brake assit for TOAD
02-05-2006, 00:46
I am thinking of putting a brake assist in my new TOAD--06 Jeep Liberty.
I know nothing about them other than one name-Brake Buddy. What are
your thoughts on the different brands.
Thanks,
Jim Scoggins
04 M380
02-05-2006, 03:37
HI Jim,
I have looked at most of the various systems available and have actually
used two. The Brake Buddy and other copies consist of a heavy box that
must be installed and uninstalled each time, and stored someplace when
not under tow. To me, it is most inconvenient. I have met several
people that had one of them and changed to another system.
I originally used the Brakemaster on the El Camino towed by the
Converted GM bus. It works very well, is proportional to the brake
pressure on the towing vehicle. However the drawbacks are: it requires
tapping into the air brake system on the coach (not difficult) and (that
the wife objected to most) Installation and removal of the actuating
cylinder each time. This is the cylinder that applies pressure to the
brake pedal. There is also an air line with quick disconnects that
connects between the coach and the toad. The wife objected the work of
installing/removal of the cylinder, especially after she saw a friends
Unified Tow Brake made by US Gear,
When we got our Bird and decided to tow the Fleetwood Caddy, she
insisted she wanted a tow brake that did not require any work on her
part and was hidden from view. The Unified Tow Brake fits these
requirements. It is proportional to the slowing of the coach (determined
electronically) and takes no effort in the hook up process. The only
connection between the coach and toad is two wires which I incorporated
in the same cable as the lights so no additional work. I take that back
- I do have to connect the break-a-way cable. That is the only
additional work. The installation is completely hidden. In my case, I
put the actuator under the carpeting in the truck and ran the actuating
cable up to the brake pedal under the carpet. The only thing that shows
is the clamp on the brake pedal arm. At the driver's station of the
coach, the controller is mounted in a convenient spot. It senses the
deceleration of the vehicle and sends it to the toad. It also has
indicator lights that tell you how the system is working and a manual
lever for manual operation of the system.
I found a place in MO (Can't remember the name right now) that had the
best price. Google or Yahoo should give you a lot of places that have it.
Hope this helps you in your decision.
George Lowry
'06 Alpine Apex - former owner of '95 WBDA 4203
Spearfish, SD enjoying the weather in Palm Springs.
>Thanks,
>Jim Scoggins
>04 M380
>Yahoo! Groups Links
02-05-2006, 04:27
George,
Thank you for posting the Unified Tow Brake info. I've been thinking our
toad should have brake a control. The Unified Tow Brake is the best I've
reviewed to date.
George Lowry wrote:
> HI Jim,
> George Lowry
> >Thanks,
> >Jim Scoggins
> >04 M380
> >Yahoo! Groups Links
> SPONSORED LINKS
> Recreational vehicles
<http://groups.yahoo.com/gads?t=ms&k=Recr...vehic\
les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\
sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_O\
bWmSYTw>
> Wanderlodge
<http://groups.yahoo.com/gads?t=ms&k=Wand...2=Wan\
derlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recrea\
tional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>
> Automotive maintenance
<http://groups.yahoo.com/gads?t=ms&k=Auto...;vehi\
Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34\
cC1O9CxA>
> Recreational vehicle dealer
<http://groups.yahoo.com/gads?t=ms&k=Recr...ional\
+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\
r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeY\
HfELr6o72IW1A>
> Used recreational vehicles
<http://groups.yahoo.com/gads?t=ms&k=Used...onal+\
vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer\
&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-\
kXbDI4ZSadEw>
> Automotive radiators
<http://groups.yahoo.com/gads?t=ms&k=Auto...ehicl\
es&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Us\
ed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq\
_4GlXA>
> YAHOO! GROUPS LINKS
> * Visit your group "WanderlodgeForum
> <http://groups.yahoo.com/group/WanderlodgeForum>" on the web.
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service <http://docs.yahoo.com/info/terms/>.
02-05-2006, 04:38
Jim,
Like George, I did not want to install, uninstall and store anything
for a toad brake. I looked at United and SMI Silent Partner. I
ended up with SMI only because of the remote control and monitoring
unit in the coach cockpit. It is proportional, has breakaway
feature and the cylinder is permanently installed. It does tap into
the toad vacuum system for actuating the cylinder. It does not use
the coach air brakes. It is activated by an inertia system in a box
in the toad. Unfortunately, I think the box is a little big and
might be hard to find a hidden spot to keep it. My last toad
required that I unplug it when I needed to use the passenger seat.
Defeated the purpose of the simple concept. With my Rubicon
Wrangler, it works the way I wanted.
Take a look at both and decide what works best for you.
Tom McCarthy
Poway, CA
"Penny Express" '95 PT42
--- In WanderlodgeForum@yahoogroups.com, George Lowry
> HI Jim,
actually
that
when
requires
(that
actuating
work of
friends
her
(determined
only
incorporated
back
case, I
actuating
shows
manual
have it.
> George Lowry
Liberty.
are
> >Thanks,
> >Jim Scoggins
> >04 M380
> >Yahoo! Groups Links
02-05-2006, 07:51
Thanks Tom. I'll put the SMI unit on my list. as well as the United.
Tom McCarthy wrote:
> Jim,
> Tom McCarthy
> Poway, CA
> > HI Jim,
> actually
> that
> when
> requires
> (that
> actuating
> the
> work of
> friends
> her
> (determined
> only
> incorporated
> back
> case, I
> actuating
> shows
> the
> the
> manual
> the
> have it.
> > George Lowry
> Liberty.
> are
> > >Thanks,
> > >Jim Scoggins
> > >04 M380
> > >Yahoo! Groups Links
> SPONSORED LINKS
bWmSYTw>
> Wanderlodge
cC1O9CxA>
HfELr6o72IW1A>
kXbDI4ZSadEw>
_4GlXA>
> YAHOO! GROUPS LINKS
02-05-2006, 12:48
Jim,
FWIW, I Googled US Gear Unified Tow Brake and found several sources,
one also for the SMI unit at:
http://www.discounttowingsupply.com/stayinplay.htm
They offer a price match guarantee and free shipping on orders over
$500. Their website shows an SMI unit mounted in a 2004 Liberty.
Jim Owens
77 FC33SB (Gas)
2000 Jeep Cherokee Sport toad
Lake of the Ozarks, MO
--- In WanderlodgeForum@yahoogroups.com, "scoggins_jim"
Liberty.
> Thanks,
> Jim Scoggins
> 04 M380
02-05-2006, 13:02
I recently installed the M&G brake system and it seems a whole lot more
simple than the Unified Tow Brake. On our previous Toad I used the
Brake Buddy and did not like dealing with it. On more than one occasion
it was out of position after a long trip...you do need to check it on a
regular basis.
The M&G system is just added to the brake cylinder and is actuated by
the coaches air system. I can't even tell it is on the car and the only
'extra' hose is the air connection between the coach and the car (quick
connects at each end).
I haven't used it yet, but it is the system many others in our area were
most familiar with.
http://www.m-gengineering.com/
Brian Gatley
93 WLWB PT40
Bend, OR
-----Original Message-----
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Curt Sprenger
Sent: Sunday, February 05, 2006 8:27 AM
Subject: Re: [WanderlodgeForum] brake assit for TOAD
George,
reviewed to date.
George Lowry wrote:
> HI Jim,
actually
that
(that
(determined
incorporated
back
actuating
shows
it.
> George Lowry
Liberty.
> >Thanks,
> >Jim Scoggins
> >04 M380
> >Yahoo! Groups Links
> SPONSORED LINKS
<http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreation
al+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+veh
icle+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=
163&.sig=DAUkCKkU7Dzhn_ObWmSYTw>
&k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge&w3=Auto
motive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+v
ehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_ObWmSYTw>
> Wanderlodge
<http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicle
r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z
&k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automotive+mai
ntenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicles&w6
<http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreatio
nal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+ve
hicle+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s
=163&.sig=IF4u_5wI8Pmy34cC1O9CxA>
&k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge&w3=Aut
omotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+
vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34cC1O9CxA>
<http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recr
eational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreation
al+vehicle+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&
c=6&s=163&.sig=z6_XahaeYHfELr6o72IW1A>
&k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wanderlodge&w
3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreati
onal+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeYHfELr6o72I
W1A>
<http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recre
ational+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreationa
l+vehicle+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c
=6&s=163&.sig=UGEY5km4L-kXbDI4ZSadEw>
&k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge&w3
=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreatio
nal+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-kXbDI4ZSad
Ew>
<http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreationa
l+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehi
cle+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=1
63&.sig=ePNVMmISsCWgTnMq_4GlXA>
&k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w3=Autom
otive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+ve
hicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq_4GlXA>
> YAHOO! GROUPS LINKS
SPONSORED LINKS
Recreational
163&.sig=DAUkCKkU7Dzhn_ObWmSYTw> vehicles Wanderlodge
-8HJdysB3QLPj9U0JvqYQ> Automotive
=163&.sig=IF4u_5wI8Pmy34cC1O9CxA> maintenance
Recreational
c=6&s=163&.sig=z6_XahaeYHfELr6o72IW1A> vehicle dealer Used
=6&s=163&.sig=UGEY5km4L-kXbDI4ZSadEw> recreational vehicles
Automotive
63&.sig=ePNVMmISsCWgTnMq_4GlXA> radiators
_____
YAHOO! GROUPS LINKS
<http://groups.yahoo.com/group/WanderlodgeForum> " on the web.
Service <http://docs.yahoo.com/info/terms/> .
_____
02-05-2006, 13:23
you will find the m-g system is a great addon for your toad .The only
caveat is in a lot of new vehicles it will not fit.and it is because
of the design of the vehicle not the M-G System. there just is not
enough room under the hood for the sytem. Call m-g engineering for
tech advice they are most pleasant to deal with.It really is a good
product.
Stephen 77fc35
> regular basis.
> most familiar with.
> Brian Gatley
> 93 WLWB PT40
> Bend, OR
> George,
> reviewed to date.
> George Lowry wrote:
> > HI Jim,
> actually
> that
> (that
> (determined
> incorporated
> back
> actuating
> shows
> it.
> > George Lowry
> Liberty.
> > >Thanks,
> > >Jim Scoggins
> > >04 M380
> > >Yahoo! Groups Links
> > SPONSORED LINKS
> > Wanderlodge
> W1A>
> Ew>
> > YAHOO! GROUPS LINKS
> SPONSORED LINKS
> Recreational
> Recreational
> Automotive
> _____
> YAHOO! GROUPS LINKS
> _____
02-05-2006, 15:03
FWIW, I had one installed on my 85 WL40 and transfered it to my 95WLWB42 along
with moving it from a Jeep GC and placing it in a Durango. It has worked very
well on all vehicles and I do not hesitate to recommend the Unified tow brak by
U S Gear.
Wallace Craig
Jim Owens wrote:
Jim,
Jim Owens
77 FC33SB (Gas)
Liberty.
> Thanks,
> Jim Scoggins
> 04 M380
Yahoo! Groups Links
Yahoo! Mail - Helps protect you from nasty viruses.
02-06-2006, 03:03
Howdy.
Liberty.
> Thanks,
> Jim Scoggins
> 04 M380>>>>>>
I realize that this is probably a "dumb" question. If the weight of
theTOAD is less than 10% of the weight of the coach, does one
reallyNEED auxilliary braking for a TOAD?
Regards,
Jack
Regards,
Jack and Liz Pearce
Fulltiming in a 1993 Wanderlodge WB40
Homesick Texans in SE. FL
