Perkins Generator Radiator Cap
01-29-2006, 12:07
Could some one tell me what pressure the cap should be for the
perkins / 12.5 kohler set up. the only markings on the cap is a "D9" thank you Richard in the Sunshime State 1981 FC 35 SB |
01-29-2006, 15:05
Richard:
Mine was a 7 psi cap on the "85 for the gen set. Good choice on the tires and if you look on the overhead near the windshield in front of the drivers area, you should see a tag there with the tire information that your Coach came out of the factory with. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 12:07 AM 1/30/2006 +0000, you wrote: >Could some one tell me what pressure the cap should be for the >perkins / 12.5 kohler set up. the only markings on the cap is a "D9" > >thank you >Richard in the Sunshime State >1981 FC 35 SB > > > > |
