1976 Wanderlodge
03-07-2006, 07:44
1976 Wanderlodge
Chuck. I've got the Cat 3208 and I'm happy with it. It's slow but very
reliable. I don't know anything about the Ford Gas engine but I do know that Wanderlodge put in the best available components, at the time, so I'd figure the engine to be generally good. Plan on spending about $300 per rim, if you go with new ones, and probably the same for tires. As with any investment you must ask. (1) Can you afford the worst case scenario? Worst case might be engine, tire and rim problems. Can you afford to deal with all of them? (2) What are the chances of a worst case scenario? You need to inspect the bus and get a feel for how likely those items are to fail. (3) What better alternatives are available now? What else is on the market that's any better? (4) Must you purchase now? If so, then you go with your best available option. (5) Total investment. What are other 76's selling for and what is their condition. This will give you an idea of the total investment target that you should set. (6) Reality. All RV's are money losing investments so don't look at it strictly as a money issue. What you're buying is a lifestyle and the convenience to go where you want when you want. Your goal is to get the vehicle up and running within the approximate financial target. So long as you don't surpass your target by too much, then you should be okay. If you come in under your target, then that's great. Henry F. Claeys, 1979 FC, McAllen, Tx. Message: 8 Date: Mon, 6 Mar 2006 14:06:59 -0600 From: "chick rives" Subject: Re: Kuhmo Tires Hi Henry, Thanks for your input. I am not familiar with that brand, but I will look into them. After all the comments I got, I am getting gun shy about buying the 76 FC in San Antonio. The price might be attractive, but that might just be the tip of the iceberg. Do you have the 534 gas or a cat diesel? This one is the gas engine. The seller tells me that he has spent almost $3 on repairs on the mechanicals. It is on Ebay as a 1976 Bluebird Wanderlodge. If you look at it, let me know what you think. I would surely appreciate it Thanks again for time Chick ----- Original Message ----- From: Henry Claeys To: WanderlodgeForum@yahoogroups.com Sent: Monday, March 06, 2006 1:04 PM Subject: [WanderlodgeForum] Kuhmo Tires I haven't seen any mention of Kuhmo tires in the recent discussions about tires. I bought two for the front, almost three years ago, for about $300 each. They've served me well, but I only drive between 1000 and 2000 miles per year on them. Henry F. Claeys, 1979 FC35, McAllen, Texas. Henry@... |
10-02-2009, 13:56
1976 Wanderlodge
Anyone know anything about the 1976 wanderlodge on ebay. Item
number:220485445705 Says it is a 76 with a 3208 CAT. I am probably wrong, but weren't the 76's all gassers and the 3208 Cats not installed until 77'. If so, would this be a conversion? |
