Tachometer on my '86 PT 38'
01-27-2006, 10:54
Jay and Scott,
Thanks for the info...I guess that pressure washer got the better of me. It's about 55 degrees right now, and too cold to go out and look right now, but in the morning, I'll take a peek. Thanks again. Kevin McKeown YL CA 86 38 PT [Non-text portions of this message have been removed] |
01-27-2006, 14:04
Greetings,
Been doing a bunch of little things to my BB, and I've noticed that my tach is acting wierd. Is the tach electronic, picking up it's signal from the alternator, or, is there a sending unit of some sort on the 8V92 somewhere? I gave the engine a good pressure washing a couple of days ago...maybe I washed something I shouldn't have. The tach reads normal at idle, and when going to high idle, it climbs like normal, then it's all over the dial. There is a 12ga wire attached to the batt post on the alternator (along with the heavy output battery cable), but removing this little wire does nothing to the tach...any idea where the other end of this wire goes, and what it's for? I guessing that the engine has a tach sending unit somewhere...any help would be appreciated. BTW, I'm still looking for that pesky air compressor governor...I bought a new one to see what it looks like, but hell, I can't find it where everyone tells me to look (Benny at BB said it was curb side, inside the frame rail, just ahead of the engine, but I guess I'm blind!) Help please...I don't feel comfortable driving without a dependable tachometer (playing the radio, you can't even hear the engine in a PT...sorry, all FC owners!) Thanks Kevin McKeown Yorba Linda, CA 1986 38' PT |
01-27-2006, 14:48
Kevin,
The tach sending unit is in the "V" of the engine, more towards the curb side and at the front of the engine. Probably about 1 1/2" diameter, has 2 wires coming out of it. My tach started acting goofy, so I bought a used sending unit for $20(Holland Motorhomes). Lean over the batteries with flashlight in hand, look at passenger side of the "V" at the front of the motor(still on top of the motor in the "V"). A pretty easy part to replace. The air governor is just forward of the air compressor. The air compressor is mounted on the front of the engine, above the transmission. The air governor is just forward of the compressor and mounted on the inside of the frame rail. I would pay somebody to change the governor. Claustrophobia got me before I could lay a wrench on it. You have to be skinny enough to fit between the transmission case and the frame rail and have arms at least 40 inches long and not need to see what your doing with your qarms in the way. I paid $35 Labor to have my air governor replaced after trying to get to it myself. Jay Darst 85PT40 Springfield, IL --- In WanderlodgeForum@yahoogroups.com, "Kevin McKeown" > > Greetings, > > Been doing a bunch of little things to my BB, and I've noticed that > my tach is acting wierd. Is the tach electronic, picking up it's > signal from the alternator, or, is there a sending unit of some sort > on the 8V92 somewhere? I gave the engine a good pressure washing a > couple of days ago...maybe I washed something I shouldn't have. > > The tach reads normal at idle, and when going to high idle, it > climbs like normal, then it's all over the dial. There is a 12ga > wire attached to the batt post on the alternator (along with the > heavy output battery cable), but removing this little wire does > nothing to the tach...any idea where the other end of this wire > goes, and what it's for? > > I guessing that the engine has a tach sending unit somewhere...any > help would be appreciated. > > BTW, I'm still looking for that pesky air compressor governor...I > bought a new one to see what it looks like, but hell, I can't find > it where everyone tells me to look (Benny at BB said it was curb > side, inside the frame rail, just ahead of the engine, but I guess > I'm blind!) > > Help please...I don't feel comfortable driving without a dependable > tachometer (playing the radio, you can't even hear the engine in a > PT...sorry, all FC owners!) > > Thanks > > > Kevin McKeown > Yorba Linda, CA > 1986 38' PT > [Non-text portions of this message have been removed] |
01-27-2006, 15:09
Now that Jay got you to the tach sending unit, if you remove the unit you will
find it is driven by a very short drive cable, like a speedometer cable. If you're frugal, you can clean and lube that cable, and shoot some lube into the sending unit too. That fixed mine, but mine was erratic only at idle, and would smooth out as the revs climbed. Scott Peatross '87PT40 Jay Darst Kevin, The tach sending unit is in the "V" of the engine, more towards the curb side and at the front of the engine. Probably about 1 1/2" diameter, has 2 wires coming out of it. My tach started acting goofy, so I bought a used sending unit for $20(Holland Motorhomes). Lean over the batteries with flashlight in hand, look at passenger side of the "V" at the front of the motor(still on top of the motor in the "V"). A pretty easy part to replace. The air governor is just forward of the air compressor. The air compressor is mounted on the front of the engine, above the transmission. The air governor is just forward of the compressor and mounted on the inside of the frame rail. I would pay somebody to change the governor. Claustrophobia got me before I could lay a wrench on it. You have to be skinny enough to fit between the transmission case and the frame rail and have arms at least 40 inches long and not need to see what your doing with your qarms in the way. I paid $35 Labor to have my air governor replaced after trying to get to it myself. Jay Darst 85PT40 Springfield, IL --- In WanderlodgeForum@yahoogroups.com, "Kevin McKeown" > > Greetings, > > Been doing a bunch of little things to my BB, and I've noticed that > my tach is acting wierd. Is the tach electronic, picking up it's > signal from the alternator, or, is there a sending unit of some sort > on the 8V92 somewhere? I gave the engine a good pressure washing a > couple of days ago...maybe I washed something I shouldn't have. > > The tach reads normal at idle, and when going to high idle, it > climbs like normal, then it's all over the dial. There is a 12ga > wire attached to the batt post on the alternator (along with the > heavy output battery cable), but removing this little wire does > nothing to the tach...any idea where the other end of this wire > goes, and what it's for? > > I guessing that the engine has a tach sending unit somewhere...any > help would be appreciated. > > BTW, I'm still looking for that pesky air compressor governor...I > bought a new one to see what it looks like, but hell, I can't find > it where everyone tells me to look (Benny at BB said it was curb > side, inside the frame rail, just ahead of the engine, but I guess > I'm blind!) > > Help please...I don't feel comfortable driving without a dependable > tachometer (playing the radio, you can't even hear the engine in a > PT...sorry, all FC owners!) > > Thanks > > > Kevin McKeown > Yorba Linda, CA > 1986 38' PT > [Non-text portions of this message have been removed] --------------------------------- YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- [Non-text portions of this message have been removed] |
