Systems monitoring and control panel
02-03-2006, 08:59
89 wanderlodge
Has anyone had experience with this panel losing all its indicator lights but
still has power
to refer alarm abd gen. switch.
There doesn't seem to be a fuse controlling the panel, a least one that i can
find.
Any help would be appreciated.
D Bell
02-03-2006, 11:29
D Bell, not sure which coach you have but our's is a 86FC and
recently when rewiring switches for a new genset we had the led's go
out. This was for the panel in the galley. I found the fuse (2A) in
the rear overhead driverside load center??????. You may also want to
check for a fuse in the front load center where you switch off all
the electrical panels. Hope this helps..
Scott B
86FC35 "RUBY"
Murrells Inlet SC "right next to heaven"
--- In WanderlodgeForum@yahoogroups.com, "bell_dab" <bell_dab@...>
> 89 wanderlodge
lights but still has power
that i can find.
> D Bell
