit your own information. If you listed the map pin before
memberships existed over there, you can go get a membership now and
re-add yourself, or you can just notify the Wanderlodge map admin (me)
to change your information.
Thanks,
1983 PT40 "Stagecoach" - For Sale
1991 WB40 "Texas Minivan"
01-28-2006, 05:25
Wanderlodge Map
Mike,
How do you change personal info and message on Frapp site.
Howard Truitt
Camilla, Ga.
86 PT40
Sent: Friday, January 27, 2006 2:08 PM
Subject: [WanderlodgeForum] Wanderlodge Map
Thanks,
YAHOO! GROUPS LINKS
01-28-2006, 06:36
Wanderlodge Map
Howard,
If you signed up for a Frappr membership when you listed your map
location, you can edit your own information.
It appears that you did not sign up for a Frappr membership (which is
free) when you joined the map. When it first started, the membership
feature did not exist.
If you did not sign up for a membership and just listed your map pin,
or if you signed up before memberships existed over there, you have
two choices:
1) you can go get a membership now and then re-add yourself to the
map, at which point you can make any changes, or
2) you can just notify the Wanderlodge map admin (me) offline to
change your information for you.
Whether you have Frappr membership or not, you should be able to add
to your original shoutout at any time by simply entering your name,
zip code and new shoutout info. The old shoutout info remians unless
you delete it (if you have a membership) or you have the admin delete it.
There is a list of frequently asked questions for the Frappr maps at
http://www.frappr.com/?a=doc§ion=faq#9
Let me know if you need anything changed.
Thanks,
--- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt"
> Mike,
> Howard Truitt
> Camilla, Ga.
> 86 PT40
> From: mbulriss
> Thanks,
> Mike Bulriss
> San Antonio, TX
> YAHOO! GROUPS LINKS
Service.
