Ramco mirrors
03-04-2006, 05:52
Ramco mirrors
I am going to repaint my ramco mirrors and would like to know what the procedure
is removing them,are the motors in the mirror head? or are they elsewhere and controlled with cables? If the motors are in the head I would think there is a wire loom disconnect somewhere close to the bracket mount. Thanks in advance. Fred & Jeanne Hulse Morristown Arizona 1997 Wanderlodge PT41 [Non-text portions of this message have been removed] |
03-04-2006, 06:05
Ramco mirrors
I had mine off my 89 SP & there was a plug just under the base that mounts on
the coach. Unplug it & then the wires will feed up through the arm & in to the mirrors. Hope this helps. Ramco heat remote with motor in the head Don 89 SP 36' Butler, PA In Cocoa, FL -----Original Message----- From: Fred Hulse To: wanderlodgeforum@yahoogroups.com Sent: Sat, 4 Mar 2006 10:52:50 -0700 Subject: [WanderlodgeForum] Ramco mirrors I am going to repaint my ramco mirrors and would like to know what the procedure is removing them,are the motors in the mirror head? or are they elsewhere and controlled with cables? If the motors are in the head I would think there is a wire loom disconnect somewhere close to the bracket mount. Thanks in advance. Fred & Jeanne Hulse Morristown Arizona 1997 Wanderlodge PT41 [Non-text portions of this message have been removed] Yahoo! Groups Links [Non-text portions of this message have been removed] |
03-04-2006, 06:10
Ramco mirrors
Hi Fred,
The motors are in the head and there is a multiple wire cable that goes from the controls to the head. Normally the pigtail that comes from the head is "butt connected" to the main cable. Putting a plug type disconnect would be unusual though possible. If you have to cut the wires, be certain to note the color coding so you can put it back the same. George Lowry '06 Alpine Apex - Formerly '95 WBDA 4203 Spearfish, SD - now in Gila Bend, AZ Fred Hulse wrote: > I am going to repaint my ramco mirrors and would like to know what the procedure is removing them,are the motors in the mirror head? or are they elsewhere and controlled with cables? > If the motors are in the head I would think there is a wire loom disconnect somewhere close to the bracket mount. > > Thanks in advance. > > Fred & Jeanne Hulse > Morristown Arizona > 1997 Wanderlodge PT41 > > [Non-text portions of this message have been removed] > > > > > Yahoo! Groups Links > > > > > > > > |
03-04-2006, 07:19
Ramco mirrors
Don
Thanks for the help,I was hoping there would be a plug,and the motors in the head. We will get after it! Fred & Jeanne Hulse Morristown Arizona 1997 Wanderlodge PT41 |
03-04-2006, 07:22
Ramco mirrors
George
Thanks for the information and help,I am grateful it is that simple. How long are you going to be in Gila Bend? Fred & Jeanne Hulse Morristown Arizona 1997 Wanderlodge PT41 |
03-04-2006, 09:48
Ramco mirrors
Hi Fred,
We are departing Gila Bend on Monday heading for Wilderness Lakes TTN for about ten days and then heading into Pomona for the FMCA Convention. From there we are going to Las Vegas TTN for a couple of weeks then up to Norcal for a rally and Dr.'s appointments. After the grandson's wedding, heading north for the cool weather.... George Fred Hulse wrote: > George > Thanks for the information and help,I am grateful it is that simple. > > How long are you going to be in Gila Bend? > Fred & Jeanne Hulse > Morristown Arizona > 1997 Wanderlodge PT41 > > > > > Yahoo! Groups Links > > > > > > > > |
03-04-2006, 15:35
Ramco mirrors
George,
We will have a litle time later this month and was going down to Ajo for a few days and was hoping to stop and visit,but we will see you next fall maybe. Thanks for the information on the mirrors. Fred & Jeanne Hulse Morristown Arizona 1997 Wanderlodge PT41 ================================= We are departing Gila Bend on Monday heading for Wilderness Lakes TTN for about ten days and then heading into Pomona for the FMCA Convention. From there we are going to Las Vegas TTN for a couple of weeks then up to Norcal for a rally and Dr.'s appointments. After the grandson's wedding, heading north for the cool weather.... George |
10-27-2009, 14:50
Ramco mirrors
InVue,...ZONE DEFENSE accident avoidance systems...anyone made a purchase? Experience?
http://www.ramco-eng.com/InVue/InVue.htm I received the aluminum (plastic no longer available) split shells (that's what I call them) from Ramco Engineering. They anchor the mirror head ball to the arm. Ramco shipped them at not cost to me. Installed the drivers side today. The mirror sits a little lower in the ball vs. the plastic split shells...guess this is good. Used PB Blaster and worked the two set screws out after several hours and playing with them. Coated the new shells with Anti-Seize, the set screws too, and all seems to be good.ÃÂ Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA |
10-28-2009, 10:25
Ramco mirrors
Curt,
that sounds really interesting. Would you please post a photo of this mirror instlled on your coach? TIA, Liz Pearce Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 D'Hanis, TX Buena Vista, CO Currently in Spring Branch, TX =========================================================== --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > *InVue*,...ZONE DEFENSE accident avoidance systems...anyone made a purchase? > Experience? > http://www.ramco-eng.com/InVue/InVue.htm > > I received the aluminum (plastic no longer available) split shells (that's > what I call them) from Ramco Engineering. They anchor the mirror head ball > to the arm. Ramco shipped them at not cost to me. Installed the drivers side > today. The mirror sits a little lower in the ball vs. the plastic split > shells...guess this is good. Used PB Blaster and worked the two set screws > out after several hours and playing with them. Coated the new shells with > Anti-Seize, the set screws too, and all seems to be good. > > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > |
10-28-2009, 10:47
Ramco mirrors
Liz,
The first paragraph I was inquiring about that mirror. http://www.ramco-eng.com/InVue/InVue.htm . The second paragraph I was reporting the fix to our mirror problem. Sorry for the confusion. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA On Wed, Oct 28, 2009 at 2:25 PM, homesicktexans_33009 <"jacklizpearce@gmail.com"> wrote:
