Simple Question on TV wall switch mounted on inside of coach
02-23-2006, 15:35
On my coach where you plug the television coax cable to the outside
antenna there is a switch on this wall plate. When you move the switch up and down a small red light on the plate comes on and go oft. I just want to know what does this light indicate when its on or oft? Thanks Jon Jon Rebel Bird Bremerton Washington |
02-23-2006, 15:48
Sounds like a wingard antenna amplifier.
- Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Jon" > > On my coach where you plug the television coax cable to the outside > antenna there is a switch on this wall plate. When you move the > switch up and down a small red light on the plate comes on and go oft. > I just want to know what does this light > indicate when its on or oft? Thanks Jon > > Jon > Rebel Bird > Bremerton Washington > |
02-24-2006, 16:30
What Jeff said...
Bob Lawrence 84 PT36 Tacky Tacoma, Wa. > > On my coach where you plug the television coax cable to the outside > antenna there is a switch on this wall plate. When you move the > switch up and down a small red light on the plate comes on and go oft. > I just want to know what does this light > indicate when its on or oft? Thanks Jon > > Jon > Rebel Bird > Bremerton Washington > |
02-24-2006, 17:00
It might be a power switch for the antenna signal amplifier. Mine is plugged
into an AC receptical and is always on unless I unplug it. Bob & Judy Johannesen 91WLWB40 "Seldom Blue" Argyle, Tx. Bob Lawrence What Jeff said... Bob Lawrence 84 PT36 Tacky Tacoma, Wa. > > On my coach where you plug the television coax cable to the outside > antenna there is a switch on this wall plate. When you move the > switch up and down a small red light on the plate comes on and go oft. > I just want to know what does this light > indicate when its on or oft? Thanks Jon > > Jon > Rebel Bird > Bremerton Washington > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators --------------------------------- YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- --------------------------------- Yahoo! Mail Bring photos to life! New PhotoMail makes sharing a breeze. [Non-text portions of this message have been removed] |
