LED Lights
02-20-2006, 14:12
LED Lights
Does anyone know of a coversion or where to get LED lights for my bus?
What about Clearance lights?
Stephen Hare
1980 FC-33SB
Plant City, FL
02-21-2006, 10:03
LED Lights
If you look at the burgundy/gold coach on http://www.wanderlodge.net you will
see Maxxima clearance lights and bezels, same mounting holes and single-
wire hookup, slightly smaller so your stripes will show the old
footprint, ... Maxxima side-repeaters (same mounting as the late '83
up), Maxxima front park/turn lights (old turnsignal holes welded shut,
slight modification on parking light holes), and the LED tail-lamps are
from a BB bus dealer. On the rear ones, the upper and lower are now
used as tail-lamps, originally the upper were turn-signal only. I
preferred to have them all come on.
- Jeff Miller
in Holland, MI
> Stephen Hare
> 1980 FC-33SB
> Plant City, FL
08-18-2006, 06:26
LED Lights
We have one set (4) stop turn and tailights available in led
Direct replacement for the hella rectangular lights
Contact me off Forum if interested
Thanks
Stephen 77fc35
cape0001@hotmail dot com
11-09-2006, 06:20
LED Lights
We now have all the LED Clearance Lights for the Wanderlodge new or
old in stock plus hella replacement stop turn and tail lights
the only ones that have not been sourced yet are the side beehive
markers under the pilot and navigator or bosses seat on the FC
Stephen 77fc35
12-22-2006, 08:54
LED Lights
Another shipment of led replacement Hella tail ights has arrived
Along with LED CLearance Lights a nice way to spruce up your coach
If interested drop me a line
Stephen 77fc35
12-22-2006, 15:25
LED Lights
Stephen, I have a 95 WLWB42. which would be nice with LED'S. What changes would
I have to make other than the bulbs. In short, is it a simple matter for the
non-mechinical inclined.
Stephen Birtles wrote: Another shipment of led
Stephen 77fc35
Yahoo! Groups Links
Wallace Craig
95 WLWB 42
Azle, Texas
12-23-2006, 02:16
LED Lights
> Stephen 77fc35
I am interested in updating my coach.
Chuck Somers
35FCSB
cfsomers@...
12-23-2006, 05:06
LED Lights
Wallace, the lED bulbs dont do a good job in the Volvo Tail light
assemblies (I tried). Led's will not glow dimm nor will they light up
unless a treshold of voltage is meet. If your voltage is low to begin
with, a toad-load may reduce you to darkness. The screw in LED's
shine in a bright dot and do not fill the lenz assemblie with light.
To Note: even covered with a red lenz, a white led produce a white
light.
Kevin&PamMac have the perfect LED ride. Kevin has a classic rearend
and his coach does not have Volvo assemblies. The LED's look good
and dont change the classic lines of their bus.
CurtS built a relay board for my 94 Volvo tail F bulbs. I can now
use the F bulb tails to land aircraft. One problem with my dimm
Volvo's turned out to be the small pin connectors at the lenz. A two
wire switch of 24 connections improved illumination 100%. Members
with Volvo Butts should check combined functions at pretrip. (Brake
lights would go out when turnsignals came on).
I think LED tails are safer. The frequency of usage on the road is
making the F bulb stop lights 'un alertable'. I would like to install
a thin LED stop strip (caddy) between my Volvo cheeks.
GregoryO'Connor
94ptRomolandCa
--- In WanderlodgeForum@yahoogroups.com, Wallace Craig
changes would I have to make other than the bulbs. In short, is it a
simple matter for the non-mechinical inclined.
> Stephen 77fc35
> Yahoo! Groups Links
> Wallace Craig
> 95 WLWB 42
> Azle, Texas
12-23-2006, 07:40
LED Lights
Wallace,
You can build the same board as Greg has and you will have BRIGHT
taillights too. You will also have two sets of lights, the upper and the
lower. If one goes out the other still works. It was an overkill thing,
but that is me. I can send you pictures of the board if you like.
Curt Sprenger
Anaheim Hills, Calif.
12-23-2006, 08:22
LED Lights
Curt, many, many thanks but I am still working on how to operate our electric
can opener and probably should not try for overkill at this time. Have a great
Christmas. Wallace & Faye
Curt Sprenger wrote: Wallace,
Curt Sprenger
Yahoo! Groups Links
Wallace Craig
95 WLWB 42
Azle, Texas
