Dry Camping...How Long?
01-30-2006, 08:14
Ain't the House batteries seperate from the engine batteries?
SAM68,31FCPortland,TN In a message dated 1/30/2006 4:14:10 PM Central Standard Time, sforman@... writes: My coach has a brand new set of 4 T-105's. About how long could I expect to 'dry camp' on these batteries and still have enough juice to crank the engine? Assume I am just using interior lights, water pump, etc...no inverter items or anything like that. Thanks Scott Forman 82 FC35RB Memphis [Non-text portions of this message have been removed] |
01-30-2006, 09:46
expect to 'dry camp' on these batteries and still have enough juice to crank the engine? Assume I am just using interior lights, water pump, etc...no inverter items or anything like that. Thanks Scott Forman 82 FC35RB Memphis |
01-30-2006, 13:48
Not in an '82 or '83 unless someone split them
Thanks Bruce '83FCSB "Blue Skies" --- In WanderlodgeForum@yahoogroups.com, Samddurrett@a... wrote: > > > Ain't the House batteries seperate from the engine batteries? > SAM68,31FCPortland,TN > > In a message dated 1/30/2006 4:14:10 PM Central Standard Time, > sforman@r... writes: > > My coach has a brand new set of 4 T-105's. About how long could I > expect to 'dry camp' on these batteries and still have enough juice to > crank the engine? Assume I am just using interior lights, water pump, > etc...no inverter items or anything like that. > > Thanks > Scott Forman > 82 FC35RB > Memphis > > > > > > > [Non-text portions of this message have been removed] > |
01-30-2006, 19:30
Not on a FC
01-30-2006, 23:02
My 68 has a battery for the gen, another for the engine and there is a
compartment behind the entrance door with a slide out try for the house batteries. It looks originial, I did not know that they changed it. Sam 68 31 FC Portland, TN In a message dated 1/31/2006 9:20:13 AM Central Standard Time, warbucks@... writes: Some of the later FC models do in fact have a split battery bank. I have the Bluebird drawing for these coaches but dont know the exact years involved. I do know that the 1982 and below are not a split system. Tom Warner 1982 FC35 Vernon Center,NY At 02:30 AM 1/31/2006, you wrote: >Not on a FC > > > >--- In WanderlodgeForum@yahoogroups.com, Samddurrett@a... wrote: > > > > > > Ain't the House batteries seperate from the engine batteries? > > SAM68,31FCPortland,TN > > > > In a message dated 1/30/2006 4:14:10 PM Central Standard Time, > > sforman@r... writes: > > > > My coach has a brand new set of 4 T-105's. About how long could I > > expect to 'dry camp' on these batteries and still have enough >juice to > > crank the engine? Assume I am just using interior lights, water >pump, > > etc...no inverter items or anything like that. > > > > Thanks > > Scott Forman > > 82 FC35RB > > Memphis [Non-text portions of this message have been removed] |
01-31-2006, 00:29
Scott; I have dry camped for as much as a week with no problems with batts. I
run the generato every AM for two to threeh hours to fix coffee and get hot water for shower. On all BB the generator batts are isolated from the coach batts so even if the coach batts are down the generator should always start to recharge coach batts to start drive engine. 1977 35FC Scott Forman <sforman@...> wrote: Not on a FC --- In WanderlodgeForum@yahoogroups.com, Samddurrett@a... wrote: > > > Ain't the House batteries seperate from the engine batteries? > SAM68,31FCPortland,TN > > In a message dated 1/30/2006 4:14:10 PM Central Standard Time, > sforman@r... writes: > > My coach has a brand new set of 4 T-105's. About how long could I > expect to 'dry camp' on these batteries and still have enough juice to > crank the engine? Assume I am just using interior lights, water pump, > etc...no inverter items or anything like that. > > Thanks > Scott Forman > 82 FC35RB > Memphis > > > > > > > [Non-text portions of this message have been removed] > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators --------------------------------- YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- --------------------------------- What are the most popular cars? Find out at Yahoo! Autos [Non-text portions of this message have been removed] |
01-31-2006, 00:31
Scott, it would be hard to pin down a number...depending on use
factors and even temp. would have an effect. For my unit, having 6 paired "sams club" golf cart types, I could go 2 days with confidence. The real problem for my FC was not so much the current I used on demand, it was the small amp load the FC demanded all the time...for various systems (clocks, monitor panel, alarms) and such. To fix this "works as designed" limitation, I installed a solar panel to recoop this constant low amp drain. I posted the project in FILES. I am very happy with this "fix". Unless generators are prohibited, to power the microwave or toaster for breakfast/dinner, we usually run the generator for 15-20 min. twice a day also. If you going to live off the batterys, just make sure your generator battery is reliable...then you can always get her started if you have let the main batteries down...nothing ruins a morning than that sound of "no start - clicks only" from your engine and then also the generator! frank 85fc33 woodbridge, va. --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@r...> wrote: > > My coach has a brand new set of 4 T-105's. About how long could I > expect to 'dry camp' on these batteries and still have enough juice to > crank the engine? Assume I am just using interior lights, water pump, > etc...no inverter items or anything like that. > > Thanks > Scott Forman > 82 FC35RB > Memphis > |
01-31-2006, 02:33
have the Bluebird drawing for these coaches but dont know the exact years involved. I do know that the 1982 and below are not a split system. Tom Warner 1982 FC35 Vernon Center,NY At 02:30 AM 1/31/2006, you wrote: >Not on a FC > > > >--- In WanderlodgeForum@yahoogroups.com, Samddurrett@a... wrote: > > > > > > Ain't the House batteries seperate from the engine batteries? > > SAM68,31FCPortland,TN > > > > In a message dated 1/30/2006 4:14:10 PM Central Standard Time, > > sforman@r... writes: > > > > My coach has a brand new set of 4 T-105's. About how long could I > > expect to 'dry camp' on these batteries and still have enough >juice to > > crank the engine? Assume I am just using interior lights, water >pump, > > etc...no inverter items or anything like that. > > > > Thanks > > Scott Forman > > 82 FC35RB > > Memphis > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > >SPONSORED LINKS ><http://groups.yahoo.com/gads?t=ms&k=Recr...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_\ ObWmSYTw>Recreational >vehicles ><http://groups.yahoo.com/gads?t=ms&k=Wand...w2=Wa\ nderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre\ ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>W\ anderlodge ><http://groups.yahoo.com/gads?t=ms&k=Auto...3;veh\ icles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5\ =Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy3\ 4cC1O9CxA>Automotive >maintenance ><http://groups.yahoo.com/gads?t=ms&k=Recr...tiona\ l+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal\ er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xahae\ YHfELr6o72IW1A>Recreational >vehicle dealer ><http://groups.yahoo.com/gads?t=ms&k=Used...ional\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L\ -kXbDI4ZSadEw>Used >recreational vehicles ><http://groups.yahoo.com/gads?t=ms&k=Auto...vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnM\ q_4GlXA>Automotive >radiators > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
01-31-2006, 03:55
Not True! The one thing I have learned about BB's is that nothing is
standard. Some have a single battery system. Some have a two battery system - House and chassis. On some, the generator starts from the house batteries and on some, the generator starts from the chassis batteries. Some have a three battery system - House, Chassis, & Generator. And some have a two battery system with the house and chassis combined and a separate battery for the generator. Some have been modified by owners to some other configuration than factory. About the only absolute statement you can make is that it varies. Our coach is/was an all electric coach - the generator started off the house batteries. IMHO, the three battery system is the best with the ability to cross connect and cross charge as necessary. George Lowry '06 Alpine Apex - former owner of '95 WBDA 4203 Spearfish, SD Enjoying the sun in Palm Springs Byrne Lobdell wrote: >Scott; I have dry camped for as much as a week with no problems with batts. I run the generato every AM for two to threeh hours to fix coffee and get hot water for shower. On all BB the generator batts are isolated from the coach batts so even if the coach batts are down the generator should always start to recharge coach batts to start drive engine. > 1977 35FC > >Scott Forman <sforman@...> wrote: > Not on a FC > > > >--- In WanderlodgeForum@yahoogroups.com, Samddurrett@a... wrote: > > >> >>Ain't the House batteries seperate from the engine batteries? >>SAM68,31FCPortland,TN >> >>In a message dated 1/30/2006 4:14:10 PM Central Standard Time, >>sforman@r... writes: >> >>My coach has a brand new set of 4 T-105's. About how long could I >>expect to 'dry camp' on these batteries and still have enough >> >> >juice to > > >>crank the engine? Assume I am just using interior lights, water >> >> >pump, > > >>etc...no inverter items or anything like that. >> >>Thanks >>Scott Forman >>82 FC35RB >>Memphis >> >> >> >> >> >> >>[Non-text portions of this message have been removed] >> >> >> > > > > > > > SPONSORED LINKS > Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators > >--------------------------------- > YAHOO! GROUPS LINKS > > > Visit your group "WanderlodgeForum" on the web. > > To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > >--------------------------------- > > > > > > >--------------------------------- > > What are the most popular cars? Find out at Yahoo! Autos > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > > > > > > > > |
01-31-2006, 05:03
Having watched "Jeramiah Johnson" again last evening I'm thinking this is
the closest any of us will come to being "Mountain Men" and it's close enough for me. Being alone and self sufficient is an illusion but a fun one. I enjoy the forum and learn from it but with the price of diesel being what it is will probably stick with the light weight trailer. I dry camp off road and a Bird would sink to the frame. Really like you folks and agree that Birds are the best if you can afford them. I do keep the dream alive anyway. Dick Gercken Near Seattle Chevy truck and trailer, No Bird ----- Original Message ----- From: "Byrne Lobdell" Sent: Tuesday, January 31, 2006 4:29 AM Subject: Re: [WanderlodgeForum] Re: Dry Camping...How Long? > Scott; I have dry camped for as much as a week with no problems with > batts. I run the generato every AM for two to threeh hours to fix coffee > and get hot water for shower. On all BB the generator batts are isolated > from the coach batts so even if the coach batts are down the generator > should always start to recharge coach batts to start drive engine. > 1977 35FC > > Scott Forman <sforman@...> wrote: > Not on a FC > |
