Looking for a BlueBird
02-05-2006, 16:52
I'm looking around for a Bluebird motorhome, either a built as or
converted.
I rather prefer what I'll call the traditional look; the newer ones
don't to my untrained eye look like what I think a BlueBird should
look like. What year did the bus style look go away?
02-05-2006, 19:56
The style changed in the 80's, there are several on ebay right now.
Sam Durrett Portland, TN
68 31 FC
02-06-2006, 01:08
In 1988 the wide body appeared and in 1989 the FC was discontinued
for the traditional Bluebird look pre 1988 above 35 foot and pre 89
for forward control no doubt somebody will correct me because there is
a very few that were inthe crossover years but that would be the
exception
Stephen 77fc35
--- In WanderlodgeForum@yahoogroups.com, "David Scott"
> converted.
02-06-2006, 01:36
> converted.
Go to http://www.vintagebirds.com <http://www.vintagebirds.com> > history >
pictures & specifications. There you will find all each year's specs
and PICTURES.
Roger Webb - 91WL - Cedar Rapids, IA
08-24-2009, 11:26
I just looked at my first Bluebird rv, 1980 35 and I like that they seem to be
built like a brick S**t house. My question is, why did they put the genset in
such of a weird location? Also, the owner has replaced the rv with a CAT. What
is standard? Also, I see that the roof has a very small railing on the roof. Is
the roof able to be walked on? The owner did not show me the rig but a an
employee.
Any help
08-24-2009, 12:29
The genset had to go along the side because the drive engine is in the front.
On a rear engine WL the genset is in front. Late in the 80's, BB improved the
genset ground clearance, but the location stayed the same. Mostly folks seem to
keep the genset tray from "grounding out" but the clearance is minimal.
Others here may know otherwise, but I believe the Cat 3208NA is the stock engine
for 1980. Earlier models had a Ford gas industrial engine standard and the Cat
was an option. If the Cat in this 1980 has a turbo, it is a replacement for the
original Cat 3208 engine.
You can walk all over the roof inside the goat rail. Forward of the goat rail
the roof is not as strong, but it supports all 180 pounds of me.
Forum tip: Give us a name when you post so we know who you are Smile
Bob Griesel '84 FC31 WLII WA
employee.
> Any help
08-24-2009, 12:51
You may want to check out vintagebirds.com, and click on the history link. For 1980, this is what was listed:
Standard Specifications-
  • Lengths: 31', 33', 35'
  • Models: Side Bath or Rear Bath
  • Suspension:Ridewell Air Suspension
  • Generator:
    • 12. 5 KW Kohler Diesel - 35'
    • 7.5 KW Kohler Gas - 31', 33'
    • [/list]
    • Fuel Capacity: 150 Gallons
    • Engine: Caterpillar 3208-210 HP
    • Transmission: Allison Automatic 4-speed MT-643
    • Brakes: Full Air
    • Tankage:
      • Fresh Water- 98 Gallons
      • Gray Water - 60 Gallons
      • Waste Water-42 Gallons
      • LP-45 Gallons
      • [/list][/list]
      [/list]
        [/list]
          [/list]
            [/list][/list]
              [/list]
- Features-
  • All Copper Air and Fuel Lines
  • Urethane Foam Insulation
  • Twin Bed or Double Bed Available
  • Standard Gas Eye Level Oven with Range
  • Microwave Optional
  • Optional Closed Circuit Back-up Monitor
  • Panasonic Sound System Includes:
    • AM/FM Radio,
    • 8-Track Stereo,
    • Stereo Cassette Player
    • [/list]
    • Fabric Driver and Co-pilot Seats
    • Blue Bird All American Chassis
    • [/list]
Markus
1993 Triple E Regency Diesel
Date: Mon, 24 Aug 2009 23:26:48 +0000
Subject: [WanderlodgeForum] Looking for a Bluebird
I just looked at my first Bluebird rv, 1980 35 and I like that they seem to be built like a brick S**t house. My question is, why did they put the genset in such of a weird location? Also, the owner has replaced the rv with a CAT. What is standard? Also, I see that the roof has a very small railing on the roof. Is the roof able to be walked on? The owner did not show me the rig but a an employee.
Any help
Windows Live: Keep your friends up to date with what you do online. Find out more.
08-25-2009, 00:01
If you put the gen in back and you ran it at night the noise could be a problem
RE
--- On Mon, 8/24/09, Markus Meyer wrote:
Subject: RE: [WanderlodgeForum] Looking for a Bluebird
To: wanderlodgeforum@yahoogroups.com
Date: Monday, August 24, 2009, 8:51 PM
You may want to check out vintagebirds. com, and click on the history link. For 1980, this is what was listed:
  • Generator:
    • [/list]
    • Brakes: Full Air
    • Tankage:
      • LP-45 Gallons
      • [/list][/list]
      [/list]
        [/list]
          [/list]
            [/list][/list]
              [/list]
- Features-
    • AM/FM Radio,
    • 8-Track Stereo,
    • [/list]
    • [/list]
Markus
Any help
08-26-2009, 06:06
They are strong! I just had a accident with ours hitting a concrete barrier at 50mph. I was able to drive it 360 milesback to Fort worth after the accident. After this experience, and seeing Rick Archie's Wanderlodge after their accident I wouldn't have any thing else!
- Chuck Wheeler-
1982 FC 31SB Fort Worth TX
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of markhaywood58
Sent: Monday, August 24, 2009 6:27 PM
Any help
08-26-2009, 06:49
Sorry, my name is Mark.
engine for 1980. Earlier models had a Ford gas industrial engine standard and
the Cat was an option. If the Cat in this 1980 has a turbo, it is a replacement
for the original Cat 3208 engine.
employee.
> > Any help
