Coolant test strips
03-11-2006, 05:10
Coolant test strips
Does anyone have the NAPA part number for coolant test strips? My
local store knows what I want but can't find it in their catalog. Thanks, Jack '87 FC35 "Traveller" Franklin, NC |
03-11-2006, 07:02
Coolant test strips
Hi Jack
NAPA offers a coolant test kit #4107 or 48 strips (12 packs of 4 #4105 or 50 strips in a box # 4106 They are in the back of the filter catalog listed with the aftermarket water filters Fred & Jeanne Hulse Morristown Arizona 1997 Wanderlodge PT41 |
03-11-2006, 07:22
Coolant test strips
Thanks Fred, That's exactly what I needed.
Jack [Non-text portions of this message have been removed] |
03-11-2006, 07:33
Coolant test strips
My pleasure, Jack
Fred |
03-11-2006, 10:02
Coolant test strips
Hey Jack, you may want to check a fleet guard dealer..I can not
remember the name but there is a big truck dealer on the west side of Asheville. They have been around for ever..I saw some pics on the wall I was there in Ocotober on our way back from Gatlinburg..they had em for free..gave me several. I did have about couple of hundred dollars worth of work there. If you need me to I can get their name from my maint log it is in the coach. Scott B 86FC35 SC --- In WanderlodgeForum@yahoogroups.com, "b19801973" wrote: > > Does anyone have the NAPA part number for coolant test strips? My > local store knows what I want but can't find it in their catalog. > > Thanks, > > Jack > '87 FC35 "Traveller" > Franklin, NC > |
03-11-2006, 10:09
Coolant test strips
Hey Fred, I have a question. 48 strips seems like alot to me. I was
told they can go bad over a year or two. Given that you might use one maybe two a year that is like 24yrs worth. Do you have any insight as to the shelf life. Thanks in advance. I usually ask for em when I get service. No problem so far getting a couple here and there. Scott B 86FC35 SC --- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" wrote: > > Hi Jack > NAPA offers a coolant test kit #4107 > or 48 strips (12 packs of 4 #4105 > or 50 strips in a box # 4106 > > They are in the back of the filter catalog listed with the aftermarket water > filters > > Fred & Jeanne Hulse > Morristown Arizona > 1997 Wanderlodge PT41 > |
03-11-2006, 10:23
Coolant test strips
Thanks for the offer Scott. Let me see what NAPA has to say Monday.
Jack '87 FC35 "Traveller" Franklin, NC [Non-text portions of this message have been removed] |
03-11-2006, 10:26
Coolant test strips
Scott
I think that the strips just laying around unopened would spoil in a couple years,but if they are sealed in a air tight package or jar they should last a lomg while,I agree 48 strips is way too many for someone like us to use up.Probably should be sold in 10's. Actually the store should sell by the each and order in the box of 50. Fred & Jeanne Hulse Morristown Arizona 1997 Wanderlodge PTMD41 |
03-29-2007, 14:50
Coolant test strips
On the multi-purpose strips, here are several sources:
Baldwin has a kit in quantities of 1, 4, and 50. Baldwin CTK5029 is the part number for 50 CTK029-4 is the 4 pack, CTK5029-1 is the one pack. Associated diesel is one source: http://www.adiesel.com/baldwinfilters/CTK5029-4.html FAQ at http://www.acustrip.com/faq.html Also Fleetguard CC2602B test strips, in 1, 4, and 50 packs. NAPA should have them and online http://www.dieselmanor.com/cooling_sys.asp has them. PDF info at: http://tinyurl.com/yw3j76 and http://www.dieselmanor.com/docs/FG-teststrips.pdf Dan 94 BB BMC 37' NM --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > My Cat dealer only sells the test strips in huge quantities. 50 I > think, Thes strips have a limited shelf life so most would end up in > the garbage. I still have not found a source for small quantities of > these strips. There are some multi purpose strips but they are not > accurate. > > Bruce > 1988FC35 > |
