Oil change every three months?
02-23-2006, 15:48
Here is another overkill or is it? Should you change your oil every
three months even if you only have run say 1000 miles? Jon Rebel Bird |
02-23-2006, 17:19
Jon, Valve lash and rack adjustments are a good idea to perform more
often then even the Mfg suggests. Like you noticed with proper adjustment your bus ran better. I never understood why people got mad that they had the valve gaps checked and no adjustment was needed. To me that is like getting a good physical from your medical doctor. Fuelline and airfilters should be only changed when needed. Who is to say when the tank will pick up dirt or your fan will blow up dust on a dirt road. This could be the day after you just replaced the filters. I hear the sulfer bit about oil but think 'oil in the pan' and 'oil in a can' is the same thing. I change every 10,000. Dont forget to replace the oil pick up in the pan. I had one snap off while driving Gregory O'Connor pt40 94 --- In WanderlodgeForum@yahoogroups.com, "Jon" wrote: > > Here is another overkill or is it? Should you change your oil every > three months even if you only have run say 1000 miles? > Jon > Rebel Bird > |
02-24-2006, 01:50
Assuming the the 1000 miles was just a few longer trips rather than 100 ten mile
trips you would be wasting your money. Six months will be just fine. Jon change your oil every three months even if you only have run say 1000 miles? Jon Rebel Bird SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators --------------------------------- YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- [Non-text portions of this message have been removed] |
02-24-2006, 03:40
Most of the manufacturers recommend that oil changes in RV usage be
every 15,000 miles or one year, whichever comes first. The newer oils enable the greater oil change limitations. Best is to check the manufacturer's latest recommendations. George Lowry '06 Alpine Apex - Formerly '95 WBDA 4203 Spearfish, SD - enjoying the heat of Gila Bend, AZ thomas nihart wrote: > Assuming the the 1000 miles was just a few longer trips rather than 100 ten mile trips you would be wasting your money. Six months will be just fine. > > Jon change your oil every > three months even if you only have run say 1000 miles? > Jon > Rebel Bird > > > > > > > SPONSORED LINKS > Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators > > --------------------------------- > YAHOO! GROUPS LINKS > > > Visit your group "WanderlodgeForum" on the web. > > To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > --------------------------------- > > > > > > [Non-text portions of this message have been removed] > > > > > Yahoo! Groups Links > > > > > > > > |
