leveling jack question
02-02-2006, 15:59
Hi
I crack a fitting that goes into the top of the rear leveling jack, ( do ask it is a long story) i removed the bad fitting. got a new one my question is do i fill the jack with fluid or how do I bleed the air out? or do I ? if you are wondering I had a peice of railroad tie I have used for over a year to dispurse the weight & the dam thing split sending the jack forward! what a noise glad I wasn't under the bird,,, another lesson learned -guy smalley 86 pt 40 |
02-02-2006, 23:57
I believe it calls for Dextron II (now III) ATF fluid, not power steering
fluid. That's what I've been using.... Kevin Mc YL CA 86 38 PT [Non-text portions of this message have been removed] |
02-03-2006, 01:08
no bleeding. activate the jack normally. it will take a minute for the
system to replace the air with power steering fluid, but when it does, your done. dandarst86fc35rbhuntleyil. >From: "guysmalley" >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: [WanderlodgeForum] leveling jack question >Date: Fri, 03 Feb 2006 03:59:55 -0000 > >Hi >I crack a fitting that goes into the top of the rear leveling jack, ( do >ask it is a long story) >i removed the bad fitting. got a new one my question is do i fill the jack >with fluid or how do I >bleed the air out? or do I ? >if you are wondering I had a peice of railroad tie I have used for over a >year to dispurse the >weight & the dam thing split sending the jack forward! what a noise glad I >wasn't under the >bird,,, another lesson learned > >-guy smalley >86 pt 40 > > > > |
02-03-2006, 08:19
Didn't know that...you learn something everyday!!
KM [Non-text portions of this message have been removed] |
02-03-2006, 08:33
In my experience power steering fluid equals ATF.
dandarst86fc35rbhuntleyil. >From: krminyl@... >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: Re: [WanderlodgeForum] leveling jack question >Date: Fri, 3 Feb 2006 11:57:10 EST > >I believe it calls for Dextron II (now III) ATF fluid, not power steering >fluid. That's what I've been using.... > >Kevin Mc >YL CA >86 38 PT > > >[Non-text portions of this message have been removed] > |
