LED Lights
02-20-2006, 14:12
LED Lights
Does anyone know of a coversion or where to get LED lights for my bus?
What about Clearance lights? Stephen Hare 1980 FC-33SB Plant City, FL |
02-21-2006, 10:03
LED Lights
If you look at the burgundy/gold coach on http://www.wanderlodge.net you will
see Maxxima clearance lights and bezels, same mounting holes and single- wire hookup, slightly smaller so your stripes will show the old footprint, ... Maxxima side-repeaters (same mounting as the late '83 up), Maxxima front park/turn lights (old turnsignal holes welded shut, slight modification on parking light holes), and the LED tail-lamps are from a BB bus dealer. On the rear ones, the upper and lower are now used as tail-lamps, originally the upper were turn-signal only. I preferred to have them all come on. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Stephen" <share@...> wrote: > > Does anyone know of a coversion or where to get LED lights for my bus? > What about Clearance lights? > > > Stephen Hare > 1980 FC-33SB > Plant City, FL > |
08-18-2006, 06:26
LED Lights
We have one set (4) stop turn and tailights available in led
Direct replacement for the hella rectangular lights Contact me off Forum if interested Thanks Stephen 77fc35 cape0001@hotmail dot com |
11-09-2006, 06:20
LED Lights
We now have all the LED Clearance Lights for the Wanderlodge new or
old in stock plus hella replacement stop turn and tail lights the only ones that have not been sourced yet are the side beehive markers under the pilot and navigator or bosses seat on the FC Stephen 77fc35 |
12-22-2006, 08:54
LED Lights
Another shipment of led replacement Hella tail ights has arrived
Along with LED CLearance Lights a nice way to spruce up your coach If interested drop me a line Stephen 77fc35 |
12-22-2006, 15:25
LED Lights
Stephen, I have a 95 WLWB42. which would be nice with LED'S. What changes would
I have to make other than the bulbs. In short, is it a simple matter for the non-mechinical inclined. Stephen Birtles replacement Hella tail ights has arrived Along with LED CLearance Lights a nice way to spruce up your coach If interested drop me a line Stephen 77fc35 Yahoo! Groups Links Wallace Craig 95 WLWB 42 Azle, Texas [Non-text portions of this message have been removed] |
12-23-2006, 02:16
LED Lights
> > Along with LED CLearance Lights a nice way to spruce up your coach > If interested drop me a line > > Stephen 77fc35 > > I am interested in updating my coach. Chuck Somers 35FCSB cfsomers@... |
12-23-2006, 05:06
LED Lights
Wallace, the lED bulbs dont do a good job in the Volvo Tail light
assemblies (I tried). Led's will not glow dimm nor will they light up unless a treshold of voltage is meet. If your voltage is low to begin with, a toad-load may reduce you to darkness. The screw in LED's shine in a bright dot and do not fill the lenz assemblie with light. To Note: even covered with a red lenz, a white led produce a white light. Kevin&PamMac have the perfect LED ride. Kevin has a classic rearend and his coach does not have Volvo assemblies. The LED's look good and dont change the classic lines of their bus. CurtS built a relay board for my 94 Volvo tail F bulbs. I can now use the F bulb tails to land aircraft. One problem with my dimm Volvo's turned out to be the small pin connectors at the lenz. A two wire switch of 24 connections improved illumination 100%. Members with Volvo Butts should check combined functions at pretrip. (Brake lights would go out when turnsignals came on). I think LED tails are safer. The frequency of usage on the road is making the F bulb stop lights 'un alertable'. I would like to install a thin LED stop strip (caddy) between my Volvo cheeks. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, Wallace Craig > > Stephen, I have a 95 WLWB42. which would be nice with LED'S. What changes would I have to make other than the bulbs. In short, is it a simple matter for the non-mechinical inclined. > > Stephen Birtles replacement Hella tail ights has arrived > > Along with LED CLearance Lights a nice way to spruce up your coach > If interested drop me a line > > Stephen 77fc35 > > > > > Yahoo! Groups Links > > > > > > > Wallace Craig > 95 WLWB 42 > Azle, Texas > > > [Non-text portions of this message have been removed] > |
12-23-2006, 07:40
LED Lights
Wallace,
You can build the same board as Greg has and you will have BRIGHT taillights too. You will also have two sets of lights, the upper and the lower. If one goes out the other still works. It was an overkill thing, but that is me. I can send you pictures of the board if you like. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. |
12-23-2006, 08:22
LED Lights
Curt, many, many thanks but I am still working on how to operate our electric
can opener and probably should not try for overkill at this time. Have a great Christmas. Wallace & Faye Curt Sprenger You can build the same board as Greg has and you will have BRIGHT taillights too. You will also have two sets of lights, the upper and the lower. If one goes out the other still works. It was an overkill thing, but that is me. I can send you pictures of the board if you like. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Yahoo! Groups Links Wallace Craig 95 WLWB 42 Azle, Texas [Non-text portions of this message have been removed] |
