shock absorbers
02-22-2006, 14:54
shock absorbers
I have a 1983 fc-35, don't know if i need shocks or not coach has
about 80,000 miles on it and wouldDoes the old test apply? if one sees
oil its bad, if i can move it by hand i would also assume its bad, any
other tips?, i have dirt driveway with several rough spots and she
wallows back and forth. I will check the hard bar from body to axle
before checking the shocks. finally what shock do i buy, i don'texpect
these folks around here to have much knowledge.
I waaant to thank all of you for the information you have provided
re brake 1983 fc-35 SB
02-22-2006, 16:17
shock absorbers
The shocks are Koni 90-2497SP1 available from BB. Use the procedure
at http://www.koni-na.com/adjustment.cfm for the 90 series and you
will probably find that your shocks are still fine. Clean them up and
reinstall them. They are probably the older version and will need new
rubber bumpers which I believe Ralph Fullenwider has.
Tom warner
1982 FC35
Vernon Center,NY
s and are fully adjustable for the life of the shocks as long as they
>SPONSORED LINKS
><http://groups.yahoo.com/gads?t=ms&k=Recr...;vehi\
Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_\
ObWmSYTw>Recreational
>vehicles
><http://groups.yahoo.com/gads?t=ms&k=Wand...w2=Wa\
nderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre\
ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>W\
anderlodge
><http://groups.yahoo.com/gads?t=ms&k=Auto...3;veh\
icles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5\
=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy3\
4cC1O9CxA>Automotive
>maintenance
><http://groups.yahoo.com/gads?t=ms&k=Recr...tiona\
l+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal\
er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xahae\
YHfELr6o72IW1A>Recreational
>vehicle dealer
><http://groups.yahoo.com/gads?t=ms&k=Used...ional\
+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\
r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L\
-kXbDI4ZSadEw>Used
>recreational vehicles
><http://groups.yahoo.com/gads?t=ms&k=Auto...vehic\
les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\
sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnM\
q_4GlXA>Automotive
>radiators
>YAHOO! GROUPS LINKS
> * Visit your group
Wanderl\
02-22-2006, 16:45
shock absorbers
If you need new shocks, I found the best price for Koni Shocks at
<http://www.shox.com> Shipping was even free. At least give them a try. Much
better price than BB.
George Lowry
'06 Alpine Apex - Formerly '95 WBDA 4203
Spearfish, SD Now enjoying the balmy Gila Bend, AZ.
> Tom warner
> 1982 FC35
> Vernon Center,NY
>>SPONSORED LINKS
>><http://groups.yahoo.com/gads?t=ms&k=Recr...3;veh\
=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn\
_ObWmSYTw>Recreational
>>vehicles
>><http://groups.yahoo.com/gads?t=ms&k=Wand...&w2=W\
anderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recr\
eational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>\
Wanderlodge
>><http://groups.yahoo.com/gads?t=ms&k=Auto...43;ve\
hicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w\
5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy\
34cC1O9CxA>Automotive
>>maintenance
>><http://groups.yahoo.com/gads?t=ms&k=Recr...ation\
al+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea\
ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xaha\
eYHfELr6o72IW1A>Recreational
>>vehicle dealer
>><http://groups.yahoo.com/gads?t=ms&k=Used...tiona\
er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4\
L-kXbDI4ZSadEw>Used
>><http://groups.yahoo.com/gads?t=ms&k=Auto...;vehi\
Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTn\
Mq_4GlXA>Automotive
>>radiators
>>YAHOO! GROUPS LINKS
>> * Visit your group
>>Wande\
rlodgeForum-unsubscribe@yahoogroups.com
> Yahoo! Groups Links
02-22-2006, 20:25
shock absorbers
Last weekend, Steve Gureasko and with a little help from me, removed both
front Koni's on my pt. Found out that one of them could be adjusted firmer, but
the other shock was toast. Lucky for me, Steve had replced his Konis and I
was the recipient of one of the discards. What a difference in ride and
handling just adjusted shocks make. We drove on I-10 to the rally and in places
road seemed almost non-existant. My DOA shock showed no sign of leakage and
the rubber grommetts were intact. If your ride and handling is giving you a
lot of fatigue at the end of your ride, shocks may be the culprit. Ernie
Ekberg, 83pt40 in Texas
02-23-2006, 02:54
shock absorbers
FWIW, When I was going thru this on my Bird, I has a long conversation
with the factory engineer at Koni. He told me that a small amount of
oil on the shock was perfectly acceptable since some was used to
lubricate the seals. If it was "running" down the shock, then that was
a problem. That was different from what I had been taught in years
past - but things do change. I really loved those Koni shocks.
George Lowry
Spearfish, SD enjoying the warm sun in Gila Bend, AZ
but
places the
> Yahoo! Groups Links
04-02-2010, 11:28
shock absorbers
I have an 83FC35 with KONI shocks on the front, I want to change them because
the Bird (3208 250T CAT)is a wild ride with the rocking back and forth. I hope
this is not normal! Does anyone know what a replacement shock would be? And
where would one go to get one?
Thanks Bill
04-02-2010, 11:33
shock absorbers
Bill, those shocks are adjustable.
Ernie- Dillon, Mt
83PT40
Wanderlodge
Weatherford, Tx 817-475-3991
--- On Fri, 4/2/10, colitatx wrote:
Subject: [WanderlodgeForum] Shock Absorbers
Date: Friday, April 2, 2010, 6:28 PM
I have an 83FC35 with KONI shocks on the front, I want to change them because the Bird (3208 250T CAT)is a wild ride with the rocking back and forth. I hope this is not normal! Does anyone know what a replacement shock would be? And where would one go to get one?
Thanks Bill
04-02-2010, 11:42
shock absorbers
Wonderful news! How does on go about this? Do you undo the bottom and rotate the shaft, clockwise from the bottom to stiffen and counter clockwise from the bottom to weaken?
Thanks
Bill Livingston Texas
--- On Fri, 4/2/10, Ernie Ekberg wrote:
Subject: Re: [WanderlodgeForum] Shock Absorbers
Date: Friday, April 2, 2010, 6:33 PM
Ernie- Dillon, Mt
83PT40
Wanderlodge
Thanks Bill
04-02-2010, 13:49
shock absorbers
Look at the bottom of this page of adjustment instructions:
http://www.koni.com/193.html
Don Bradner
90 PT40 "Blue Thunder"
bottom and
>Thanks
>From: Ernie Ekberg
>Â
>Ernie- Dillon, Mt
>Ernie Ekberg
>83PT40
>Wanderlodge
>http://www.ernieekbergfloo ring.net
>From: colitatx
>Â
>Thanks Bill
04-03-2010, 06:51
shock absorbers
If your rear shocks are original, they are shot and are not adjustable. I
tightened my front shocks about 1/2 turn from full stiff and replaced the rear
shocks with much improvement.
David Hollis 84FC35 Springfield,IL
> Thanks Bill
