OOPS -- My CB Is Transmitting Over The Stereo !?!
02-25-2006, 13:24
I have a small problem. I have installed a CB radio with two
antennas, a Wilson 5000 that I use when I'm parked, and a 'Lil Wilson that I use when running. When I transmit on the Big Wilson it works perfect. When I transmit on the 'Lil Wilson whatever I transmit comes through the stereo speakers. I think it's finding it's way through the AM/FM antenna that is on the roof as well. I have moved it all around but the feedback through the stereo is the same everywhere I position it. I'm a bit perplexed here. I don't understand why the Wilson 5000 transmits clean but the 'Lil Wilson feeds back. Not sure what I'm doing wrong. I know this antenna is widely used on automobiles and they all have stereo's, so I must be missing something. I appreciate any help you can offer, thanks. -James 78FC33SB LasVegas NV |
02-26-2006, 06:22
I guess there are not many 2-way radio folks in this group.
For anyone that is interested, I blew the Little Wilson's base load with 100 watts continuous transmit power, peaking at about 190 watts. That is why it is bleeding all over the place. The Little Wilson is rated up to 300 watts, but don't believe it. Oh well, back to the drawing board to find a short base load antenna that can handle a bit of fire in da wire. Any suggestions? -James 79FC33SB LasVegas NV --- In WanderlodgeForum@yahoogroups.com, "orbitalsolutions" > > I have a small problem. I have installed a CB radio with two > antennas, a Wilson 5000 that I use when I'm parked, and a 'Lil > Wilson that I use when running. > > When I transmit on the Big Wilson it works perfect. When I transmit > on the 'Lil Wilson whatever I transmit comes through the stereo > speakers. > > I think it's finding it's way through the AM/FM antenna that is on > the roof as well. I have moved it all around but the feedback > through the stereo is the same everywhere I position it. > > I'm a bit perplexed here. I don't understand why the Wilson 5000 > transmits clean but the 'Lil Wilson feeds back. > > Not sure what I'm doing wrong. I know this antenna is widely used > on automobiles and they all have stereo's, so I must be missing > something. > > I appreciate any help you can offer, thanks. > > > -James > 78FC33SB > LasVegas NV > |
