Trojan Batteries And Chargers
01-31-2006, 13:44
I just finished looking at the Trojan Web Site. There are three models
that I want to talk about -- T-105, T-125, T-145. These are all identical in dimensions with the only exception being that the T-145 is slightly less than an inch taller. Here are the 20hr rates -- T-105 = 225AH, T-125 = 240AH, T-145 = 260AH. The only other difference is their weight -- T-105 = 60lbs, T-125 = 66lbs, T-145 = 72lbs. Seems like the heavier models have larger plates and should have greater durability, I suppose, more Amp Hours for sure. So I am wondering why everyone uses the T-105's? Is there a problem with using the higher reated models? If any one has any input on a new charge/converter to replace the original I would appreciate it. the original charger/converter works fine but I have been told that it will boil the batteries. In fact, the previous owner of my bus has a timer in line with the charger to prevent it from running full time when the bus is "pluged in." This actually works fine but I'm assuming that it is a one stage charger and was wondering if it would make sense to replace it with a modern 3 stage job. Also it appears that the charger and the converter are two seperate units that were originally mounted next to each other in a road side bay. I have no problems with the converter at all. Are all newer units combo charger/converters? Would it make sense to only up grade the charger? Is that even possible? Whats the best type of charger to use? Thanks in advance. -James 78FC33SB -- LasVegas NV |
01-31-2006, 13:59
James the T-105 is the winner in dollars per amp-hour. The T-125 has maximum
capacity stuffed into the T-105 case size, not sure why someone would use those if they could fit a T-145. And the T-145 is the money-no-object-what-fits-in-my-battery-rack size. Scott Peatross '87 PT40 with T-105's orbitalsolutions I just finished looking at the Trojan Web Site. There are three models that I want to talk about -- T-105, T-125, T-145. These are all identical in dimensions with the only exception being that the T-145 is slightly less than an inch taller. Here are the 20hr rates -- T-105 = 225AH, T-125 = 240AH, T-145 = 260AH. The only other difference is their weight -- T-105 = 60lbs, T-125 = 66lbs, T-145 = 72lbs. Seems like the heavier models have larger plates and should have greater durability, I suppose, more Amp Hours for sure. So I am wondering why everyone uses the T-105's? Is there a problem with using the higher reated models? [Non-text portions of this message have been removed] |
01-31-2006, 14:20
James,
Your evaluation on the batteries is quite right. There is another Trojan which is even taller - the L-16 - which has 395 AH capacity but because of the height, needs to be designed for. It is also quite heavy and expensive (around $175 ea). The T-105's seem to give the most bang for the buck. You can often find them at Sam's Club for around $50 each and they fit into the space where the designer built for them. As to the charger: The older chargers/converters were, indeed, a single stage affair. Wet lead acid batteries tend to boil or gas at 13.8 volts on a standard 70 degree day. Hotter and they will gas at a lower voltage and colder and it takes a higher voltage. The best charging system available today is a three stage charging system with temperature sensing. This is available on most inverter/charging systems and there are some straight chargers that will take all of these parameters into consideration. There is also a system (Link 2000R) along with a Heart inverter/charger (Now owned by Xantrax) that has a voltage regulator that turns you alternator into a three stage charging system. Improvements are being made every day. And of course, there are cheaper systems out there. A single stage system will only charge a battery to approximately 85% of its capacity. Since you should limit the discharge to 50% of capacity, you have lost 30% of usable capacity off the top. The three stage charger will charge a battery to capacity without gassing. With this system your batteries last longer and you get more usable capacity out of them. As I have often said, everything is a compromise. You have to look at everything and make your own decision. Check out <http://www.amplepower.com> A lot of good information available there. George Lowry '06 Alpine Apex Former owner of '95 WBDA 4203 Spearfish, SD orbitalsolutions wrote: >I just finished looking at the Trojan Web Site. There are three models >that I want to talk about -- T-105, T-125, T-145. > > > >These are all identical in dimensions with the only exception being that >the T-145 is slightly less than an inch taller. > > > >Here are the 20hr rates -- T-105 = 225AH, T-125 = 240AH, T-145 = 260AH. > > > >The only other difference is their weight -- T-105 = 60lbs, T-125 = >66lbs, T-145 = 72lbs. > > > >Seems like the heavier models have larger plates and should have >greater durability, I suppose, more Amp Hours for sure. So I am >wondering why everyone uses the T-105's? Is there a problem with using >the higher reated models? > > > >If any one has any input on a new charge/converter to replace the >original I would appreciate it. the original charger/converter works >fine but I have been told that it will boil the batteries. In fact, the >previous owner of my bus has a timer in line with the charger to prevent >it from running full time when the bus is "pluged in." This actually >works fine but I'm assuming that it is a one stage charger and was >wondering if it would make sense to replace it with a modern 3 stage >job. > > > >Also it appears that the charger and the converter are two seperate >units that were originally mounted next to each other in a road side >bay. I have no problems with the converter at all. Are all newer units >combo charger/converters? Would it make sense to only up grade the >charger? Is that even possible? Whats the best type of charger to use? > > > >Thanks in advance. > > > >-James > >78FC33SB -- LasVegas NV > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > |
01-31-2006, 15:28
Hi James I have four T-145's in my house compartment up front & they work
good for me. I have had them in for two years. Just make sure you have the room for the higher batteries in the compartment. They are in a 89 SP 36'. I had T-105's in my 79 FC that worked good also. Don 89 SP 36' Butler, PA in Zephyrhills FL right now -----Original Message----- From: orbitalsolutions To: WanderlodgeForum@yahoogroups.com Sent: Wed, 01 Feb 2006 01:44:43 -0000 Subject: [WanderlodgeForum] Trojan Batteries And Chargers I just finished looking at the Trojan Web Site. There are three models that I want to talk about -- T-105, T-125, T-145. These are all identical in dimensions with the only exception being that the T-145 is slightly less than an inch taller. Here are the 20hr rates -- T-105 = 225AH, T-125 = 240AH, T-145 = 260AH. The only other difference is their weight -- T-105 = 60lbs, T-125 = 66lbs, T-145 = 72lbs. Seems like the heavier models have larger plates and should have greater durability, I suppose, more Amp Hours for sure. So I am wondering why everyone uses the T-105's? Is there a problem with using the higher reated models? If any one has any input on a new charge/converter to replace the original I would appreciate it. the original charger/converter works fine but I have been told that it will boil the batteries. In fact, the previous owner of my bus has a timer in line with the charger to prevent it from running full time when the bus is "pluged in." This actually works fine but I'm assuming that it is a one stage charger and was wondering if it would make sense to replace it with a modern 3 stage job. Also it appears that the charger and the converter are two seperate units that were originally mounted next to each other in a road side bay. I have no problems with the converter at all. Are all newer units combo charger/converters? Would it make sense to only up grade the charger? Is that even possible? Whats the best type of charger to use? Thanks in advance. -James 78FC33SB -- LasVegas NV Yahoo! Groups Links [Non-text portions of this message have been removed] |
01-31-2006, 18:02
Thanks to all for the information.
There were no prices on the Trojan Web Site, so I don't know how much a T-145 sells for, I will soon find out. I'll need new batteries in the near future so it's a good opportunity to take a hard look at the DC system. The T-145's will fit, the one inboard batterie will be a challenge to fill, but doable. The Xantrax and Ample Power products look fantastic! If I was converting a bus the bolt in DC system by Ample Power would be just perfect -- what a neat piece of equipment !! I need to get a new charger, alt regulator, and monitor panel. That should bring the old Bird's DC system right into the twenty first century. Shouldn't be a problem finding the right sizes from the above mentioned companys. -James 78FC33SB LasVegas NV |
01-31-2006, 23:50
James, I replaced all my batteries with T-105's. I took out the old
converters (chargers) and replaced them with two 60 amp convertors that are made by Progressive Dynamics (http://www.progressivedyn.prawnserver.co...rters.html ). This gives me 120 amp charging capability, or if I am plugged into a 15 amp outlet, I can unplug one to prevent popping the circuit breaker. Both Curt and Kevin recommended these to me. I purchased them thru http://www.bestconverter.com/view_category.asp?cat=39 as they were cheaper than the "Hot Deals" on the Progressive website. Make sure to get the Charge Wizard, as it turns them into a 3 stage charger. It was a simple swap-out to install them, except I used all new wires. These are strictly chargers, not a combo charger/inverter. Steve Harrie Your Nearest BB Neighbor St. George, UT [Non-text portions of this message have been removed] |
02-01-2006, 00:15
Steve,
We have a PD-80 amp charger with the charge wizard. Works great when hooked to shore power but causes the Kohler/Yanmar generator output to drop about 10 volts when connected. The old chargers have no effect. I don't know if anyone else has this problem. We use the old 1-stage chargers when dry camping--the PD-80 when connected to AC. Bill & Rita in Roanoke, VA (45 & clear) 1987 FC-35 [Non-text portions of this message have been removed] |
02-01-2006, 07:54
> We have a PD-80 amp charger...generator output to drop about 10 volts
I don't have this problem. If I were you I would call Progressive Dynamics and see what they say. I would think there is something wrong with it. Steve '86 PT38 with 6 T105's & 1 12volt Battery |
02-01-2006, 08:11
Thanks for the reply, Steve. It's nice to know I have a neighbor.
There sure is a lot of space between you and the world when you live out here in the middle of the desert. If anyone is interested in remote dry camping, Steve or I could probably reccomend over a million prime acres in our area! I will certainly check out Progressive Dynamics, thanks. -James 78FC33SB LasVegas NV --- In WanderlodgeForum@yahoogroups.com, nicodemus815@... wrote: > > James, I replaced all my batteries with T-105's. I took out the old > converters (chargers) and replaced them with two 60 amp convertors that are made by > Progressive Dynamics > (http://www.progressivedyn.prawnserver.co...rters.html ). This gives me 120 amp charging capability, or if I am plugged into a > 15 amp outlet, I can unplug one to prevent popping the circuit breaker. Both > Curt and Kevin recommended these to me. > > I purchased them thru http://www.bestconverter.com/view_category.asp?cat=39 > as they were cheaper than the "Hot Deals" on the Progressive website. Make > sure to get the Charge Wizard, as it turns them into a 3 stage charger. It was a > simple swap-out to install them, except I used all new wires. > > These are strictly chargers, not a combo charger/inverter. > > Steve Harrie > Your Nearest BB Neighbor > St. George, UT |
02-04-2006, 02:41
I have T 125s (taller than the T 105s) in my 89SP and my Blue Point
battery filler just fits. How do you top off your batteries with the added height of the T 145s, have you found a lower profile battery filler? --- In WanderlodgeForum@yahoogroups.com, dspithaler@... wrote: > > Hi James I have four T-145's in my house compartment up front & they work good for me. I have had them in for two years. Just make sure you have the room for the higher batteries in the compartment. They are in a 89 SP 36'. I had T-105's in my 79 FC that worked good also. > Don 89 SP 36' > Butler, PA in Zephyrhills FL right now > > -----Original Message----- > From: orbitalsolutions > To: WanderlodgeForum@yahoogroups.com > Sent: Wed, 01 Feb 2006 01:44:43 -0000 > Subject: [WanderlodgeForum] Trojan Batteries And Chargers > > > > I just finished looking at the Trojan Web Site. There are three models > that I want to talk about -- T-105, T-125, T-145. > > > > These are all identical in dimensions with the only exception being that > the T-145 is slightly less than an inch taller. > > > > Here are the 20hr rates -- T-105 = 225AH, T-125 = 240AH, T-145 = 260AH. > > > > The only other difference is their weight -- T-105 = 60lbs, T-125 = > 66lbs, T-145 = 72lbs. > > > > Seems like the heavier models have larger plates and should have > greater durability, I suppose, more Amp Hours for sure. So I am > wondering why everyone uses the T-105's? Is there a problem with using > the higher reated models? > > > > If any one has any input on a new charge/converter to replace the > original I would appreciate it. the original charger/converter works > fine but I have been told that it will boil the batteries. In fact, the > previous owner of my bus has a timer in line with the charger to prevent > it from running full time when the bus is "pluged in." This actually > works fine but I'm assuming that it is a one stage charger and was > wondering if it would make sense to replace it with a modern 3 stage > job. > > > > Also it appears that the charger and the converter are two seperate > units that were originally mounted next to each other in a road side > bay. I have no problems with the converter at all. Are all newer units > combo charger/converters? Would it make sense to only up grade the > charger? Is that even possible? Whats the best type of charger to use? > > > > Thanks in advance. > > > > -James > > 78FC33SB -- LasVegas NV > > > > > > > > > Yahoo! Groups Links > > > > > > > [Non-text portions of this message have been removed] > |
