Speedometer drive Replacement
02-14-2006, 05:33
Does anyone know where to get a replacement speedometer drive to fit the
Allison MT transmission? This is the transmissions used on the wanderlodge before 73. Even a part number would help. Blue Bird could give no help, I had a few numbers to try but they would not come up or cross over. Allison says they did not put the drive in, the manufacture did that. Sammy Durrett 68 FC 31 Portland, TN [Non-text portions of this message have been removed] |
02-14-2006, 10:57
If you're looking for the gear in the tail of the transmission, I
believe that it is an Allison part. If you're talking about a ratio-adapter mounted to the outside of the tail of the transmission, it is a SW / Stewart-Warner part and you'll need to know the ratio (which is stamped on the part's casting), and the adapter can be re-geared or replaced by a speedometer shop. I've had them re-ratioed locally, Holland Bus Company has ordered one for me once also (in Holland, MI - Rick the service manager might know, 616.392.1461). - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, Samddurrett@... wrote: > > Does anyone know where to get a replacement speedometer drive to fit the > Allison MT transmission? This is the transmissions used on the wanderlodge > before 73. Even a part number would help. Blue Bird could give no help, I had a > few numbers to try but they would not come up or cross over. Allison says > they did not put the drive in, the manufacture did that. > > Sammy Durrett > 68 FC 31 Portland, TN > > > > [Non-text portions of this message have been removed] > |
