Need help running DC wires in an FC
02-23-2006, 07:56
I feel silly, but I can't find an easy way to pass three 12 guage
wires from inside the bus, under the steering wheel, to the house
battery bank directly beneth it.
It's mighty tight in there. What am I missing?
I know one thing. I could really use the assistance of a 3 foot
midgit. This is a job for a contorsionist. My aging body is sore
all over...
Here is what I'm doing -- I need to supply 12 power to 1) 400 Watt
Pure sine wave inverter 2) 200 Watt 2-way radio and 3) 100 Watt
stereo amp.
Thanks in advance.
-James
78FC33SB
LasVegas NV
02-23-2006, 08:06
Open up the drivers side front swing out compartment, feed the wires
under the dash to the outside. On the lower right of that compartment
you should have 3 large relays that has enough room around them to
feed the wires down into the battery box.
tom Warner
1982 Fc35
Vernon Center,NY
>all over...
>stereo amp.
>Thanks in advance.
>-James
>78FC33SB
>LasVegas NV
>SPONSORED LINKS
><http://groups.yahoo.com/gads?t=ms&k=Recr...;vehi\
Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_\
ObWmSYTw>Recreational
>vehicles
><http://groups.yahoo.com/gads?t=ms&k=Wand...w2=Wa\
nderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre\
ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>W\
anderlodge
><http://groups.yahoo.com/gads?t=ms&k=Auto...3;veh\
icles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5\
=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy3\
4cC1O9CxA>Automotive
>maintenance
><http://groups.yahoo.com/gads?t=ms&k=Recr...tiona\
l+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal\
er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xahae\
YHfELr6o72IW1A>Recreational
>vehicle dealer
><http://groups.yahoo.com/gads?t=ms&k=Used...ional\
+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\
r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L\
-kXbDI4ZSadEw>Used
>recreational vehicles
><http://groups.yahoo.com/gads?t=ms&k=Auto...vehic\
les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\
sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnM\
q_4GlXA>Automotive
>radiators
>YAHOO! GROUPS LINKS
> * Visit your group
Wanderl\
02-23-2006, 08:18
frontside of the steering column toward the fron of the coach open
headlight door on front of coach and lay in channel that surround
steering column and run through floor
Stephen 77fc35
--- In WanderlodgeForum@yahoogroups.com, "orbitalsolutions"
> all over...
> stereo amp.
> Thanks in advance.
> -James
> 78FC33SB
> LasVegas NV
02-23-2006, 08:18
Stephen 77fc35
> all over...
> stereo amp.
> Thanks in advance.
> -James
> 78FC33SB
> LasVegas NV
02-23-2006, 08:37
Thank you, Stephen.
I have removed the access plate and I can see daylight !! Oh Joy !!
I plan on drilling a small hole in the access plate to send the runs
through it and then I will remount it. There isn't anything wrong
with that is there?
Thanks again, Steve. This was great help
> Stephen 77fc35
guage
house
sore
> > all over...
Watt
> > stereo amp.
> > Thanks in advance.
> > -James
> > 78FC33SB
> > LasVegas NV
02-23-2006, 08:50
Thanks, Tom.
I am not sure what you mean by the driver side swing out
compartment. Are you talking about the panel on the front of the
steering coluum, or is there another access somewhere else?
-James
78FC33SB
LasVegas NV
wires
compartment
> tom Warner
> 1982 Fc35
> Vernon Center,NY
> >all over...
> >stereo amp.
> >Thanks in advance.
> >-James
> >78FC33SB
> >LasVegas NV
> >SPONSORED LINKS
t=ms&k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge&
n_ObWmSYTw>Recreational
> >vehicles
t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automot
ive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+v
8HJdysB3QLPj9U0JvqYQ>Wanderlodge
t=ms&k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge
y34cC1O9CxA>Automotive
> >maintenance
t=ms&k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wander
aeYHfELr6o72IW1A>Recreational
> >vehicle dealer
t=ms&k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderl
4L-kXbDI4ZSadEw>Used
t=ms&k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w
nMq_4GlXA>Automotive
> >radiators
> >YAHOO! GROUPS LINKS
> > * Visit your group
on the web.
> > subject=Unsubscribe>WanderlodgeForum-unsubscribe@yahoogroups.com
02-23-2006, 09:44
James, what the guys are talking about is on the OUTSIDE of the coach
there are three panels one for each side behind the headlight they
swing open and one big panel to open for access to the radiator this
panel must be lifted off. These panels are for access. In other words
if you stood in front of the bus then opened the driver side panel
you would see the steering column, the fuel pedal, break pedal, "load
center" (circut breakers etc..lots of wires)That is where they are
saying to run the wires...pretty easy access actually. This would be
a great time to "snoop around" in there when the access panel is
swung open don't pull wires loose though!!.. NOTE: When retightening
the bolts to close the front up it is a great time to add "never
sieze" material to the threads of the bolts so you don't strip out
the Riv-nuts.
Best of Luck
Scott B
1986FC35 "RUBY"
Murrells Inlet SC "right next to heaven"
> Thanks, Tom.
> -James
> 78FC33SB
> LasVegas NV
> wires
> compartment
to
> > tom Warner
> > 1982 Fc35
> > Vernon Center,NY
sore
> > >all over...
Watt
> > >stereo amp.
> > >Thanks in advance.
> > >-James
> > >78FC33SB
> > >LasVegas NV
> > >SPONSORED LINKS
> > >vehicles
> > >maintenance
> > >vehicle dealer
> > >radiators
> > >YAHOO! GROUPS LINKS
> > > * Visit your group
> on the web.
02-23-2006, 10:14
I am talking about the swing out doors on the front where the
headlights are mounted. There are 1/4 X 20 hex head bolts that hold
it on. Remove them and the door swings out revealing circuit breakers etc.
tom
At 03:50 PM 2/23/2006, you wrote:
>Thanks, Tom.
>-James
>78FC33SB
>LasVegas NV
>wires
>compartment
> > tom Warner
> > 1982 Fc35
> > Vernon Center,NY
> > >all over...
> > >stereo amp.
> > >Thanks in advance.
> > >-James
> > >78FC33SB
> > >LasVegas NV
> > >SPONSORED LINKS
> > ><<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads?
> > >vehicles
> > >maintenance
> > >vehicle dealer
> > >radiators
> > >YAHOO! GROUPS LINKS
> > > * Visit your group
"<<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yahoo.com/group/\
>on the web.
> <<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/>Yahoo!
> Terms of Service.
>SPONSORED LINKS
>vehicles
anderlodge
>maintenance
>vehicle dealer
-kXbDI4ZSadEw>Used
q_4GlXA>Automotive
>radiators
>YAHOO! GROUPS LINKS
> * Visit your group
Wanderl\
02-23-2006, 14:42
Thanks, Tom Scott and Stephen.
The job is now done and in quicker fashion with your help. My new
stereo and 2-way radio are both cranking at full speed.
The old bus is really Rocken and Talken now !!
-James
78FC33SB
LasVegas NV
hold
breakers etc.
> tom
> >Thanks, Tom.
> >-James
> >78FC33SB
> >LasVegas NV
> >wires
> >compartment
them to
> > > tom Warner
> > > 1982 Fc35
> > > Vernon Center,NY
guage
house
foot
sore
> > > >all over...
Watt
Watt
> > > >stereo amp.
> > > >Thanks in advance.
> > > >-James
> > > >78FC33SB
> > > >LasVegas NV
> > > >SPONSORED LINKS
r
h
> > > >vehicles
t
v
e
c
m
> > > >maintenance
r
e
h
> > > >vehicle dealer
l
d
m
w
e
T
> > > >radiators
> > > >YAHOO! GROUPS LINKS
> > > > * Visit your group
> >on the web.
>Yahoo!
> > Terms of Service.
> >SPONSORED LINKS
> >vehicles
> >maintenance
> >vehicle dealer
> >radiators
> >YAHOO! GROUPS LINKS
> > * Visit your group
on the web.
