BMC question
02-20-2006, 14:52
BMC question
A Bluebird BMC owner at Jojoba Hills RV Resort passed away two weeks ago,
his relations are currently here and have asked if there is a safe in the coach. I thought that all Bluebirds had one but a brief search did not turn one up. Can any BMC owner comment on this question, is there a safe or not? Where is it located? Thanks to all, Neil & Pat PT-36 in southern CA |
02-20-2006, 15:07
BMC question
Neil & Pat,
I don't think the safe was a standard item in a BMC. It might have been added as an option. You can check in the master bedroom closet on the driver's side. Their is a hidden compartment where extra chairs are stored. I could see one mounted in that location or under front of the bed. Hope this helps. Sorry to hear of your friend's passing. Al & Kathy Johnson '96 BMC Mandeville, Louisiana Certified Motosat Datastorm Installer --- In WanderlodgeForum@yahoogroups.com, Neil & Pat LeKander > > A Bluebird BMC owner at Jojoba Hills RV Resort passed away two weeks ago, > his relations are currently here and have asked if there is a safe in the > coach. I thought that all Bluebirds had one but a brief search did not turn > one up. Can any BMC owner comment on this question, is there a safe or not? > Where is it located? > > Thanks to all, > > Neil & Pat > PT-36 in southern CA > |
02-21-2006, 05:08
BMC question
my 93 wanderlodge wb does not have a safe.it was not put in
every coach. randy--- In WanderlodgeForum@yahoogroups.com, Neil & Pat LeKander > > A Bluebird BMC owner at Jojoba Hills RV Resort passed away two weeks ago, > his relations are currently here and have asked if there is a safe in the > coach. I thought that all Bluebirds had one but a brief search did not turn > one up. Can any BMC owner comment on this question, is there a safe or not? > Where is it located? > > Thanks to all, > > Neil & Pat > PT-36 in southern CA > |
