Safe combination?
02-14-2006, 02:00
Safe combination?
As usual, the safe in my coach is locked up tight and no one knows the
combination. Anyone know any tricks? Was there a "factory default" combination? Thanks Scott Forman 82 FC35RB Memphis |
02-14-2006, 05:27
Safe combination?
Scott, check the "files" section...i found and added info from WOO. I
had same problem, and was pleased to find mine still set to one of the listed default combos....good luck. FrankW 85FC33 Woodbridge, VA. --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > As usual, the safe in my coach is locked up tight and no one knows the > combination. Anyone know any tricks? Was there a "factory default" > combination? > > Thanks > Scott Forman > 82 FC35RB > Memphis > |
