Understanding Electrical Systems
01-29-2006, 09:07
I am debating how "educated" I need to become before troubleshooting
and/or repairing some electrical issues I am having. The coach is new to me and has been in the shop for the past month getting many things repaired. One of the items repaired was the Freedom 25 inverter. It was found that the inverter received an electrical spike of some sort and several critical parts were damaged. I was told this could occur either by bad shore power or by a lightning strike. Right now there are several things that I don't understand and need to figure out if there is trouble somewhere that needs to be repaired. 1. Alternator Fault - When the engine is running ALT1 fault light is on. 2. Shore Power Polarity - The polarity light does not indicate good or bad polarity when plugged into shore power. 3. Xantrex Link 2000 - When everything is shut off (master electrical switch and AT switch) the Link 2000 is still on. 4. LoBat - Within a few days, it appears that the batteries are already low (I do not have the coach plugged into shore power). I have read through the Link 2000 manual and it appears that there are many settings in being sure the batteries are used and charged correctly. The first thing was to determine the type of batteries being used. It took me several hours just to figure out the kind of batteries they are and I am still not 100% certain. They are Deka 8G4D and I believe they are Gelled and not Sealed Absorbed. There are 4 batteries with 6 cells each and 2.35 V per cell at 68 degrees. There are many questions I have in addition to the items above (obviously I am not electrically inclined): 1. Should I just hire an "expert" and have them check the entire system and train me on managing power? Any "BB experts" that can be recommended? 2. Or, do I just take my time and learn everything myself risking damage to systems and delaying the time that we can use the coach? 3. Are the batteries being damaged right now? 4. On our first trip I would like to believe that the electrical system is functioning correctly (we don't have an immediate trip planned, but I will plan a trip only when I know the problems are resolved). 5. Are the settings of Link 2000 interface correct? What are the correct settings? 6. Are the batteries bad? Or, is there something out of the ordinary draining the batteries? 7. Is the alternator bad? How do the 2 alternators work? My engine mechanic did not indicate that there were any problems with the alternators. He was pretty thorough in checking everything. 8. What is the best way to store the coach in cold weather? Can I plug it into a 20 amp house circuit just to keep the batteries up? Do I need to install a 30 or 50 amp circuit ASAP in order to store the coach properly? 9. Are there good "RV Electrical Systems for Dummies" resources out there? 10. Are BBs so complicated and/or specialized that basic RV electrical information would not be helpful? Brian Gatley 93 WLWB PT40 Bend, OR [Non-text portions of this message have been removed] |
01-29-2006, 11:35
Hi Brian,
First, I am NOT a BB expert. I have owned a BB and have also designed and converted a Greyhound bus. I have a little knowledge and will share what I know. Second, there are few BB experts. None that are close to you. Jeff Miller, Holland, Mich., Ralph Fullenwider, Duncan, OK, and George Morris, who works for Bleakley RV in GA are the only ones that I know that are reasonably well versed in BBs. George Morris was the top tech for BB before they fired him. Another source of electrical information that is relatively close to you is Dick Wright in Eugene, OR. Dick owns Wrico Generators and is into bus conversions and has a great overall knowledge of the electrical systems of higher line coaches. I would suggest that you contact him and see if he can check your system out or suggest someone in your area that is competent to do it. The systems on the BB are far more sophisticated than the average car or truck mechanic has ever seen. They could cost you more as they are trying to learn.... Some thoughts: On some coaches, you must rev up the engine before the alternator will cut in. I don't believe the Link 2000 was original equipment. When I talked to BB about the Link, they were not knowledgeable about it. IF you have the Link 2000R, the "R" designates the regulator version. The standard voltage regulator is replaced with an electronic regulator which turns the alternator into a three stage charging system. This is an excellent system, however, it may not be correctly connected in your coach. The Shore power Polarity system is manufactured by PMMI. Check out the files section for their address and phone number. I have heard of others that have had theirs repaired by them. The Link 2000 can be connected so that it stays on or goes off when the battery master is turned off. Only way to check that is to trace the wiring, preferably with the installation instructions in hand. In theory, when the master electrical switches are off, everything should be off. There are usually two switches, a master switch in the battery or engine compartment and the master electronics switch which was in the compartment with the VCR, etc. in the front overhead compartment. Again, someone may have wired things differently over the last 13 years. I kept mine plugged in just to keep the batteries up. BB has numerous drains on the system that seems to draw the batteries down. Your batteries are Gell, absorbed electrolyte, sealed valve regulated non-spillable battery. Refer to <http://www.eastpenn-deka.com/products/pdfs/c.pdf> for more information. BB used these batteries in the coaches in the time period yours was built. They may be the original batteries. You need to find someone that is knowledgeable about the Deka batteries to check them out. You have a sophisticated system there that most mechanics will not understand. I suggest going to <http://www.amplepower.com> and reading all you can on 12V power. He also has some good books. I have found that having at least some knowledge is valuable because the "mechanic" may not have any but will still work on it at your expense. Hope this helps you, George Lowry '06 Alpine Apex formerly owned a '95 WBDA 4203 Spearfish, SD Enjoying the warmth in Palm Springs. Brian Gatley wrote: >I am debating how "educated" I need to become before troubleshooting >and/or repairing some electrical issues I am having. > >The coach is new to me and has been in the shop for the past month >getting many things repaired. > >One of the items repaired was the Freedom 25 inverter. It was found >that the inverter received an electrical spike of some sort and several >critical parts were damaged. I was told this could occur either by bad >shore power or by a lightning strike. > >Right now there are several things that I don't understand and need to >figure out if there is trouble somewhere that needs to be repaired. > >1. Alternator Fault - When the engine is running ALT1 fault light is on. > >2. Shore Power Polarity - The polarity light does not indicate good or >bad polarity when plugged into shore power. > >3. Xantrex Link 2000 - When everything is shut off (master electrical >switch and AT switch) the Link 2000 is still on. > >4. LoBat - Within a few days, it appears that the batteries are already >low (I do not have the coach plugged into shore power). > >I have read through the Link 2000 manual and it appears that there are >many settings in being sure the batteries are used and charged >correctly. > >The first thing was to determine the type of batteries being used. It >took me several hours just to figure out the kind of batteries they are >and I am still not 100% certain. > >They are Deka 8G4D and I believe they are Gelled and not Sealed >Absorbed. There are 4 batteries with 6 cells each and 2.35 V per cell >at 68 degrees. > >There are many questions I have in addition to the items above >(obviously I am not electrically inclined): > >1. Should I just hire an "expert" and have them check the entire system >and train me on managing power? Any "BB experts" that can be >recommended? > >2. Or, do I just take my time and learn everything myself risking damage >to systems and delaying the time that we can use the coach? > >3. Are the batteries being damaged right now? > >4. On our first trip I would like to believe that the electrical system >is functioning correctly (we don't have an immediate trip planned, but I >will plan a trip only when I know the problems are resolved). > >5. Are the settings of Link 2000 interface correct? What are the >correct settings? > >6. Are the batteries bad? Or, is there something out of the ordinary >draining the batteries? > >7. Is the alternator bad? How do the 2 alternators work? My engine >mechanic did not indicate that there were any problems with the >alternators. He was pretty thorough in checking everything. > >8. What is the best way to store the coach in cold weather? Can I plug >it into a 20 amp house circuit just to keep the batteries up? Do I need >to install a 30 or 50 amp circuit ASAP in order to store the coach >properly? > >9. Are there good "RV Electrical Systems for Dummies" resources out >there? > >10. Are BBs so complicated and/or specialized that basic RV electrical >information would not be helpful? > >Brian Gatley >93 WLWB PT40 >Bend, OR > > > > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > > > > > > > > |
01-29-2006, 15:00
Hello Brian:
Certainly some skills with a multimeter and amp meter are a definite plus when it come to working on Birds or even home systems and an understanding of schematics and the theory of electrical circuits are a good place to start. You don't need ohms law to read a meter but it helps and a darn good understanding of series/parallel circuits is a must read. Example of that is; a Coach has 6 12 vdc deep cycle batteries wired series parallel gives you three banks of 12 vdc output. If you replace those batteries with 12 vdc batteries and wire them series parallel you will get 24 vdc out put to everything in the Coach and most 12 volt dc systems will pop it's buttons. So an understanding of that system I would say is required reading. There are several good manuals on the market that gives a good understanding of DC electrical 101. Then of course knowing how relay logic works is a must. All this can be done with a good read. Ok, freedom inverter and the Link 2000; If you simply switch off the switch on the inverter, the link 2K should go out, if not then I would seriously take a look at the on and off switch on the inverter. Alt fault light; As stated, you may not have a problem with your alts and the fault could simply be indicated due to a bad Bosh relay. Those relays should be located behind the curb side grill in the upper portion above the Primus boilers ( if you have Primus). On the back fire wall, in that same area you will see a series of circuit breakers and to the left of those will or should be 3 shunts. Attached to the center shunt should be 2 large cables with red taped ends and those ends are the feeds from the alternators. This info is for locational value alone. One question I always ask a new owner;"Have you read your manual?" This is in no way trying to be offensive but to drive home that there is a multitude of important information there and much will "come to light" with a little study. Even though the master switches are off and the master electronic switch is off, there are some systems that stay energized by design so a few days of dis charge is more or less a normal thing. Battery maint is primary in these Coaches. Ok, the polarity indicaters: Doug Hampton of PMMI is a member if this forum, contact Doug ( a darn nice guy by the way) and set up how to ship your units to PMMI for repair. And if you do this, be sure that the GFI mod is added to the unit. Winter storage is a Coach by Coach thing. It depends on where the Coach is stored what part of the Country it is stored in and so forth. If you plug into the house 20 amp circuit with your 50 amp cord and an adapter, your chargers will work and you can run one electric heater in the Coach. Open the doors to the kitchen sink and the bathroom sink, turn on the bath electric heater and it will keep the interior of your Coach at an even 52 degrees F through out. You can even leave the refer and ice maker on with a 20 amp circuit. Lets talk relay logic a moment. Usually a switch will not handle the amperage needed for most circuits, so how is this amperage controlled. It is done with relays that have 20/30 or 30/40 amp contacts that will handle the amperage. So in effect the switch on the dash energizes the "coil" of a relay and allows the amperage to flow across contacts that were open until the relay "pulled" in. Enough 101, sorry if this is a little too long. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 01:07 PM 1/29/2006 -0800, you wrote: >I am debating how "educated" I need to become before troubleshooting >and/or repairing some electrical issues I am having. > >The coach is new to me and has been in the shop for the past month >getting many things repaired. > >One of the items repaired was the Freedom 25 inverter. It was found >that the inverter received an electrical spike of some sort and several >critical parts were damaged. I was told this could occur either by bad >shore power or by a lightning strike. > >Right now there are several things that I don't understand and need to >figure out if there is trouble somewhere that needs to be repaired. > >1. Alternator Fault - When the engine is running ALT1 fault light is on. > >2. Shore Power Polarity - The polarity light does not indicate good or >bad polarity when plugged into shore power. > >3. Xantrex Link 2000 - When everything is shut off (master electrical >switch and AT switch) the Link 2000 is still on. > >4. LoBat - Within a few days, it appears that the batteries are already >low (I do not have the coach plugged into shore power). > >I have read through the Link 2000 manual and it appears that there are >many settings in being sure the batteries are used and charged >correctly. > >The first thing was to determine the type of batteries being used. It >took me several hours just to figure out the kind of batteries they are >and I am still not 100% certain. > >They are Deka 8G4D and I believe they are Gelled and not Sealed >Absorbed. There are 4 batteries with 6 cells each and 2.35 V per cell >at 68 degrees. > >There are many questions I have in addition to the items above >(obviously I am not electrically inclined): > >1. Should I just hire an "expert" and have them check the entire system >and train me on managing power? Any "BB experts" that can be >recommended? > >2. Or, do I just take my time and learn everything myself risking damage >to systems and delaying the time that we can use the coach? > >3. Are the batteries being damaged right now? > >4. On our first trip I would like to believe that the electrical system >is functioning correctly (we don't have an immediate trip planned, but I >will plan a trip only when I know the problems are resolved). > >5. Are the settings of Link 2000 interface correct? What are the >correct settings? > >6. Are the batteries bad? Or, is there something out of the ordinary >draining the batteries? > >7. Is the alternator bad? How do the 2 alternators work? My engine >mechanic did not indicate that there were any problems with the >alternators. He was pretty thorough in checking everything. > >8. What is the best way to store the coach in cold weather? Can I plug >it into a 20 amp house circuit just to keep the batteries up? Do I need >to install a 30 or 50 amp circuit ASAP in order to store the coach >properly? > >9. Are there good "RV Electrical Systems for Dummies" resources out >there? > >10. Are BBs so complicated and/or specialized that basic RV electrical >information would not be helpful? > >Brian Gatley >93 WLWB PT40 >Bend, OR > |
